文件系统 添加f_mkdir后编译失败,去掉则可
834|0
 楼主| 香菇选手 发表于 2018-6-29 13:12 | 显示全部楼层 |阅读模式
#include "stm32f10x.h"
#include "bsp_sdio_sdcard.h"
#include "usart1.h"
#include "ff.h"
# ifndef _FF_H
  #include "diskio.h"
# endif
int main (void)
  USART1_Configuration();
  NVIC_Configuration();
  disk_initialize(0);
  f_mount(0,&fs);          //挂在到盘区
  res =f_mkdir("newdir");                               // 新建文件夹,名为newdir
  //FRESULT        f_mkdir (const TCHAR*);
  res = f_open(&fnew, "0:newfile.txt", FA_CREATE_ALWAYS | FA_WRITE );
  if ( res == FR_OK )
         res = f_write(&fnew, textFileBuffer, sizeof(textFileBuffer), &bw);
         f_close(&fnew);
  else if ( res == FR_EXIST )
    printf ("\r\n文件已经存在\n");
  res = f_open(&fnew, "0:newfile.txt", FA_OPEN_EXISTING | FA_READ);
  br=1;                        ///?
  for (;;)
    for (a=0;a<512;a++)
                   buffer[a]=0;
      res = f_read(&fnew, buffer, sizeof(buffer), &br);
      printf("\r\n %s ", buffer);
          if (res||br==0)
            {break;}
    f_close(&fnew);                /* Close open files */
    /* Unregister work area prior to discard it */
  f_mount(0, NULL);                         //卸载挂载盘区
   while(1);
编译后 output显示:
Build target 'Target 1'
compiling main.c...
linking...
..\Output\STM-DEMO.axf: Error: L6218E: Undefined symbol f_mkdir (referred from main.o).
..\Output\STM-DEMO.axf: Not enough information to list image symbols.
..\Output\STM-DEMO.axf: Finished: 1 information, 0 warning and 1 error messages.
Target not created
问题:
添加f_mkdir后编译失败,去掉则可。output显示main中没有定义f_mkdir,但我在头文件已经#include “ff.h”,同样是ff.h中的 f_read和f_write 却可以编译通过。。
请教前辈,多谢!
另外,此main函数中  br=1,有什么作用?因为f_read()中有一行 :*br = 0;        /* Initialize byte counter */,将br初始化为0,为何在f_read前 还给br赋值1?  此处优点不解。。。
[/td][/tr][/table]
