[STM32F4] timer输入捕获测频率偶尔会得到真实值的一半
2570|9
 楼主| tvrgt 发表于 2020-9-5 19:50 | 显示全部楼层 |阅读模式
用了定时器的输入捕获功能来测得频率,有两个中断,一个是上升沿信号中断,一个是计数器溢出中断,我现在不懂那个500 是咋回事,测着测着突然出来这么一个,每次都是实际值的一半
代码,上升沿中断和溢出中断, 第一次溢出后开始取数,用上这次上升沿的数值减去一次上升沿的数值得出信号源频率值,但是偶尔会出现捕获值翻倍,好像漏掉了一次上升沿一样,我开启了 溢出判断也并没有进入贴一下中断服务函数
void TIMER2_IRQHandler(void)
           if(SET == timer_interrupt_flag_get(TIMER2,TIMER_INT_UP))
                         timer_interrupt_flag_clear(TIMER2,TIMER_INT_UP);
                         timer2_counter_overflow++;
       timer2_interrupt_clear();
                         update_flag++;
                  if(timer2_counter_overflow==2)
                         timer2_interrupt_disable(); //double time capture,????????g???????2.????????
                   timer_disable(TIMER2);
                         timer2_counter_overflow=0;
    if(SET == timer_interrupt_flag_get(TIMER2,TIMER_INT_CH0))
        /* clear channel 0 interrupt bit */
        timer_interrupt_flag_clear(TIMER2,TIMER_INT_CH0);
/* !!!!!!!!!! */interrupt_flag1++; /* !!!!!!!!!!!!!! */
            /* read channel 0 capture value */
                        if((timer2_counter_overflow==1) && (RESET == timer_flag_get(TIMER2,TIMER_INTF_CH0OF)))//wu yi chu
        if(0 == ccnumber0)
        CH0_CAPTURE_OLD = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_0)+1;
         ccnumber0 = 1;
        else if(1 == ccnumber0)
        CH0_CAPTURE_NEW = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_0)+1;
        if(CH0_CAPTURE_NEW > CH0_CAPTURE_OLD)
        ic1value = CH0_CAPTURE_NEW - CH0_CAPTURE_OLD;
        else{
                                                ic1value = ((0xFFFF - CH0_CAPTURE_OLD) + CH0_CAPTURE_NEW);
                                                fre_highcapture_1= 10000000/ ic1value;
/* !!!!!!!!!! */fre_highcapture_1_OLD=fre_highcapture_1;
            if(fre_highcapture_1<9980)
/* !!!!!!!!!! */int_CH0_flag=1;  /* !!!!!!!!!!!!!!!!! */
            if(fre_highcapture_1>10012)
              int_CH0_flag=1;
              ccnumber0 = 0;
                  if((timer2_counter_overflow==1) &&(SET == timer_flag_get(TIMER2,TIMER_INTF_CH0OF)))//you yi chu
                          timer_flag_clear(TIMER2,TIMER_INTF_CH0OF);
/* !!!!!!!!!! */fre_highcapture_1=fre_highcapture_1_OLD;
/* !!!!!!!!!! */timer2_interrupt_disable();  /* !!!!!!!!!! */
/* !!!!!!!!!! */timer_disable(TIMER2);       /* !!!!!!!!!!!!!!! */
                          int_CH0_flag=1;
                           ccnumber0 = 0;
    if(SET == timer_interrupt_flag_get(TIMER2,TIMER_INT_CH1))
        timer_interrupt_flag_clear(TIMER2,TIMER_INT_CH1);
/* !!!!!!!!!! */ interrupt_flag2++; /* !!!!!!!!!!!! */
                        if((timer2_counter_overflow==1) && (RESET == timer_flag_get(TIMER2,TIMER_INTF_CH1OF)))
        if(0 == ccnumber1)
        CH1_CAPTURE_OLD = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_1)+1;
         ccnumber1 = 1;
        else if(1 == ccnumber1)
         CH1_CAPTURE_NEW = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_1)+1;
         if(CH1_CAPTURE_NEW > CH1_CAPTURE_OLD)
                        ic2value = CH1_CAPTURE_NEW - CH1_CAPTURE_OLD;
       else{
          ic2value = ((0xFFFF - CH1_CAPTURE_OLD) + CH1_CAPTURE_NEW);
            fre_highcapture_2= 10000000/ ic2value;
/* !!!!!!!!!! */fre_highcapture_2_OLD=fre_highcapture_2;
            if(fre_highcapture_2<9980)
/* !!!!!!!!!! */int_CH1_flag=1;  /* !!!!!!!!!!!!!!!!! */
            if(fre_highcapture_2>10012)
            int_CH1_flag=1;
            ccnumber1 = 0;
                   if((timer2_counter_overflow==1) &&(SET == timer_flag_get(TIMER2,TIMER_INTF_CH1OF)))
                    timer_flag_clear(TIMER2,TIMER_INTF_CH1OF);
                    fre_highcapture_2=fre_highcapture_2_OLD;
