没有定义的错误,可是已经定义了
367|0
 楼主| 过期账户 发表于 2019-11-28 20:22 | 显示全部楼层 |阅读模式
ST, AD, dc, TE, Value
        itoa(ADC_ConvertedValue[0], ADC_STR1,10);
        itoa(ADC_ConvertedValue[1], ADC_STR2,10);
一直说ADC_STR1没有定义:
..\..\Output\Template.axf: Error: L6218E: Undefined symbol ADC_STR1 (referred from app.o).
..\..\Output\Template.axf: Error: L6218E: Undefined symbol ADC_STR2 (referred from app.o).
可是在前面我已经定义了它:
extern unsigned char  ADC_STR1[5];
extern unsigned char  ADC_STR2[5];
这是什么原因?
itoa函数如下:
char *itoa(int value, char *string, int radix)
    int     i, d;
    int     flag = 0;
    char    *ptr = string;
    /* This implementation only works for decimal numbers. */
    if (radix != 10)
        *ptr = 0;
        return string;
    if (!value)
        *ptr++ = 0x30;
        *ptr = 0;
        return string;
    /* if this is a negative value insert the minus sign. */
    if (value < 0)
        *ptr++ = '-';
        /* Make the value positive. */
        value *= -1;
    for (i = 10000; i > 0; i /= 10)
        d = value / i;
        if (d || flag)
            *ptr++ = (char)(d + 0x30);
            value -= (d * i);
            flag = 1;
    /* Null terminate the string. */
    *ptr = 0;
    return string;
