| 我最近也在用STM8L152C6的段试LCD显示功能,遇到了和此贴类似的问题,希望过来人指点指点,谢谢! LCD是4个COM,20个SEG,1/4duty, 1/3bias我的配置代码如下:
 void LCD_Configuration(void)
 CLK_PeripheralClockConfig(CLK_Peripheral_LCD, ENABLE);
 CLK_RTCClockConfig(CLK_RTCCLKSource_LSE, CLK_RTCCLKDiv_1);
 LCD_Init(LCD_Prescaler_2, LCD_Divider_17, LCD_Duty_1_4,
 LCD_Bias_1_3, LCD_VoltageSource_External);
 LCD_PortMaskConfig(LCD_PortMaskRegister_0, 0xFF);
 LCD_PortMaskConfig(LCD_PortMaskRegister_1, 0xFF);
 LCD_PortMaskConfig(LCD_PortMaskRegister_2, 0x0F);
 LCD_ContrastConfig(LCD_Contrast_Level_2);
 LCD_DeadTimeConfig(LCD_DeadTime_0);
 LCD_PulseOnDurationConfig(LCD_PulseOnDuration_0);
 LCD_Cmd(ENABLE);
 在主程序中驱动LCD显示字符,当我接手LCD屏后,测量COM0,COM1,COM2的波形,请看附件“接LCD屏时测得COM口波形”,此时的波形有很长的电容充放电时间,导致在某个duty时间内,电压处在0~1/3VCC范围,如果此时SEG波形也类似,就会导致某些像素点很微弱的点亮了,就出现鬼影。当我不接LCD,直接测量COM0,COM1,COM2波形,此时的波形就和datasheet上的理论波形接近。
 然后我做了如下修改:
 将  LCD_PulseOnDurationConfig(LCD_PulseOnDuration_0);
 改成  LCD_PulseOnDurationConfig(LCD_PulseOnDuration_7);
 datasheet上有这样一段话解释这句:
 The PON[2:0] (Pulse ON duration) bits in the LCD_CR2 register configure the time during
 which RL is enabled (see Figure 55) through a HD (high drive) when the levels of common
 and segment lines change. A short drive time decreases power consumption, but displays
 with high internal resistance may need a longer drive time to achieve a satisfactory contrast.
 The RL divider can be always switched on using the HD bit in the LCD_CR2 register.
 The HD switch follows the rules described below:
 ● If the HD bit and the PON[2:0] bits in the LCD_CR2 are reset, then HD switch is open.
 ● If the HD bit in the LCD_CR2 register is reset and the PON[2:0] bits in the LCD_CR2
 are different from 00 then, the HD switch is closed during the number of pulses defined
 in the PON[2:0] bits.
 ● If HD bit in the LCD_CR2 register is 1 then HD switch is always closed.
 我这样修改后就是增加了驱动时间,从而达到了较满意的对比度,测试看波形和看显示效果,果然很好,显示基本满足要求,没有鬼影。但这段话中也说了,延长驱动时间,会导致功耗增加,而我们的产品对功耗要求很高,我对这样的解决方案无法接受。请过来人指点下,怎么解决这个问题。感激不尽!
