ESP8266 AP模式下数据返回有延迟
843|0
通过指南者学习ES8266时,发现移植火哥的代码,ESP8266在AP模式下,上位机发送指令,ESP8266返回数据时会有2-3S的延时,STA模式下收到指令就会立马返回数据,不知道这个是什么原因,哪位大神能帮忙解决下。/**
  * @brief  ESP8266 (AP Server )工作
  * @param  无
  * @retval 无
void ESP8266_ApTcpServer_Worktest ( void )
        uint8_t ucId, ucLen;
        uint8_t ucLed1Status = 0, ucLed2Status = 0, ucLed3Status = 0, ucBuzzerStatus = 0;
        char cStr [ 100 ] = { 0 }, cCh;
  char * pCh, * pCh1;
        if ( strEsp8266_Fram_Record .InfBit .FramFinishFlag )
                        USART_ITConfig ( macESP8266_USARTx, USART_IT_RXNE, DISABLE ); //禁用串口接收中断
                        strEsp8266_Fram_Record .Data_RX_BUF [ strEsp8266_Fram_Record .InfBit .FramLength ]  = '\0';
                        USART1_printf("%s\r\n",strEsp8266_Fram_Record .Data_RX_BUF);
                        if ( ( pCh = strstr ( strEsp8266_Fram_Record .Data_RX_BUF, "CMD_LED_" ) ) != 0 )
                                cCh = * ( pCh + 8 );
                                switch ( cCh )
                                    case '1':
        cCh = * ( pCh + 10 );
        switch ( cCh )
        case '0':
        macLED1_OFF ();
        ESP8266_SendString ( DISABLE, LED_State[1], strlen ( LED_State[0]), Multiple_ID_0  );
        break;
        case '1':
        macLED1_ON ();
        ESP8266_SendString ( DISABLE, LED_State[0], strlen ( LED_State[0]), Multiple_ID_0  );
        break;
        default :
        break;
        break;
                                          case '2':
        switch ( cCh )
        case '0':
        macLED2_OFF ();
        break;
        case '1':
        macLED2_ON ();
        ESP8266_SendString ( ENABLE, LED_State[2], 0, Single_ID_0 );
        break;
        default :
        break;
        break;
                                          case '3':
        switch ( cCh )
        case '0':
        macLED3_OFF ();
        ESP8266_SendString ( ENABLE, LED_State[5], 0, Single_ID_0 );
        break;
        case '1':
        macLED3_ON ();
        ESP8266_SendString ( ENABLE, LED_State[4], 0, Single_ID_0 );
        break;
        default :
        break;
        break;
                                    default :
                    break;
                        /*sprintf ( cStr, "CMD_LED_END_%d_%d_%dDHT11_BUZZER_%d_ENDBUZZER_END",
        ucLed1Status, ucLed2Status, ucLed3Status,
                  ucBuzzerStatus );
                        if ( ( pCh = strstr ( strEsp8266_Fram_Record .Data_RX_BUF, "+IPD," ) ) != 0 )
                                ucId = * ( pCh + strlen ( "+IPD," ) ) - '0';
                                ESP8266_SendString ( DISABLE, cStr, strlen ( cStr ), ( ENUM_ID_NO_TypeDef ) ucId );
                  strEsp8266_Fram_Record .InfBit .FramLength = 0;
            strEsp8266_Fram_Record .InfBit .FramFinishFlag = 0;
                        USART_ITConfig ( macESP8266_USARTx, USART_IT_RXNE, ENABLE ); //使能串口接收中断
* 函数名:ESP8266_SendString
* 描述  :WF-ESP8266模块发送字符串
* 输入  :enumEnUnvarnishTx,声明是否已使能了透传模式
*       :pStr,要发送的字符串
*       :ulStrLength,要发送的字符串的字节数
*       :ucId,哪个ID发送的字符串
* 返回  : 1,发送成功
*         0,发送失败
* 调用  :被外部调用
bool ESP8266_SendString ( FunctionalState enumEnUnvarnishTx, char * pStr, u32 ulStrLength, ENUM_ID_NO_TypeDef ucId )
        char cStr [20];
        bool bRet = false;
        if ( enumEnUnvarnishTx )
                ESP8266_Usart ( "%s", pStr );
                bRet = true;
        else
                if ( ucId < 5 )
                        sprintf ( cStr, "AT+CIPSEND=%d,%d", ucId, ulStrLength + 2 );
                else
                        sprintf ( cStr, "AT+CIPSEND=%d", ulStrLength + 2 );
                ESP8266_Cmd ( cStr, "> ", 0, 1000 );
                bRet = ESP8266_Cmd ( pStr, "SEND OK", 0, 1000 );
        return bRet;
