[PIC32/SAM] SAM D21Curiosity Nano+AVR STUDIO+TN9
1314|10
 楼主| Cjy_JDxy 发表于 2020-5-20 17:03 | 显示全部楼层 |阅读模式
今天捣鼓了一下TN9模块,红外温度计模块。
DATA:PA14
CLK:PA15
ACTION:PA10
代码:
#include "sam.h"
#define uchar unsigned char
#define uint unsigned int
#define REG_PORT_PINCFG14           (*(RwReg8 *)0x4100444EUL) /**< \brief (PORT) Pin Configuration 0 */
#define REG_PORT_PINCFG15           (*(RwReg8 *)0x4100444FUL) /**< \brief (PORT) Pin Configuration 0 */
void ACK_0() { REG_PORT_OUT0=0x000;}  //
void ACK_1() { REG_PORT_OUT0=0x400;}
#define DATA            ((REG_PORT_IN0 & 0x4000)>>14)
#define CLOCK           ((REG_PORT_IN0 & 0x8000)>>15)
float Temp;
float Temp1,Temp2;
unsigned char ReadData[5];
//????:Delay()
void Delay(unsigned char us)  //5,7,9
        while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
        unsigned int i,j;
        for(i=0;i<ims;i++)
        for(j=0;j<65;j++)
                Delay(1);
void TN_IRACK_EN(void)
        ACK_0();
        Delay(1);
void TN_IRACK_UN(void)
        ACK_1();
        Delay(1);
void TN_ReadData(unsigned char Flag)
        unsigned char i,j,k,BitState=0;
        for(k=0;k<7;k++)
                for(j=0;j<5;j++)
                        for(i=0;i<8;i++)
                                while(1)
                                        if(CLOCK==0)
                                        break;
                                        Delay(1);
                                Delay(1);
                                if(DATA==1)
                                BitState=1;
                                else
                                BitState=0;
                                ReadData[j]= ReadData[j]<<1;
                                ReadData[j]= ReadData[j]|BitState;
                                Delay(1);
                                while(1)
                                        if(CLOCK==1)
                                        break;
                                        Delay(1);
                if(ReadData[0]==Flag)
                k=8;
        TN_IRACK_UN();
float TN_GetData(unsigned char X)
        TN_ReadData(X);
        Temp=(ReadData[1]<<8)|ReadData[2];
        Temp=(float)Temp/16.00-273.15;
        return Temp;
float TN_GetTemp(unsigned char mode)
        float T;
                TN_IRACK_UN();
                TN_IRACK_EN();
                if(mode==0)
                        T=TN_GetData(0x4c);
                else
                        T=TN_GetData(0x66);
        return T;
void configure_port_pins(void)
        REG_PORT_DIR0=0x0400;
        REG_PORT_OUTSET0=0xC000;
        REG_PORT_PINCFG14=0x06;
        REG_PORT_PINCFG15=0x06;
int main(void)
        long int i;
        /* Initialize the SAM system */
        SystemInit();
        configure_port_pins();
        /* Replace with your application code */
        while (1)
                Temp1=TN_GetTemp(0);
                Temp2=TN_GetTemp(1);
                REG_PORT_OUT1^=0x400;
                for(i=1000000;i>0;i--);
效果图:
工程:
@ningling_21 :你应该没接TN9.把TN9的代码去掉  发表于 2020-5-27 08:45
@ningling_21 :这个不是闪灯程序,TN9测温程序  发表于 2020-5-27 08:43
下载你这个程序到板子上,灯怎么不会闪呢?  发表于 2020-5-27 08:13
小卡 发表于 2020-5-29 10:48 | 显示全部楼层
renzheshengui 发表于 2020-6-6 15:08 | 显示全部楼层
Curiosity Nano
wakayi 发表于 2020-6-6 15:09 | 显示全部楼层
入门容易吗
wowu 发表于 2020-6-6 15:09 | 显示全部楼层
楼主很勤快
xiaoqizi 发表于 2020-6-6 15:09 | 显示全部楼层
效率好高啊
木木guainv 发表于 2020-6-6 15:09 | 显示全部楼层
非常不错的模块
 楼主| Cjy_JDxy 发表于 2020-6-6 15:57 | 显示全部楼层
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
