STM32H7的DAM2D实现YCbCr转RGB的API
782|0
 楼主| 稻花香1号 发表于 2018-8-9 18:28 | 显示全部楼层 |阅读模式
还是这种的API调用起来省事
  * @brief  DMA2D conversion from YCbCr (video output) to RGB (Display frame buffer)
  * @param  pSrc : Source buffer pointer
  * @param  xsize: Horizontal size of the frame buffer
  * @param  ysize: Vertical size of the frame buffer
  * @retval None
void DMA2D_CopyBuffer_YCbCr_To_RGB(uint32_t *pSrc, uint16_t xsize, uint16_t ysize)
  uint32_t inputLineOffset = 0;
  uint32_t destination;
  U32 BufferSize;
  U32 regValue, regMask;
  /* Wait if there is a transfer in progress */
  _DMA2D_ExecOperation();
  /* Take the TransferInProgress flag */
  TransferInProgress = 1;
  /* Get the buffer size */
  BufferSize = _GetBufferSize(0);
  /* Calculate all the needed DMA2D inputs */
  destination = _aAddr[0] + BufferSize * _aBufferIndex[0];
  inputLineOffset = xsize % 16;
  if(inputLineOffset != 0)
    inputLineOffset = 16 - inputLineOffset;
  regValue = DMA2D_INPUT_YCBCR | (DMA2D_REPLACE_ALPHA << 16) |
                        (DMA2D_REGULAR_ALPHA << 20)|
            (DMA2D_RB_REGULAR << 21)   |
            (0xFFU << 24)               |
            (DMA2D_CSS_420 << 18);
  regMask  = DMA2D_BGPFCCR_CM | DMA2D_BGPFCCR_AM | DMA2D_BGPFCCR_ALPHA | DMA2D_BGPFCCR_AI | DMA2D_BGPFCCR_RBS | DMA2D_FGPFCCR_CSS;
  /* Setup DMA2D Configuration */
  DMA2D->CR      = 0x00010000UL | (1 << 9);
  DMA2D->OPFCCR  = DMA2D_OUTPUT_RGB565;
  DMA2D->OOR     = 640 - xsize;
  DMA2D->OPFCCR  |= (DMA2D_REGULAR_ALPHA << 20);
  DMA2D->OPFCCR  |= (DMA2D_RB_REGULAR << 21);
  DMA2D->FGPFCCR |= (regMask & regValue);
  DMA2D->FGOR    = inputLineOffset;
  DMA2D->NLR     = (U32)(xsize << 16) | (U16)ysize;
  DMA2D->OMAR    = (U32)destination;
  DMA2D->FGMAR   = (U32)pSrc;
  /* Start the transfer, and enable the transfer complete IT */
  DMA2D->CR     |= (1|DMA2D_IT_TC);
  /* Wait for the end of the transfer */
