ID Err 0x0000000a!
268|0
 楼主| 小蘭 发表于 2018-9-1 09:26 | 显示全部楼层 |阅读模式
se, TI, AD, fm, TE
烧写OK6410开发板(1GNandFlash)时可以烧写成功,但是启动时出现错误为ID Err 0x0000000a!,无法进入到界面,请问是什么原因?
输出调试信息为:
Welcome! This tool just for TE/OK6410
+OALArgsInit()
SocID:0x36410101
Arguments area is initialized
-OALArgsInit()
INFO: (unsigned)C_IsrHandler : 0x8008095C
INFO: (unsigned)ASM_IsrHandler : 0x80084018
INFO: (unsigned)pISR : 0xEA020FFE
HSMMC init
[HSMMC1] Setting registers for the EPLL (for SDCLK) : SYSCon.
[HSMMC0] Setting registers for the GPIO.
[HSMMC1] Setting registers for the EPLL : HSMMCCon.
#### this SD card is made on SPEC 2.0
This SD card is made on SPEC 2.0
This SD card is High Capacity
CardSize: 31260672 sector
[HSMMCLIB:INF] ClockConfig() Card Working Frequency = 24MHz
BP_Init
[FMD] ++FMD_Init() ****
[FMD:INF] FMD_Init() : Read ID = 0x00002c38
[FMD] FMD_Init() : NUM_OF_BLOCKS = 1024
[FMD] FMD_Init() : PAGES_PER_BLOCK = 128
[FMD] FMD_Init() : SECTORS_PER_PAGE = 8
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 1024(0x400), SECTORSPERBLOCK = 128(0x80), BYTESPERSECTOR = 4096(0x1000)
wNUM_BLOCKS : 1024(0x400)
[Eboot] ++InitializeDisplay()
[Eboot] --InitializeDisplay()
Press [ENTER] to launch image stored on boot media, or [SPACE] to enter boot monitor.
Initiating image launch in 0 seconds.
Starting auto-download ...
Erase  the block '0..3'
System ready!
Preparing for download...
IsCardInserted
f_mount return = 0x0
FileInfo.fsize = 0x2000
g_pDownPt = 0xA300211B
BL_IMAGE_TYPE_MANIFEST
BL_IMAGE_TYPE_UNKNOWN
Download BIN file information:
[0]: Base Address=0x0  Length=0x2000
Stepldr image
ImageStart = 0x0, ImageLength = 0x2000, LaunchAddr = 0x0
Completed file(s):
[0]: Address=0x0  Length=0x2000  Name="stepldr.nb0" Target=RAM
BP_Init  iSighForSlcMlc = 1
[FMD] --FMD_Init()
[FMD] FMD_GetInfo() : NUMBLOCKS = 8192(0x2000), SECTORSPERBLOCK = 8(0x8), BYTESPERSECTOR = 2048(0x800)
dwImageLength = 0x2000
dwNumBlocks = 0x1
dwBlock(0x0) X g_FlashInfo.wSectorsPerBlock(0x8) = 0x0
dwBytesPerBlock : 16384
INFO: Step loader image stored to Smart Media.  Please Reboot.  Halting...
IsCardInserted
FileInfo.fsize = 0x5DEF7
g_pDownPt = 0xA305DEF7
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80030000  Length=0x5fa24
Eboot image
rom_offset=0x0.
