STM32F411CE片子, 将HSE设置为主时钟,配置出错。请大神看下。
441|0
 楼主| 大碴子味 发表于 2018-7-29 16:52 | 显示全部楼层 |阅读模式
我想将外部时钟(HSE 8M)设置为系统主时钟。我是按照STM32F4固件库说明修改的,结果主时钟是HSI输出,不是HSE输出。请大神支出那么有问题?(前提晶振绝对可以起振的,用STM32CubeMX生成的工程测试过。)固件库是探索者学习板A盘中带着F4的库
代码如下:static void SetSysClock(void) 下合适我STM32F411CE的程序。
#elif defined (STM32F411xE)
#if defined (USE_HSE_BYPASS)
/*            PLL (clocked by HSE) used as System clock source                */
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /* Enable HSE and HSE BYPASS */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON | RCC_CR_HSEBYP);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Select regulator voltage output Scale 1 mode */
    RCC->APB1ENR |= RCC_APB1ENR_PWREN;
    PWR->CR |= PWR_CR_VOS;
    /* HCLK = SYSCLK / 1*/
    RCC->CFGR |= RCC_CFGR_HPRE_DIV1;
    /* PCLK2 = HCLK / 2*/
    RCC->CFGR |= RCC_CFGR_PPRE2_DIV1;
    /* PCLK1 = HCLK / 2*/
    RCC->CFGR |= RCC_CFGR_PPRE1_DIV2;
    /* Configure the main PLL */
    RCC->PLLCFGR = PLL_M | (PLL_N << 6) | (((PLL_P >> 1) -1) << 16) |
                   (RCC_PLLCFGR_PLLSRC_HSE) | (PLL_Q << 24);
    /* Enable the main PLL */
    RCC->CR |= RCC_CR_PLLON;                //打开主PLL
    /* Wait till the main PLL is ready */                //等待
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Configure Flash prefetch, Instruction cache, Data cache and wait state */
    FLASH->ACR = FLASH_ACR_PRFTEN | FLASH_ACR_ICEN |FLASH_ACR_DCEN |FLASH_ACR_LATENCY_2WS;
    /* Select the main PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));                //清0
//        RCC->CFGR |= RCC_CFGR_SW_PLL;                //修改过的东西!!!!!!!!!!!!
        RCC->CFGR |= RCC_CFGR_SW_HSE;
    /* Wait till the main PLL is used as system clock source */        //等待HSE就绪
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SW_HSE);//修改过的东西!!!!!!!!!!
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
