| #define CR2_EXTTRIG_SWSTART_Set     ((uint32_t)0x00500000) void ADC_SoftwareStartConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState)
 /* Check the parameters */
 assert_param(IS_ADC_ALL_PERIPH(ADCx));
 assert_param(IS_FUNCTIONAL_STATE(NewState));
 if (NewState != DISABLE)
 /* Enable the selected ADC conversion on external event and start the selected
 ADC conversion */
 ADCx->CR2 |= CR2_EXTTRIG_SWSTART_Set;
 else
 /* Disable the selected ADC conversion on external event and stop the selected
 ADC conversion */
 ADCx->CR2 &= CR2_EXTTRIG_SWSTART_Reset;
 这里“#define CR2_EXTTRIG_SWSTART_Set     ((uint32_t)0x00500000)”把ADC_CR2的位22SWSTART和位20EXTTRIG都使能了,为什么呀?
