[技术问答] spi-flash对有数据为0x00的数组,把数据0x00覆盖后,flash还是显示0x00
1258|4
 楼主| xukng 发表于 2020-9-5 15:22 | 显示全部楼层 |阅读模式
#define OK 1
#define FAULSE 0
  bit flagFrame = 0;
  bit flagTxd = 0;
  unsigned char cntRxd = 0;
  unsigned char a[32]={0};
  unsigned char t1buf[250];
  unsigned char sbuf[250];
  UINT8  rbuf[25];
  UINT8  T2buf[25];
  UINT8 Tbuf[25];
  UINT8 R1buf[32];
  extern void SPI_Initial(void);
  extern void W25QXX_Erase_Sector(UINT32 Dst_Addr);
  extern void Flash_Program(UINT8* pBuffer,UINT32 WriteAddr,UINT16 NumByteToWrite);
  extern void Flash_Read(UINT8* pBuffer,UINT32 ReadAddr,UINT16 NumByteToRead);
  extern void SPI_Flash_Write_NoCheck(UINT8* pBuffer,UINT32 ReadAddr,UINT16 Len);
   UINT8 SearchIDNum(UINT8 *buf,UINT8 *rbuf,UINT16 len);
   void delay500ms(void)
  unsigned char i,j,k;
  for(i=15;i>0;i--)     //??????????
  for(j=202;j>0;j--)    //??????????
  for(k=81;k>0;k--);    //???????з??
  /////////////////??????0??63??????????//////////////////////////
   void InitSector()
         UINT32 sector;
       for(sector=0;sector<64;sector++)
                    W25QXX_Erase_Sector(sector*4096);
//////////////////?????????????????0??????????15?////////////////
  void PrintSector(UINT8 sector)
     //UINT8 sector;
           UINT8 page;
           UINT8 ab[2];
                 for(page=0;page<16;page++)
                  {            ab[0]=sector;
                        ab[1]=page;
                           UartWrite(ab,2);
                     Flash_Read(sbuf,sector*4096+page*256,250);
                         UartWrite(sbuf,250);
                         if(page==15)
                           Timer2_Delay(24000000,128,1000,1000);
  ////////////////////////////?洢????///////////////////////////////
  //////////////////////?п?????棬??????0x00/////////////////
   UINT8 storedata(UINT8 *buf,UINT8 *rbuf,UINT16 len)
          UINT32 sector;
          UINT8 i,page;
          //bit flag=1;
          //sector = buf[8]%64;
                 for(i=0;i<10;)
                          Flash_Read(rbuf,sector*4096+page*256+25*i,len);
                          if((rbuf[5]!=0xff)&&(rbuf[6]!=0xff)&&(rbuf[7]!=0xff)&&(rbuf[8]!=0xff))
                       i++;
                      if((rbuf[5]==0xff)&&(rbuf[6]==0xff)&&(rbuf[7]==0xff)&&(rbuf[8]==0xff))
                           {Flash_Program(buf,sector*4096+page*256+25*i,len);
                                 return OK;}
               UART_Send_Data(UART0,0x00);
                   return FAULSE;
  ////////////???????ж?????///////////////////////////////
  ////////////?????????1???????????0??//////////////////
      UINT32 sector;
          UINT8 i,page;
          //sector = buf[9]%64;
                 for(i=0;i<10;i++)
                          if((rbuf[5]!=buf[5])&&(rbuf[6]!=buf[6])&&(rbuf[7]!=buf[7])&&(rbuf[8]!=buf[8]))
                       {continue;}
                      if((rbuf[5]==buf[5])&&(rbuf[6]==buf[6])&&(rbuf[7]==buf[7])&&(rbuf[8]==buf[8]))
                           {UART_Send_Data(UART0,0x01);return OK; }
                           return FAULSE;
  //////////////////???SPI??flash???????к????????????????????λд0x00//////////
  UINT8 DeleteNum(UINT8 *buf,UINT8 *rbuf,UINT16 len)
      UINT32 sector;
          UINT8 i,page,j;
          //UINT8 i,j,m,k,page1,page2;
                 for(i=0;i<10;i++)
                       {continue;}
                                           for(j=0;j<25;j++)
                               buf[j]=0x00;
                                   return OK;
                           return FAULSE;
////////////////////////////???0x00??????????λ?????????64????????/////
///////////////////////////?????0x00????????????????64????????????0x00???//
////////////////////////// ????????????????????????????????????64??????????
