关于V8指令集运行请教?
240|0
 楼主| 向日葵的武士 发表于 2018-9-11 08:44 | 显示全部楼层 |阅读模式
本人在A72上做一个数组累加:
s += a,测试的时候数组a是一个10KB的数组,循环100000次,保证整个过程的数据都是l1cache上,排除cachemiss的可能。
发现效率怎么都达不到最优,按理说这个数组每4个值需要一个LD1指令和一个ADD指令,按照F0/F1和L/S四个单元并行原则,理论上是1个cycle就可以搞定了,但实际上需要1.7cycle。
具体实现如下:
            "2:\\n"\n            "subs        x1    , x1,    #1\\n"\n            "ld1 {v8.4s},[x0],#16\\n"\n            "ld1 {v9.4s},[x0],#16\\n"\n            "ld1 {v10.4s},[x0],#16\\n"\n            "ld1 {v11.4s},[x0],#16\\n"\n            "ld1 {v12.4s},[x0],#16\\n"\n            "ld1 {v13.4s},[x0],#16\\n"\n            "add  v0.4s,v0.4s,v8.4s\\n"\n            "ld1 {v14.4s},[x0],#16\\n"\n            "add  v1.4s,v1.4s,v9.4s\\n"\n            "ld1 {v15.4s},[x0],#16\\n"\n            "add  v2.4s,v2.4s,v10.4s\\n"                \n            "ld1 {v16.4s},[x0],#16\\n"\n            "add  v3.4s,v3.4s,v11.4s\\n"\n            "ld1 {v17.4s},[x0],#16\\n"\n            "add  v4.4s,v4.4s,v12.4s\\n"\n            "ld1 {v18.4s},[x0],#16\\n"\n            "add  v5.4s,v5.4s,v13.4s\\n"\n            "ld1 {v19.4s},[x0],#16\\n"\n            "add  v6.4s,v6.4s,v14.4s\\n"\n            "ld1 {v20.4s},[x0],#16\\n"\n            "add  v7.4s,v7.4s,v15.4s\\n"\n            "ld1 {v21.4s},[x0],#16\\n"\n            "add  v24.4s,v24.4s,v16.4s\\n"\n            "ld1 {v22.4s},[x0],#16\\n"\n            "add  v25.4s,v25.4s,v17.4s\\n"\n            "ld1 {v23.4s},[x0],#16\\n"\n            "add  v26.4s,v26.4s,v18.4s\\n"\n            "add  v27.4s,v27.4s,v19.4s\\n"\n            "add  v28.4s,v28.4s,v20.4s\\n"\n            "add  v29.4s,v29.4s,v21.4s\\n"\n            "add  v30.4s,v30.4s,v22.4s\\n"\n            "add  v31.4s,v31.4s,v23.4s\\n"\n            "bne        2b\\n"\n            \n            第二种:
                "2:\\n"\n                "subs        x1    , x1,    #1\\n"\n                "ld1 { v8.4s},[x0],#16\\n"\n                "ld1 { v9.4s},[x0],#16\\n"\n                "ld1 {v10.4s},[x0],#16\\n"\n                "ld1 {v11.4s},[x0],#16\\n"\n                "ld1 {v12.4s},[x0],#16\\n"\n                "ld1 {v13.4s},[x0],#16\\n"    \n                "ld1 {v14.4s},[x0],#16\\n"\n                "ld1 {v15.4s},[x0],#16\\n"\n                 "add  v0.4s,v0.4s, v8.4s\\n"\n                "add  v1.4s,v1.4s, v9.4s\\n"\n                "add  v2.4s,v2.4s,v10.4s\\n"\n                "add  v3.4s,v3.4s,v11.4s\\n"\n                "add  v4.4s,v4.4s,v12.4s\\n"\n                "add  v5.4s,v5.4s,v13.4s\\n"\n                "add  v6.4s,v6.4s,v14.4s\\n"\n                "add  v7.4s,v7.4s,v15.4s\\n"\n                "bne        2b\\n"这两种的效率都是1.7cycle。
求解无法达到理论值的原因
