请教:stm32L152的LCD驱动能力不够是怎么回事?
16532|31
拿起书本 发表于 2014-10-27 14:40 | 显示全部楼层
感觉STM32L软硬件兼容性做的很好,功耗真的低!
Multiplus123 发表于 2015-3-19 16:55 | 显示全部楼层
楼主,能共享下驱动的代码吗?一直在调,老是点不亮屏,不知道哪里配置不对
ZJCSC 发表于 2015-5-16 21:09 | 显示全部楼层
楼主,能共享下驱动的代码吗?一直在调,老是点不亮屏,不知道哪里配置不对 ...
这个是我自己 已跑过的程序 就是显示灰度不均匀 不知道是驱动的问题还是 液晶显示屏的问题
void LCD_GLASS_Init(void)//ÅäÖÃLCDÇý¶¯
                                LCD_InitTypeDef LCD_InitStructure;
                                RCC_Config();//ʱÖÓÅäÖÃ
                                LCD_GPIOConfig(); /*!< Configure the LCD Glass GPIO pins */
                                /*!< Configure the LCD interface -------------------------------------------*/
                                RCC_APB1PeriphClockCmd(RCC_APB1Periph_LCD, ENABLE); /*!< Enable LCD APB1 Clock */
                                LCD_InitStructure.LCD_Prescaler = LCD_Prescaler_512;
                                LCD_InitStructure.LCD_Divider = LCD_Divider_16;
                                LCD_InitStructure.LCD_Duty = LCD_Duty_1_4;
                                LCD_InitStructure.LCD_Bias = LCD_Bias_1_3;
                                LCD_InitStructure.LCD_VoltageSource = LCD_VoltageSource_External;//LCD_VoltageSource_Internal;//
                                //LCD_StructInit(&LCD_InitStructure);
                                LCD_Init(&LCD_InitStructure);
                                //LCD_MuxSegmentCmd(DISABLE);
                                /*!< Configure the Pulse On Duration */
                                LCD_PulseOnDurationConfig(LCD_PulseOnDuration_7);
                                LCD_DeadTimeConfig(LCD_DeadTime_1);
                                //LCD_HighDriveCmd(ENABLE);
                                /*!< Configure the LCD Contrast (3.51V) */
                                LCD_ContrastConfig(LCD_Contrast_Level_5);
                                /*!< Wait Until the LCD FCR register is synchronized */
                                LCD_WaitForSynchro();
                                /*!< Enable LCD peripheral */
                                LCD_Cmd(ENABLE);
                                /*!< Wait Until the LCD is enabled */
                                while(LCD_GetFlagStatus(LCD_FLAG_ENS) == RESET)
                                /*!< Wait Until the LCD Booster is ready */
                                while(LCD_GetFlagStatus(LCD_FLAG_RDY) == RESET)
void LCD_GPIOConfig(void)
                                /*!< Enable GPIOA, GPIOB, GPIOC, GPIOD and GPIOE AHB Clocks */
                                RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOB | RCC_AHBPeriph_GPIOC
        | RCC_AHBPeriph_GPIOD | RCC_AHBPeriph_GPIOE, ENABLE);
                                /*!< Connect PA.06 to LCD SEG3 */
                                GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_LCD);
                                /*!< Connect PA.07 to LCD SEG4 */
                                GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_LCD);
                                /*!< Connect PA.08 to LCD COM0 */
                                GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_LCD);
                                /*!< Connect PA.09 to LCD COM1 */
                                GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_LCD);
                                /*!< Connect PA.10 to LCD COM2 */
                                GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_LCD);
                                /*!< Connect PB.09 to LCD COM3 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_LCD);
                                /*!< Connect PC.10 to LCD COM4 */
                                //GPIO_PinAFConfig(GPIOC, GPIO_PinSource10, GPIO_AF_LCD);
                                /*!< Connect PC.11 to LCD COM5 */
                                //GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_LCD);
                                /*!< Connect PC.12 to LCD COM6 */
                                //GPIO_PinAFConfig(GPIOC, GPIO_PinSource12, GPIO_AF_LCD);
                                /*!< Connect PD.2 to LCD COM7 */
                                //GPIO_PinAFConfig(GPIOD, GPIO_PinSource2, GPIO_AF_LCD);
                          #ifndef SimulationEn
                                /*!< Connect PA.15 to LCD SEG17 */
                                GPIO_PinAFConfig(GPIOA, GPIO_PinSource15, GPIO_AF_LCD);//¹²ÓÃJTDI
                          #endif
                                /*!< Connect PB.00 to LCD SEG5 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource0, GPIO_AF_LCD);
                                /*!< Connect PB.01 to LCD SEG6 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_LCD);
                                /*!< Connect PB.03 to LCD SEG7 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_LCD);//¹²ÓÃJTDO
                                /*!< Connect PB.04 to LCD SEG8 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_LCD);//¹²ÓÃJRST
                          #endif
                                /*!< Connect PB.05 to LCD SEG9 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_LCD);
                                /*!< Connect PB.08 to LCD SEG16 */
                                /*!< Connect PB.10 to LCD SEG10 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_LCD);
                                /*!< Connect PB.11 to LCD SEG11 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_LCD);
                                /*!< Connect PB.12 to LCD SEG12 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_LCD);
                                /*!< Connect PB.13 to LCD SEG13 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_LCD);
                                /*!< Connect PB.14 to LCD SEG14*/
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_LCD);
                                /*!< Connect PB.15 to LCD SEG15 */
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_LCD);
                                GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_LCD);
                                /*!< Connect PC.00 to LCD SEG18 */
                                GPIO_PinAFConfig(GPIOC, GPIO_PinSource0, GPIO_AF_LCD);
                                /*!< Connect PC.01 to LCD SEG19 */
