STM32f769 RTC亚秒寄存器平移失败
622|0
 楼主| 你画我瞎 发表于 2018-7-14 16:46 | 显示全部楼层 |阅读模式
我需要做一个在捕获GPS的pps信号时通过平移操作来同步RTC时钟和GPS PPS信号的上升沿,但是平移操作无法成功,通过函数发现在判断
RTC_CR寄存器REFCKON位时条件始终无法满足,初始化添加了清除此位的操作还是一样,查看代码没有发现将此位置位的操作,有没有遇到
同样问题的
平移函数HAL_StatusTypeDef HAL_RTCEx_SetSynchroShift(RTC_HandleTypeDef* hrtc, uint32_t ShiftAdd1S, uint32_t ShiftSubFS)
  uint32_t tickstart = 0;
  /* Check the parameters */
  assert_param(IS_RTC_SHIFT_ADD1S(ShiftAdd1S));
  assert_param(IS_RTC_SHIFT_SUBFS(ShiftSubFS));
  /* Process Locked */
  __HAL_LOCK(hrtc);
  hrtc->State = HAL_RTC_STATE_BUSY;
  /* Disable the write protection for RTC registers */
  __HAL_RTC_WRITEPROTECTION_DISABLE(hrtc);
  /* Get tick */
  tickstart = HAL_GetTick();
    /* Wait until the shift is completed*/
    while((hrtc->Instance->ISR & RTC_ISR_SHPF) != RESET)
      if((HAL_GetTick() - tickstart ) > RTC_TIMEOUT_VALUE)
        /* Enable the write protection for RTC registers */
        __HAL_RTC_WRITEPROTECTION_ENABLE(hrtc);
        hrtc->State = HAL_RTC_STATE_TIMEOUT;
        /* Process Unlocked */
        __HAL_UNLOCK(hrtc);
        return HAL_TIMEOUT;
    /* Check if the reference clock detection is disabled */
    if((hrtc->Instance->CR & RTC_CR_REFCKON) == RESET)
      /* Configure the Shift settings */
      hrtc->Instance->SHIFTR = (uint32_t)(uint32_t)(ShiftSubFS) | (uint32_t)(ShiftAdd1S);
      /* If  RTC_CR_BYPSHAD bit = 0, wait for synchro else this check is not needed */
      if((hrtc->Instance->CR & RTC_CR_BYPSHAD) == RESET)
        if(HAL_RTC_WaitForSynchro(hrtc) != HAL_OK)
          hrtc->State = HAL_RTC_STATE_ERROR;
          __HAL_UNLOCK(hrtc);
          return HAL_ERROR;
    else
      /* Change RTC state */
      __HAL_UNLOCK(hrtc);
      return HAL_ERROR;
  hrtc->State = HAL_RTC_STATE_READY;
  __HAL_UNLOCK(hrtc);
  return HAL_OK;
初始化清除RTC_CR寄存器REFCKON位
但是在平移操作判断if((hrtc->Instance->CR & RTC_CR_REFCKON) == RESET)始终RTC_CR 寄存器REFCKON位为1
导致平移失败