UINT8 ModifyNum(UINT8 *buf,UINT8 *rbuf,UINT16 len)
      bit flag=1;
      UINT32 sector;
          //UINT8 ab[2];
           for(page1=0;page1<16;page1++)
                for(i=0;i<10;i++)
                          Flash_Read(rbuf,sector*4096+page1*256+25*i,len);
                          if((rbuf[5]!=0x00)&&(rbuf[6]!=0x00)&&(rbuf[7]!=0x00)&&(rbuf[8]!=0x00))
                       {continue;}
                      if((rbuf[5]==0x00)&&(rbuf[6]==0x00)&&(rbuf[7]==0x00)&&(rbuf[8]==0x00))
                                    //W25QXX_Erase_Sector(64*4096);
        k=i;
                                 for(page2=0;page2<16;page2++)
                                         Flash_Read(sbuf,sector*4096+page2*256,250);
                                              Flash_Program(sbuf,64*4096+page2*256,250);
                                        if(page2==page1)
                                          for(m=0;m<10;m++)
                                           for(j=0;j<25;j++)
                                               //if(m<k)
                                                //        t1buf[m*25+j] = sbuf[m*25+j];
                                                   if((m>=k)&&(m<9))
                                                    sbuf[m*25+j] = sbuf[(m+1)*25+j];
                                                   if(m==9)
                                                         sbuf[m*25+j] = buf[j];
                                                  //delay500ms();
                                                  // PrintSector(64);
                                                        delay500ms();
                                          /*W25QXX_Erase_Sector(sector*4096);
                                          delay500ms();
                                           Flash_Read(sbuf,64*4096+page2*256,250);
                                           Flash_Program(sbuf,sector*4096+page2*256,250);
                                       return OK;
                           return FAULSE;
void main()
                 UINT8 i=0,j=0,k=0,m=0;
            MFP_P30_UART0_RXD;
                    P30_QUASI_MODE;
                   MFP_P31_UART0_TXD;
                   P31_QUASI_MODE;
                    MFP_P00_SPI0_MOSI;
                   P00_QUASI_MODE;
                   MFP_P01_SPI0_MISO;
                   P01_QUASI_MODE;
                   MFP_P02_SPI0_CLK;
                   P02_QUASI_MODE;
                   MFP_P03_SPI0_SS;
                   P03_QUASI_MODE;
                   SPI_Initial();
                   UART_Open(24000000,UART0_Timer1,115200);
                   UART_Interrupt_Enable(UART0,Enable);
                   //Timer_Interrupt_Enable(TIMER2);
               ENABLE_GLOBAL_INTERRUPT;
                   Timer0_Delay(24000000,1,1000);
                   //flash_Chip_Erase();
                                    // delay500ms();
                           InitSector();
                  //UINT8 storedata(Tbuf,rbuf,25);//
                 //Flash_Read(Rbuf,0x000000,32);   //??N????
           while(i<10)
                if(flagFrame)
                  flagFrame = 0;
                  UartRead(Tbuf,R1buf,32);
                           //delay500ms();
                  //UartRead(T2buf,R1buf,32);
                 //SearchIDNum(T2buf,rbuf,25);
                 //UartWrite(Tbuf,25);
                  i++;
                // UartWrite(Tbuf,25);
            //PrintSector(0);
                        //while(1);
           while(j<1)
                   if(flagFrame)
                         flagFrame = 0;
                   j++;
                 j=0;
                    //PrintSector();
                 while(k<1)
                    if(flagFrame)
                         flagFrame = 0;
                   DeleteNum(T2buf,rbuf,25);
                   k++;
                 PrintSector(0);
                 while(m<1)
                         if(flagFrame)
                         flagFrame = 0;
                         ModifyNum(T2buf,rbuf,25);
                          m++;
        PrintSector(64);
天灵灵地灵灵 发表于 2020-9-5 20:06 | 显示全部楼层
听起来没毛病啊。
 楼主| xukng 发表于 2020-9-6 10:26 | 显示全部楼层
是这样的,我存了一些数据在flash里,然后将其中有些数据改为0x00,然后再保存在临时数组中,在数组中去除是0的数据,就是将其覆盖,然后再写回到新的扇区中去,结果为0的数据依然存在
chenjun89 发表于 2020-9-6 16:25 来自手机 | 显示全部楼层
楼主你回复一楼的也没毛病,如果是这样的话肯定还是0啊!
为0的数据不是被我覆盖了吗,为啥传进flash里面还会出现0  发表于 2020-9-8 08:38
