Hardware JPEG & FatFS
476|0
 楼主| 一片混沌 发表于 2018-8-4 08:06 | 显示全部楼层 |阅读模式
各位好,
想与各位请教,我现在尝试建立FatFS的方式读取SDCard中的 JPG,想以硬体解码的方式透过DMA2D显示于屏幕上。
已参考过官方例子,但似乎在某些部分有点问题(STM32CubeMX 中 JPEG_DecodingUsingFs_DMA )
以下为移植后程序,进入#8(do..while)后却无法结束void HWJPEG(void)
        FRESULT ret;
        uint32_t xPos = 0, yPos = 0;
        ret = f_mount(&SDFatFS,SDPath,0);
        if(ret != FR_OK)
                printf("Mount Failed!\r\n");
                printf("Mount Success!\r\n");
        //Cause of too quick and not get
        HAL_Delay(60);
        ret = f_open(&SDFile,IMAGE_FILE,FA_READ);
        if(ret != FR_OK)
                printf("Open Failed!\r\n");
        else
           printf("Open Success!\r\n");
        /*##-7- JPEG decoding with DMA (Not Blocking ) Method ################*/
          JPEG_Decode_DMA(&hjpeg, &SDFile, JPEG_OUTPUT_DATA_BUFFER);
          /*##-8- Wait till end of JPEG decoding and perfom Input Processing in BackGround  #*/
          do
            JpegProcessing_End = JPEG_InputHandler(&hjpeg);
          }while(JpegProcessing_End == 0);
          /*##-9- Get JPEG Info  ###############################################*/
          HAL_JPEG_GetInfo(&hjpeg, &JPEG_Info);
          /*##-10- Copy RGB decoded Data to the display FrameBuffer  ############*/
          xPos = (BSP_LCD_GetXSize() - JPEG_Info.ImageWidth)/2;
          yPos = (BSP_LCD_GetYSize() - JPEG_Info.ImageHeight)/2;
          DMA2D_CopyBuffer((uint32_t *)JPEG_OUTPUT_DATA_BUFFER, (uint32_t *)LCD_FRAME_BUFFER, xPos , yPos, JPEG_Info.ImageWidth, JPEG_Info.ImageHeight, JPEG_Info.ChromaSubsampling);
        f_close(&SDFile);
}复制代码
不知板上各位是否有此相关的经验可以给予参考呢?
感谢!!
