[MCU] MSP432评测9-----PWM
1258|11
 楼主| Cjy_JDxy 发表于 2020-4-19 12:04 | 显示全部楼层 |阅读模式
今天搞了一下PWM。
PWM腿为P2.4
代码:
#include <ti/devices/msp432p4xx/driverlib/driverlib.h>
uint8_t TXData = 1;
uint8_t RXData = 0;
//![Simple Timer_A Config]
/* Timer_A PWM Configuration Parameter */
Timer_A_PWMConfig pwmConfig =
        TIMER_A_CLOCKSOURCE_SMCLK,
        TIMER_A_CLOCKSOURCE_DIVIDER_1,
        32000,
        TIMER_A_CAPTURECOMPARE_REGISTER_1,
        TIMER_A_OUTPUTMODE_RESET_SET,
        3200
int main(void)
     /* Halting the watchdog */
    MAP_WDT_A_holdTimer();
    //![Simple Timer_A Example]
    /* Setting MCLK to REFO at 128Khz for LF mode
     * Setting SMCLK to 64Khz */
    MAP_CS_setReferenceOscillatorFrequency(CS_REFO_128KHZ);
    MAP_CS_initClockSignal(CS_MCLK, CS_REFOCLK_SELECT, CS_CLOCK_DIVIDER_1);
    MAP_CS_initClockSignal(CS_SMCLK, CS_REFOCLK_SELECT, CS_CLOCK_DIVIDER_2);
    MAP_PCM_setPowerState(PCM_AM_LF_VCORE0);
    /* Configuring GPIO2.4 as peripheral output for PWM  and P6.7 for button
     * interrupt */
    MAP_GPIO_setAsPeripheralModuleFunctionOutputPin(GPIO_PORT_P2, GPIO_PIN4,
            GPIO_PRIMARY_MODULE_FUNCTION);
    MAP_GPIO_setAsInputPinWithPullUpResistor(GPIO_PORT_P1, GPIO_PIN1);
    MAP_GPIO_clearInterruptFlag(GPIO_PORT_P1, GPIO_PIN1);
    MAP_GPIO_enableInterrupt(GPIO_PORT_P1, GPIO_PIN1);
    /* Configuring Timer_A to have a period of approximately 500ms and
     * an initial duty cycle of 10% of that (3200 ticks)  */
    MAP_Timer_A_generatePWM(TIMER_A0_BASE, &pwmConfig);
    /* Enabling interrupts and starting the watchdog timer */
    MAP_Interrupt_enableInterrupt(INT_PORT1);
    MAP_Interrupt_enableSleepOnIsrExit();
    MAP_Interrupt_enableMaster();
    /* Sleeping when not in use */
    while (1)
        MAP_PCM_gotoLPM0();
/* Port1 ISR - This ISR will progressively step up the duty cycle of the PWM
* on a button press
void PORT1_IRQHandler(void)
    uint32_t status = MAP_GPIO_getEnabledInterruptStatus(GPIO_PORT_P1);
    MAP_GPIO_clearInterruptFlag(GPIO_PORT_P1, status);
    if (status & GPIO_PIN1)
        if(pwmConfig.dutyCycle == 28800)
            pwmConfig.dutyCycle = 3200;
        else
            pwmConfig.dutyCycle += 3200;
效果图:
工程:
zhangmangui 发表于 2020-4-19 21:19 | 显示全部楼层
工具很全  工作室还是学校
 楼主| Cjy_JDxy 发表于 2020-4-20 07:53 | 显示全部楼层
工具很全  工作室还是学校
公司。
21ic小喇叭 发表于 2020-4-20 14:52 | 显示全部楼层
感谢分享,周末还愿意写评测,太佩服了!
zhangmangui 发表于 2020-4-21 21:45 | 显示全部楼层
感谢分享,周末还愿意写评测,太佩服了!
我们没有周末 妹子
八层楼 发表于 2020-5-9 16:18 | 显示全部楼层
非常感谢楼主分享
观海 发表于 2020-5-9 16:19 | 显示全部楼层
至今还未用过pwm啊
guanjiaer 发表于 2020-5-9 16:26 | 显示全部楼层
楼主公司是硬件研发的吗
heimaojingzhang 发表于 2020-5-9 16:26 | 显示全部楼层
在中断里处理  会不会有影响
keaibukelian 发表于 2020-5-9 16:27 | 显示全部楼层
非常感谢楼主分享
 楼主| Cjy_JDxy 发表于 2020-5-9 16:27 | 显示全部楼层
楼主公司是硬件研发的吗
开发试验机,包括硬件和软件。
 楼主| Cjy_JDxy 发表于 2020-5-9 16:28 | 显示全部楼层
在中断里处理  会不会有影响
不会。
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
