测试发现STM32H7的LPTIM1的中断可以唤醒停机模式,其它几个LPTIM2-5无法唤醒,邪门
432|0
 楼主| 第8号打板工 发表于 2018-8-1 19:06 | 显示全部楼层 |阅读模式
对于LPTIM1,各种中断方式都可以唤醒停机模式,比如PWM中断,超时中断等(含软件触发和外部触发)。
而LPTIM2-LPTIM5的各种中断方式却都无法唤醒停机模式,但不做唤醒使用,也都正常,邪门了,看勘误手册也没有这种bug。
邪门,备份下这个问题吧。
停机模式下使用的LSE或者LSI为LPTIM提供时钟。
LPTIM1软件触发超时中断方式。
程序里面配置了8分频,4秒后唤醒。
LPTIM_HandleTypeDef             LptimHandle = {0};
void bsp_InitLPTIM2(void)
        GPIO_InitTypeDef   GPIO_InitStruct = {0};
        RCC_OscInitTypeDef RCC_OscInitStruct = {0};
        /* ## - 1 - Enable LPTIM clock ############################################ */
        __HAL_RCC_LPTIM1_CLK_ENABLE();
        __HAL_RCC_LPTIM2_CLK_ENABLE();
        __HAL_RCC_GPIOE_CLK_ENABLE();
        GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
        GPIO_InitStruct.Pull = GPIO_PULLUP;
        GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
        GPIO_InitStruct.Alternate = GPIO_AF1_LPTIM1;
        GPIO_InitStruct.Pin = GPIO_PIN_0;
        HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
        RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSE;
        RCC_OscInitStruct.LSEState = RCC_LSE_ON;
        RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
        if (HAL_RCC_OscConfig(&RCC_OscInitStruct)!= HAL_OK)
        Error_Handler(__FILE__, __LINE__);
        RCC_PeriphCLKInitStruct.PeriphClockSelection = RCC_PERIPHCLK_LPTIM1;
        RCC_PeriphCLKInitStruct.Lptim1ClockSelection = RCC_LPTIM1CLKSOURCE_LSE;
        HAL_RCCEx_PeriphCLKConfig(&RCC_PeriphCLKInitStruct);
        /* ### - 2 - Initialize the LPTIM peripheral ############################## */
        LptimHandle.Instance = LPTIM1;
        LptimHandle.Init.Clock.Source    = LPTIM_CLOCKSOURCE_APBCLOCK_LPOSC;
        LptimHandle.Init.Clock.Prescaler = LPTIM_PRESCALER_DIV8;
        LptimHandle.Init.CounterSource   = LPTIM_COUNTERSOURCE_INTERNAL;
        LptimHandle.Init.Trigger.Source  = LPTIM_TRIGSOURCE_SOFTWARE;
//        LptimHandle.Init.Trigger.Source     = LPTIM_TRIGSOURCE_0;
//        LptimHandle.Init.Trigger.ActiveEdge = LPTIM_ACTIVEEDGE_FALLING;
        LptimHandle.Init.OutputPolarity  = LPTIM_OUTPUTPOLARITY_HIGH;
        LptimHandle.Init.UpdateMode      = LPTIM_UPDATE_IMMEDIATE;
        LptimHandle.Init.Input1Source    = LPTIM_INPUT1SOURCE_GPIO;
        LptimHandle.Init.Input2Source    = LPTIM_INPUT2SOURCE_GPIO;
        /* Initialize LPTIM peripheral according to the passed parameters */
        if (HAL_LPTIM_Init(&LptimHandle) != HAL_OK)
        /* Enable and set LPTIM Interrupt to the highest priority */
        HAL_NVIC_SetPriority(LPTIM1_IRQn, 1, 0);
        HAL_NVIC_EnableIRQ(LPTIM1_IRQn);
        /* ### - 3 - Start counting in interrupt mode ############################# */
        if (HAL_LPTIM_TimeOut_Start_IT(&LptimHandle, 32768, 32768/2) != HAL_OK)
//        if (HAL_LPTIM_PWM_Start_IT(&LptimHandle, 32768, 32768/2) != HAL_OK)
//       Error_Handler(__FILE__, __LINE__);
        /* ### - 4 - Enter in Stop mode ########################################### */
        HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
        SystemClock_Config();
void LPTIM1_IRQHandler(void)
        HAL_LPTIM_IRQHandler(&LptimHandle);
        bsp_LedToggle(4);
