Dialog DA9053电源管理芯片
3360|1
 楼主| array918 发表于 2011-12-21 11:14 | 显示全部楼层 |阅读模式
General descriptionThe DA9053 is a quad buck PMIC subsystem with supply domain flexibility to support a wide range of multicore application processors including ARM multicore devices, associated peripherals and user interface functions.
Combined with a switched-mode DC input/USB compatible charger, full power path management and multiple sleep modes the device offers an energy-optimised solution suitable for portable handheld, wireless and infotainment applications.
Interfacing directly to a Li-ion/polymer battery pack the high efficiency switching charger supports precise current/voltage charging as well as pre charge and USB modes without processor interaction. During charging the die temperature is thermally regulated enabling higher capacity batteries to be rapidly charged at currents up to 1.8A with minimum thermal impact to space-constrained PCB’s.
USB suspend mode operation is supported and for robustness the USB power inputs are internally protected against over-voltage conditions.
The autonomous power path controller seamlessly detects and manages energy flow between an AC adaptor, USB cable and battery whilst maintaining USB power specification compliance.
The internally-generated system power rail supports power scenarios such as instant-on with a full discharged battery. A reverse-protected backup battery charger is also integrated into the power path function.
The power efficiency and flexibility of the switching input stage is maintained to the generated supplies. Controlled by a programmable digital power manager the 14 user-programmable switched/linear regulators may be configured for a variety of start up sequences, levels and timings.
Features
  • Switched DC/USB charger with power path management
  • 4 buck converters (3 with DVS) 0.5V-2.5V up to 2Amp
  • 10 programmable LDO’s high PSRR, 1% accuracy.
  • Low power backup charger 1.1-3.1V up to 6mA
  • 32kHz RTC oscillator
  • 10 channel general purpose ADC with touch screen interface with pen down detect
  • High voltage boost for white LED driver
  • 16 bit GPIO bus for enhanced wakeup and peripheral control
  • Dual serial control interfaces with arbitration
  • Flexible autoboot and memory configurations
  • Unique ID code capability with OTP memory
Applications
  • Mobile internet devices
  • Tablet PCs
  • Personal navigation devices
  • Consumer & in-vehicle infotainment devices
Package
  • VFBGA 7x7mm package
  • VFBGA 11x11mm package
上海亚锐电子科技有限公司
电话:021-64016882
联系人:李灿
 楼主| array918 发表于 2011-12-21 11:19 | 显示全部楼层
苹果的iphone上用的也是Dialog的电源管理芯片。
