STM32H7使用函数SCB_InvalidateDCache_by_Addr,SCB_CleanDCache_by_Addr等函数注意事项
2932|0
 楼主| 第8号打板工 发表于 2018-8-10 11:26 | 显示全部楼层 |阅读模式
特别注意下面这三个函数的形参addr和dsize:
addr : 操作的地址一定要是32字节对齐的。
dsize :一定要是32字节的整数倍
  rief   D-Cache Invalidate by address
  details Invalidates D-Cache for the given address
  param[in]   addr    address (aligned to 32-byte boundary)
  param[in]   dsize   size of memory block (in number of bytes)
__STATIC_INLINE void SCB_InvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize)
  #if defined (__DCACHE_PRESENT) && (__DCACHE_PRESENT == 1U)
     int32_t op_size = dsize;
    uint32_t op_addr = (uint32_t)addr;
     int32_t linesize = 32;                /* in Cortex-M7 size of cache line is fixed to 8 words (32 bytes) */
    __DSB();
    while (op_size > 0) {
      SCB->DCIMVAC = op_addr;
      op_addr += (uint32_t)linesize;
      op_size -=           linesize;
    __DSB();
    __ISB();
  #endif
  rief   D-Cache Clean by address
  details Cleans D-Cache for the given address
__STATIC_INLINE void SCB_CleanDCache_by_Addr (uint32_t *addr, int32_t dsize)
    uint32_t op_addr = (uint32_t) addr;
    __DSB();
      SCB->DCCMVAC = op_addr;
    __DSB();
    __ISB();
  #endif
  rief   D-Cache Clean and Invalidate by address
  details Cleans and invalidates D_Cache for the given address
__STATIC_INLINE void SCB_CleanInvalidateDCache_by_Addr (uint32_t *addr, int32_t dsize)
    __DSB();
      SCB->DCCIMVAC = op_addr;
    __DSB();
    __ISB();
  #endif
