注意STM32H7的DMA中断方式启动函数HAL_DMA_Start_IT会开启多个中断,自己实现中断要注意清标志
841|0
 楼主| kaloulin 发表于 2018-8-10 08:20 | 显示全部楼层 |阅读模式
开启TC发送完成中断,TE传输错误中断,DME直接模式错误中断和FIFO错误中断
#define DMA_IT_TC                         ((uint32_t)DMA_SxCR_TCIE)
#define DMA_IT_HT                         ((uint32_t)DMA_SxCR_HTIE)
#define DMA_IT_TE                         ((uint32_t)DMA_SxCR_TEIE)
#define DMA_IT_DME                        ((uint32_t)DMA_SxCR_DMEIE)
#define DMA_IT_FE                         ((uint32_t)0x00000080U)
最后还有个HT半传输中断,这个根据用户时候注册的半传输回调函数决定。
  * @brief  Start the DMA Transfer with interrupt enabled.
  * @param  hdma:       pointer to a DMA_HandleTypeDef structure that contains
  *                     the configuration information for the specified DMA Stream.
  * @param  SrcAddress: The source memory Buffer address
  * @param  DstAddress: The destination memory Buffer address
  * @param  DataLength: The length of data to be transferred from source to destination
  * @retval HAL status
HAL_StatusTypeDef HAL_DMA_Start_IT(DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t DataLength)
  HAL_StatusTypeDef status = HAL_OK;
  /* Check the parameters */
  assert_param(IS_DMA_BUFFER_SIZE(DataLength));
  /* Check the DMA peripheral handle */
  if(hdma == NULL)
    return HAL_ERROR;
  /* Process locked */
  __HAL_LOCK(hdma);
  if(HAL_DMA_STATE_READY == hdma->State)
    /* Change DMA peripheral state */
    hdma->State = HAL_DMA_STATE_BUSY;
    /* Initialize the error code */
    hdma->ErrorCode = HAL_DMA_ERROR_NONE;
    /* Disable the peripheral */
    __HAL_DMA_DISABLE(hdma);
    /* Configure the source, destination address and the data length */
    DMA_SetConfig(hdma, SrcAddress, DstAddress, DataLength);
    if(IS_D2_DMA_INSTANCE(hdma) != RESET) /* D2 Domain DMA : DMA1 or DMA2 */
      /* Enable Common interrupts*/
      MODIFY_REG(((DMA_Stream_TypeDef   *)hdma->Instance)->CR, (DMA_IT_TC | DMA_IT_TE | DMA_IT_DME | DMA_IT_HT), (DMA_IT_TC | DMA_IT_TE | DMA_IT_DME));
      ((DMA_Stream_TypeDef   *)hdma->Instance)->FCR |= DMA_IT_FE;
      if(hdma->XferHalfCpltCallback != NULL)
        /*Enable Half Transfer IT if corresponding Callback is set*/
        ((DMA_Stream_TypeDef   *)hdma->Instance)->CR  |= DMA_IT_HT;
    else /* D3 Domain BDMA */
      MODIFY_REG(((BDMA_Channel_TypeDef   *)hdma->Instance)->CCR, (BDMA_CCR_TCIE | BDMA_CCR_HTIE | BDMA_CCR_TEIE), (BDMA_CCR_TCIE | BDMA_CCR_TEIE));
        ((BDMA_Channel_TypeDef   *)hdma->Instance)->CCR  |= BDMA_CCR_HTIE;
    /* Check if DMAMUX Synchronization is enabled*/
    if((hdma->DMAmuxChannel->CCR & DMAMUX_CxCR_SE) != 0U)
      /* Enable DMAMUX sync overrun IT*/
      hdma->DMAmuxChannel->CCR |= DMAMUX_CxCR_SOIE;
    if(hdma->DMAmuxRequestGen != 0U)
      /* if using DMAMUX request generator, enable the DMAMUX request generator overrun IT*/
      /* enable the request gen overrun IT*/
      hdma->DMAmuxRequestGen->RGCR |= DMAMUX_RGxCR_OIE;
    /* Enable the Peripheral */
    __HAL_DMA_ENABLE(hdma);
  else
    /* Process unlocked */
    __HAL_UNLOCK(hdma);
    /* Set the error code to busy */
    hdma->ErrorCode = HAL_DMA_ERROR_BUSY;
    /* Return error status */
    status = HAL_ERROR;
  return status;
