关于c语言宏定义与结构体的问题
290|0
 楼主| 社畜一枚 发表于 2018-7-29 10:54 | 显示全部楼层 |阅读模式
typedef struct RampGen_t        //定义结构体
        int32_t count;
        int32_t XSCALE;
        float out;
        void (*Init)(struct RampGen_t *ramp, int32_t XSCALE);
        float (*Calc)(struct RampGen_t *ramp);
        void (*SetCounter)(struct RampGen_t *ramp, int32_t count);
        void (*ResetCounter)(struct RampGen_t *ramp);
        void (*SetScale)(struct RampGen_t *ramp, int32_t scale);
        uint8_t (*IsOverflow)(struct RampGen_t *ramp);
}RampGen_t;
#define RAMP_GEN_DAFAULT                                                        //宏定义结构体变量?可以嘛?
                                                        .count = 0,
                                                        .XSCALE = 0,
                                                        .out = 0,
                                                        .Init = &RampInit,
                                                        .Calc = &RampCalc,
                                                        .SetCounter = &RampSetCounter,
                                                        .ResetCounter = &RampResetCounter,
                                                        .SetScale = &RampSetScale,
                                                        .IsOverflow = &RampIsOverflow,
RampGen_t LRSpeedRamp = RAMP_GEN_DAFAULT;                            //定义结构体变量,然后把宏定义的值赋到结构体变量中
这个程序是我看别人程序看来得,请问c语言编译有问题吗?
