不能同时配置RTC和USART中断优先级
472|0
 楼主| 车水马龙 发表于 2019-11-23 17:30 | 显示全部楼层 |阅读模式
你好,我用ISO板子,在同时使用RTC和USART1中断时,发现中断优先级函数NVIC_Init(&NVIC_InitStructure);不能调用两次,如果调用两次程序就进入死循环了,什么原因?请帮忙,代码如下:
void RTC_NVIC_Config(void)
        NVIC_InitTypeDef NVIC_InitStructure;
        /* Configure one bit for preemption priority */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
        /* Enable the RTC Interrupt */
        NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQn ;//|SDIO_IRQn
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x000;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        /* Enable the USARTy Interrupt */
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x1;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x001;