ImageStart = 0x80030000, ImageLength = 0x5FA24, LaunchAddr = 0x80083850
Completed file(s):
[0]: Address=0x80030000  Length=0x5FA24  Name="" Target=RAM
ROMHDR at Address 80030044h
BP_Init  iSighForSlcMlc = 0
[FMD] --FMD_Init()
dwImageLength = 0x5fa24
dwNumBlocks = 0x1
dwBlock(0x2) X g_FlashInfo.wSectorsPerBlock(0x80) = 0x100
dwBytesPerBlock : 524288
TOC {
dwSignature: 0x434F544E
BootCfg {
  ConfigFlags: 0x20830
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  MAC Address: 00:00:00:00:00:00
  Port: 0.0.0.0
  SubnetMask: 255.255.255.0
ID[0] {
  dwVersion: 0x20004
  dwSignature: 0x45424F54
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x60
  dwLoadAddress: 0x80030000
  dwJumpAddress: 0x80083850
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x100
  sgList[0].dwLength: 0x60
ID[1] {
  dwVersion: 0x1
  dwSignature: 0x43465348
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x11D9
  dwLoadAddress: 0x80150000
  dwJumpAddress: 0x80157734
  dwStoreOffset: 0x0
  sgList[0].dwSector: 0x380
  sgList[0].dwLength: 0x11D9
chainInfo.dwLoadAddress: 0X00000000
chainInfo.dwFlashAddress: 0X00000000
chainInfo.dwLength: 0X00000000
INFO: Eboot image stored to Smart Media.  Please Reboot.  Halting...
Reserving Blocks [0x0 - 0x2] ...
...reserve complete.
Enter LowLevelFormat [0x3, 0x3ff].
WriteMBR: MBR block = 0x3.
Done.
BinFS format done.
IsCardInserted
FileInfo.fsize = 0x1187163
g_pDownPt = 0xA4187163
BL_IMAGE_TYPE_BIN
[0]: Base Address=0x80150000  Length=0x11dab90
RAM image
rom_offset=0x0.
ImageStart = 0x80150000, ImageLength = 0x11DAB90, LaunchAddr = 0x80157734
Completed file(s):
[0]: Address=0x80150000  Length=0x11DAB90  Name="" Target=RAM
ROMHDR at Address 80150044h
+WriteOSImageToBootMedia: g_dwTocEntry =1, ImageStart: 0x80150000, ImageLength: 0x11dab90, LaunchAddr:0x80157734
INFO: OEMLaunch: Found chain extenstion: '' @ 0x80150000
Writing single region/multi-region update, dwBINFSPartLength: 18721680
IsValidMBR: block = 0x0.
IsValidMBR: block = 0x1.
IsValidMBR: block = 0x2.
IsValidMBR: MBR sector = 0x180 (valid MBR)
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0x1fdff.
CreatePartition: Start = 0x200, Num = 0x1200.
Log2Phys: Logical 0x200 -> Physical 0x380
BP_SetDataPointer at 0x0
Write OS to Nand Flash finished!!!
Updated TOC!
OpenPartition: Partition Exists=0x0 for part 0xb.
CreatePartition: Enter CreatePartition for 0xb.
FindFreeSector: FreeSector is: 0x1400 after processing part 0x21.
CreatePartition: Num sectors set to 0x1e900 to allow for compaction blocks.
CreatePartition: Start = 0x1400, Num = 0x1e900.
TOC {
BootCfg {
  BootDelay: 0x2
  ImageIndex: 1
  IP: 0.0.0.0
  Port: 0.0.0.0
ID[0] {
  dwVersion: 0x20004
  String: 'eboot.nb0'
  dwImageType: 0x2
  dwTtlSectors: 0x60
  dwStoreOffset: 0x0
ID[1] {
  dwVersion: 0x1
  String: ''
  dwImageType: 0x2
  dwTtlSectors: 0x11DB
  dwStoreOffset: 0x0
  sgList[0].dwLength: 0x11DB
waitforconnect
INFO: using TOC[1] dwJumpAddress: 0x80157734
Success!
SpinForever...
000000 0 僷噋ppppp<p8p8饃<饃<饃x<痧**<<<<>>>><<||x痧痧痧痧痧痧痧囵疣噜疣噜噜噜噜噜噜噜噜噜噜噜噜囵痧痧痧痧痧痧痧痧痧痧痧痧痧痧痧痧痧瘌
WinCE 6.0 Steploader for SMDK6410
ID Err
0x0000000a
Launch Eboot...
