关于《STM32库开发实战指南》中SysTick中断优先级的疑问
310|0
 楼主| 过期账户 发表于 2019-11-13 18:44 | 显示全部楼层 |阅读模式
static __INLINE uint32_t SysTick_Config(uint32_t ticks)
  if (ticks > SysTick_LOAD_RELOAD_Msk)  return (1);            /* Reload value impossible */
  SysTick->LOAD  = (ticks & SysTick_LOAD_RELOAD_Msk) - 1;      /* set reload register */
  NVIC_SetPriority (SysTick_IRQn, (1<<__NVIC_PRIO_BITS) - 1);  /* set Priority for Cortex-M0 System Interrupts */
  SysTick->VAL   = 0;                                          /* Load the SysTick Counter Value */
  SysTick->CTRL  = SysTick_CTRL_CLKSOURCE_Msk |
                   SysTick_CTRL_TICKINT_Msk   |
                   SysTick_CTRL_ENABLE_Msk;                    /* Enable SysTick IRQ and SysTick Timer */
  return (0);                                                  /* Function successful */
}这个是systick的配置函数,查看了SysTick_IRQn为-1,NVIC_PRIO_BITS为4,请问大家,经过下面这个函数后,优先级到底是什么?应该是比所有的外设的中断优先级都要高吧(SysTick_IRQn为-1,负数!)
static __INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
  if(IRQn < 0) {
    SCB->SHP[((uint32_t)(IRQn) & 0xF)-4] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff); } /* set Priority for Cortex-M3 System Interrupts */
  else {
    NVIC->IP[(uint32_t)(IRQn)] = ((priority << (8 - __NVIC_PRIO_BITS)) & 0xff);    }        /* set Priority for device specific Interrupts  */
}这个是设置systick中断的库函数
