STM32F407读写NAND FLASH ReadSmallPage 只能读一页
452|0
 楼主| 第8号打板工 发表于 2018-7-29 16:30 | 显示全部楼层 |阅读模式
为何 NumPageToRead=1时可以正常读数据,而=2时没有读到任何数据?
读操作程序如下:
uint32_t FSMC_NAND_ReadSmallPage(uint16_t *pBuffer, NAND_ADDRESS Address, uint32_t NumPageToRead)
  uint32_t index = 0x00, numpageread = 0x00, addressstatus = NAND_VALID_ADDRESS;
  uint32_t status = NAND_READY, size = 0x00;
  while((NumPageToRead != 0x0) && (addressstatus == NAND_VALID_ADDRESS))
    /* Page Read command and page address */
    *(vu8 *)(NAND_FLASH_START_ADDR | CMD_AREA) = NAND_CMD_READ_1;
    *(vu8 *)(NAND_FLASH_START_ADDR | ADDR_AREA) = 0x00;
    *(vu8 *)(NAND_FLASH_START_ADDR | ADDR_AREA) = 0X00;
    *(vu8 *)(NAND_FLASH_START_ADDR | ADDR_AREA) = ADDR_1st_CYCLE(ROW_ADDRESS);
    *(vu8 *)(NAND_FLASH_START_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(ROW_ADDRESS);
    *(vu8 *)(NAND_FLASH_START_ADDR | CMD_AREA) = NAND_CMD_READ_TRUE;
   while( GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) == 0 );
    /* Calculate the size */
    size = NAND_PAGE_SIZE + (NAND_PAGE_SIZE * numpageread);
        for(index=0; index < 0x490; index++){}/延时
    /* Get Data into Buffer */
    for(; index < size; index++)
      pBuffer[index]= *(vu16 *)(NAND_FLASH_START_ADDR | DATA_AREA);
    numpageread++;
    NumPageToRead--;
    /* Calculate page address */
    addressstatus = FSMC_NAND_AddressIncrement(&Address);
  status = FSMC_NAND_GetStatus();
  return (status | addressstatus);
test程序:
void FSMC_NAND_Test(void)
  uint16_t index;
    uint16_t j;
  NAND_IDTypeDef NAND_ID;
  NAND_ADDRESS WriteReadAddr;
  FSMC_NANDDeInit(FSMC_Bank2_NAND);
  FSMC_NAND_Init();
  FSMC_NAND_ReadID(&NAND_ID);
  printf("Nand Flash ID = %02X,%02X,%02X,%02X  ",NAND_ID.Maker_ID, NAND_ID.Device_ID,
                                                         NAND_ID.Third_ID, NAND_ID.Fourth_ID );
  if ((NAND_ID.Maker_ID == 0xEC) && (NAND_ID.Device_ID == 0xF1)
                && (NAND_ID.Third_ID == 0x80) && (NAND_ID.Fourth_ID == 0x15))
         printf("Type = K9F1G08U0A
  else if ((NAND_ID.Maker_ID == 0xEC) && (NAND_ID.Device_ID == 0xF1)
                && (NAND_ID.Third_ID == 0x00) && (NAND_ID.Fourth_ID == 0x95))
         printf("Type = K9F1G08U0B
  else if ((NAND_ID.Maker_ID == 0xAD) && (NAND_ID.Device_ID == 0xF1)
                && (NAND_ID.Third_ID == 0x80) && (NAND_ID.Fourth_ID == 0x1D))
         printf("Type = HY27UF081G2A
  else
         printf("Type = Unknow
  /* NAND memory address to write to */
  WriteReadAddr.Zone = 0x00;
  WriteReadAddr.Block = 0x00;
  WriteReadAddr.Page = 0x00;
  /* Erase the NAND first Block */
  FSMC_NAND_EraseBlock(WriteReadAddr);
  /* Write data to FSMC NOR memory */
  /* Fill the buffer to send */
  for (index = 0; index < 3000; index++ )
     TxBuffer[index] = index;
  FSMC_NAND_WriteSmallPage(TxBuffer, WriteReadAddr, 2);
   printf("
Written to the number of£o
   for(j = 0; j < 3000; j++)
        printf("%x
",TxBuffer[j]);
  /* Read back the written data */
  FSMC_NAND_ReadSmallPage (RxBuffer, WriteReadAddr, 2);
     printf("
Read several£o
        printf("%x
",RxBuffer[j]);