                    int_CH1_flag=1;
                     ccnumber1 = 0;
    if(SET == timer_interrupt_flag_get(TIMER2,TIMER_INT_CH2))
     timer_interrupt_flag_clear(TIMER2,TIMER_INT_CH2);
/* !!!!!!!!!! */ interrupt_flag3++;/* !!!!!!!!!! */
                        if((timer2_counter_overflow==1) && (RESET == timer_flag_get(TIMER2,TIMER_INTF_CH2OF)))
        if(0 == ccnumber2)
        CH2_CAPTURE_OLD = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_2)+1;
         ccnumber2 = 1;
        else if(1 == ccnumber2)
         CH2_CAPTURE_NEW = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_2)+1;
         if(CH2_CAPTURE_NEW > CH2_CAPTURE_OLD)
                      ic3value = CH2_CAPTURE_NEW - CH2_CAPTURE_OLD;
                     else
                            ic3value = ((0xFFFF - CH2_CAPTURE_OLD) + CH2_CAPTURE_NEW);
                                fre_highcapture_3= 10000000/ ic3value;
                                if(fre_highcapture_3<9980)
/* !!!!!!!!!! */int_CH2_flag=1;  /* !!!!!!!!!!!!!!!!! */
                                if(fre_highcapture_3>10012)
                                int_CH2_flag=1;
                                ccnumber2 = 0;
                if((timer2_counter_overflow==1) && (SET == timer_flag_get(TIMER2,TIMER_INTF_CH2OF)))
                        timer_flag_clear(TIMER2,TIMER_INTF_CH2OF);
/* !!!!!!!!!! */fre_highcapture_3=fre_highcapture_3_OLD;
                        int_CH2_flag=1;
                        ccnumber2 = 0;
    if(SET == timer_interrupt_flag_get(TIMER2,TIMER_INT_CH3))
        timer_interrupt_flag_clear(TIMER2,TIMER_INT_CH3);
/* !!!!!!!!!! */interrupt_flag4++;/* !!!!!!!!!! */
                        if((timer2_counter_overflow==1) && (RESET == timer_flag_get(TIMER2,TIMER_INTF_CH3OF)))
        if(0 == ccnumber3)
         CH3_CAPTURE_OLD = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_3)+1;
         ccnumber3 = 1;
        else if(1 == ccnumber3)
         CH3_CAPTURE_NEW = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_3)+1;
         if(CH3_CAPTURE_NEW > CH3_CAPTURE_OLD)
                        ic4value = CH3_CAPTURE_NEW - CH3_CAPTURE_OLD;
        else{
            ic4value = ((0xFFFF - CH3_CAPTURE_OLD) + CH3_CAPTURE_NEW);
          fre_highcapture_4 = 10000000/ ic4value;
/* !!!!!!!!!! */fre_highcapture_4_OLD=fre_highcapture_4;
            if(fre_highcapture_4<9980)
/* !!!!!!!!!! */int_CH3_flag=1;  /* !!!!!!!!!!!!!!!!! */
            if(fre_highcapture_4>10012)
            int_CH3_flag=1;
            ccnumber3 = 0;
                 if((timer2_counter_overflow==1) && (SET == timer_flag_get(TIMER2,TIMER_INTF_CH3OF)))
                        timer_flag_clear(TIMER2,TIMER_INTF_CH3OF);
/* !!!!!!!!!! */fre_highcapture_4=fre_highcapture_4_OLD;/* !!!!!!!!!! */
                        int_CH3_flag=1;
                        ccnumber3 = 0;
 楼主| tvrgt 发表于 2020-9-6 15:31 | 显示全部楼层
香水城 发表于 2020-9-6 14:26
假定待测信号周期短于定时器计数周期。 你应该测量两次上沿捕捉事件或两次下沿捕捉事件才合理啊。
这个没有问题,问题是出现漏掉一次中间捕获值,或者说是没有捕获到
香水城 发表于 2020-9-7 10:03 | 显示全部楼层
硬件捕捉是不会丢的,除非你软件处理上出了问题,比方代码处理过程漏掉了1次捕捉。
代码精简点,尤其被捕捉信号频率较高时。
 楼主| tvrgt 发表于 2020-9-7 14:30 | 显示全部楼层
代码精简点,尤其被捕 ...
我设了捕获溢出标志查询,并未发生漏掉的情况
按您说的精简处理时间,那也只是会降低出错的机率而不能完全消除吧
香水城 发表于 2020-9-8 10:15 | 显示全部楼层
按您说的精简处理时间,那也只是会降低出错的机率而不能完 ...
你如果确认没有漏掉溢出,那就可能是你信号本身或代码处理方面的问题。
精简处理时间不能停留在简单降低出错机会,要保证不能出错,尤其代码处理上。如果不能保证,那么
这个测法就用不了,得另想办法。
不知你现在的被测信号频率是多少,我之前用F411做过输入信号的周期和占空比的测试,
当时5个us以上是没问题的。【代码应该还有一定优化空间】
我是使用PWM输入的方法 或单通道上下沿翻转方法都验证过的。
chengxiaoke 发表于 2021-7-23 16:33 | 显示全部楼层
楼主这个问题解决了吗?我也想要一段输入捕获历程,能否发我邮箱里,2290085314@qq.COM,谢谢楼主大大
乖了去 发表于 2022-5-31 22:03 | 显示全部楼层
GD32定时器输入捕获有bug
sadicy 发表于 2022-6-1 20:15 | 显示全部楼层
感觉是软件问题,查代码吧
通讯不上 发表于 2024-2-21 08:58 | 显示全部楼层
楼主解决了吗,我现在也碰到了同样的问题。目前已经排除了信号的问题,因为我用pwm模式去采频率的话是没有这个问题的
