[其他模拟产品-信号链] TMS37157低频收发器MCU接口方案
2598|0
 楼主| kakio 发表于 2011-12-23 17:12 | 显示全部楼层 |阅读模式
TI公司的TMS37157把低频收发器接口和SPI接口与功率管理组合在一起,非常适合任何配置,数据采集,传感器遥控制应用.TMS37157工作电压2V到3.6V,超低的功耗,工作时功耗为150uA,降功耗模式为60nA.本文介绍TMS37157主要特性,广泛的应用范围,方框图,功率管理框图, 和直接连接到电池的MCU应用电路,以及MCU连接到TMS37157 VBATI输出的应用电路.
The TMS37157 combines a Low Frequency Transponder Interface with an SPI Interface and Power Management for a connected microcontroller. It is the ideal device for any Configuration, Data Logger-, Sensoror Remote Control Application. The Transponder memory is accessible through SPI and LF and, in the second case, operates without the need for a battery. The use of the Low Frequency Band ensures a communication in a defined direction and harsh environments.
The TMS37157 manages the Transponder communication and push button interaction. During sleep state the devices enters a special low power mode with only 60 nA current consumption.
The EEPROM memory is accessible over the LF interface without support from the battery or through SPI by a microcontroller if a battery is connected. The TMS37157 offers a special battery charge mode.
The external resonance circuit with a LF coil and a resonance capacitor can be trimmed to the correct resonance frequency with the integrated trimming capability achieving an easy way to eliminate part tolerances.
The small RSA 16-pin package together with only a few external components results in a cost efficient design.
TMS37157主要特性:
TMS37157应用:
图1.TMS37157方框图