                                GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_LCD);
                                /*!< Connect PC.02 to LCD SEG20 */
                                GPIO_PinAFConfig(GPIOC, GPIO_PinSource2, GPIO_AF_LCD);
                                /*!< Connect PC.03 to LCD SEG21 */
                                GPIO_PinAFConfig(GPIOC, GPIO_PinSource3, GPIO_AF_LCD);
                                /*!< Connect PC.04 to LCD SEG22 */
                                GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_LCD);
                                /*!< Connect PC.05 to LCD SEG23 */
                                GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_LCD);
                                        /*!< Connect PC.06 to LCD SEG24 */
                                GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_LCD);
                                /*!< Connect PC.07 to LCD SEG25 */
                                GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_LCD);
                                /*!< Connect PC.08 to LCD SEG26 */
                                GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_LCD);
                                /*!< Connect PC.09 to LCD SEG27 */
                                GPIO_PinAFConfig(GPIOC, GPIO_PinSource9, GPIO_AF_LCD);
                                /*!< Connect PC.10 to LCD SEG40 */
                                /*!< Connect PC.11 to LCD SEG41 */
                                /*!< Connect PC.12 to LCD SEG42 */
                                /*!< Connect PD.01 to LCD SEG43 */
                                /*!< Connect PD.08 to LCD SEG28 */
                                GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_LCD);
                                /*!< Connect PD.09 to LCD SEG29 */
                                GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_LCD);
                                /*!< Connect PD.10 to LCD SEG30 */
                                GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_LCD);
                                /*!< Connect PD.11 to LCD SEG31 */
                                GPIO_PinAFConfig(GPIOD, GPIO_PinSource11, GPIO_AF_LCD);
                                /*!< Connect PD.12 to LCD SEG32 */
                                GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_LCD);
                                /*!< Connect PD.13 to LCD SEG33 */
                                GPIO_PinAFConfig(GPIOD, GPIO_PinSource13, GPIO_AF_LCD);
                                /*!< Connect PD.14 to LCD SEG34 */
                                GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_LCD);
                                /*!< Connect PD.15 to LCD SEG35 */
                                GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_LCD);
                                /*!< Connect PD.02 to LCD SEG38 */
                                GPIO_PinAFConfig(GPIOE, GPIO_PinSource2, GPIO_AF_LCD);
                                /*!< Connect PD.03 to LCD SEG39 */
                                GPIO_PinAFConfig(GPIOE, GPIO_PinSource3, GPIO_AF_LCD);
                                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 |GPIO_Pin_5 | GPIO_Pin_8 | GPIO_Pin_9 | \
        GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
                                GPIO_Init(GPIOB, &GPIO_InitStructure);
                                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | \
        GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_10 | GPIO_Pin_11 | \
        GPIO_Pin_12;
                                GPIO_Init(GPIOC, &GPIO_InitStructure);
                                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 ;
                                GPIO_Init(GPIOD, &GPIO_InitStructure);
                          GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_15;//Õý³£ÓÃ
                                #else
                                GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10;//·ÂÕæÓÃ
                                #endif
                                GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
                                GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
                                GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
                                GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
                                GPIO_Init(GPIOA, &GPIO_InitStructure);
                                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_8 | GPIO_Pin_9 |\
        GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_11 | GPIO_Pin_12 |\
        GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; //
                                #else
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_5 | GPIO_Pin_8 | GPIO_Pin_9 |\
        GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;//·ÂÕæÓà
                                #endif
                                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 |\
        GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 |  GPIO_Pin_12;
                                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | \
                                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
                                GPIO_Init(GPIOE, &GPIO_InitStructure);
ZJCSC 发表于 2015-5-16 21:17 | 显示全部楼层
我的显示屏也很大 显示都正常 就是出现显示不均匀 有的笔画颜色很深有的很浅 我看看波形也没有什么问题
insect2006 发表于 2015-5-21 18:28 | 显示全部楼层
各位我也遇到了类似的问题,不过我用的MCU是STM32F030系列
电路原理图如附件。
液晶是6个8的段式液晶,1/4Duty,1/3BIAS,3V电压
问题是COM1输出高低电平的时候,此时COM2是高阻态,电平在1/2VCC左右,突然被拉低到1/3Vcc
接了液晶和不接液晶的波形是一样
有没有人遇到过这样的问题?
冰河w 发表于 2015-5-21 19:34 | 显示全部楼层
学习了
Multiplus123 发表于 2015-6-22 11:08 | 显示全部楼层
我现在改为内部参考就好很多了
mgfhappy 发表于 2015-9-21 20:33 | 显示全部楼层
朋友能留个联系方式?
我现在用STM32L152的开发板中段码LCD的例程都跟不起来,屏上显示乱码;
hncdc 发表于 2015-12-22 16:28 | 显示全部楼层
从你这个波形图上看,LCD驱动电源好像有3.8V左右,你用的不是stm32L152芯片?
hncdc 发表于 2016-6-29 20:17 | 显示全部楼层
我使用的是内部电源,内部电源是可以从These bits specify one of the VLCD maximum voltages (independent of VDD). It ranges from
2.60 V to 3.51V.
hncdc 发表于 2016-6-29 20:26 | 显示全部楼层
这些问题似乎出在驱动能力不够上,今天下载了A版本的芯片说明书,其中有2个图片我特地截图,大家看看,是否可以通过外接分压电阻网络,解决驱动能力不够的问题。 内部电阻网络.png 外接电容图.png
