ucosIII信号量的创建
472|0
 楼主| 菊江先生 发表于 2019-11-28 20:24 | 显示全部楼层 |阅读模式
void  OSSemCreate (OS_SEM      *p_sem,
                   CPU_CHAR    *p_name,
                   OS_SEM_CTR   cnt,
                   OS_ERR      *p_err)
    CPU_SR_ALLOC();
#ifdef OS_SAFETY_CRITICAL
    if (p_err == (OS_ERR *)0) {
        OS_SAFETY_CRITICAL_EXCEPTION();
        return;
#endif
#ifdef OS_SAFETY_CRITICAL_IEC61508
    if (OSSafetyCriticalStartFlag == DEF_TRUE) {
        *p_err = OS_ERR_ILLEGAL_CREATE_RUN_TIME;
        return;
#endif
#if OS_CFG_CALLED_FROM_ISR_CHK_EN > 0u
    if (OSIntNestingCtr > (OS_NESTING_CTR)0) {              /* Not allowed to be called from an ISR                   */
        *p_err = OS_ERR_CREATE_ISR;
        return;
#endif
#if OS_CFG_ARG_CHK_EN > 0u
    if (p_sem == (OS_SEM *)0) {                             /* Validate 'p_sem'                                       */
        *p_err = OS_ERR_OBJ_PTR_NULL;
        return;
#endif
    CPU_CRITICAL_ENTER();
    p_sem->Type    = OS_OBJ_TYPE_SEM;                       /* Mark the data structure as a semaphore                 */
    p_sem->Ctr     = cnt;                                   /* Set semaphore value                                    */
    p_sem->TS      = (CPU_TS)0;
    p_sem->NamePtr = p_name;                                /* Save the name of the semaphore                         */
    OS_PendListInit(&p_sem->PendList);                      /* Initialize the waiting list                            */
#if OS_CFG_DBG_EN > 0u
    OS_SemDbgListAdd(p_sem);
#endif
    OSSemQty++;
    CPU_CRITICAL_EXIT();
    *p_err = OS_ERR_NONE;
ucosIII中信号量的创建函数,它的参数该怎样填?
