DMA结构体各个成员函数的详细意义
962|0
 楼主| 道子 发表于 2018-7-11 15:02 | 显示全部楼层 |阅读模式
typedef struct
  uint32_t DMA_Channel;            /*!< Specifies the channel used for the specified stream.
                                        This parameter can be a value of @ref DMA_channel */
  uint32_t DMA_PeripheralBaseAddr; /*!< Specifies the peripheral base address for DMAy Streamx. */
  uint32_t DMA_Memory0BaseAddr;    /*!< Specifies the memory 0 base address for DMAy Streamx.
                                        This memory is the default memory used when double buffer mode is
                                        not enabled. */
  uint32_t DMA_DIR;                /*!< Specifies if the data will be transferred from memory to peripheral,
                                        from memory to memory or from peripheral to memory.
                                        This parameter can be a value of @ref DMA_data_transfer_direction */
  uint32_t DMA_BufferSize;         /*!< Specifies the buffer size, in data unit, of the specified Stream.
                                        The data unit is equal to the configuration set in DMA_PeripheralDataSize
                                        or DMA_MemoryDataSize members depending in the transfer direction. */
  uint32_t DMA_PeripheralInc;      /*!< Specifies whether the Peripheral address register should be incremented or not.
                                        This parameter can be a value of @ref DMA_peripheral_incremented_mode */
  uint32_t DMA_MemoryInc;          /*!< Specifies whether the memory address register should be incremented or not.
                                        This parameter can be a value of @ref DMA_memory_incremented_mode */
  uint32_t DMA_PeripheralDataSize; /*!< Specifies the Peripheral data width.
                                        This parameter can be a value of @ref DMA_peripheral_data_size */
  uint32_t DMA_MemoryDataSize;     /*!< Specifies the Memory data width.
                                        This parameter can be a value of @ref DMA_memory_data_size */
  uint32_t DMA_Mode;               /*!< Specifies the operation mode of the DMAy Streamx.
                                        This parameter can be a value of @ref DMA_circular_normal_mode
                                        @note The circular buffer mode cannot be used if the memory-to-memory
                                              data transfer is configured on the selected Stream */
  uint32_t DMA_Priority;           /*!< Specifies the software priority for the DMAy Streamx.
                                        This parameter can be a value of @ref DMA_priority_level */
  uint32_t DMA_FIFOMode;          /*!< Specifies if the FIFO mode or Direct mode will be used for the specified Stream.
                                        This parameter can be a value of @ref DMA_fifo_direct_mode
                                        @note The Direct mode (FIFO mode disabled) cannot be used if the
                                               memory-to-memory data transfer is configured on the selected Stream */
  uint32_t DMA_FIFOThreshold;      /*!< Specifies the FIFO threshold level.
                                        This parameter can be a value of @ref DMA_fifo_threshold_level */
  uint32_t DMA_MemoryBurst;        /*!< Specifies the Burst transfer configuration for the memory transfers.
                                        It specifies the amount of data to be transferred in a single non interruptable
                                        transaction. This parameter can be a value of @ref DMA_memory_burst
                                        @note The burst mode is possible only if the address Increment mode is enabled. */
  uint32_t DMA_PeripheralBurst;    /*!< Specifies the Burst transfer configuration for the peripheral transfers.
                                        transaction. This parameter can be a value of @ref DMA_peripheral_burst
}DMA_InitTypeDef;
谁能重点解释下倒数5个的成员变量置成不同的值时的DMA对应的转换的反应吗?比如那个Circul的模式是指的啥循环,还有那个FIFO指的是那个转换数据的先入先出?
