应广单片机测温(粗暴)
461|0
 楼主| 34af9uc 发表于 2020-10-7 21:01 | 显示全部楼层 |阅读模式
#include        "extern.h"
#define                bit0                0x01
ad_1                bit                        pa.0;
void                adc();
void                wendu();
word                ad_1_a1;
word                wendu_a1;
byte                wendu_a2;
void        FPPA0 (void)
//.ADJUST_IC        SYSCLK=IHRC/4, IHRC=16MHz, VDD=5V, Bandgap=On;
.ADJUST_IC        SYSCLK=IHRC/4, IHRC=16MHz, VDD=5V;
/**************************************************/        //ad配置
$                ad_1                in;
$                padier                =~bit0;                //只写寄存器
$                adcc                enable,pa0;
$                adcm                12bit,/8;
$                adcrgc                vdd;
.delay                4*400;                //400us
ad_start                =1;
while(!ad_done)        {};
ad_1_a1$1                =adcrh;
ad_1_a1$0                =adcrl;
ad_1_a1                        >>=4;
while (1)
adc();
wendu_a1                =ad_1_a1;
wendu();
void                adc()
ad_start                =1;
while(!ad_done)        {};
ad_1_a1$1                =adcrh;
ad_1_a1$0                =adcrl;
ad_1_a1                        >>=4;
ad_1_a1                        =~ad_1_a1;                //取反变增长
void                wendu()
if(wendu_a1>62000)                //减基数
        wendu_a1                -=62000;
if(wendu_a1        >1444        ){wendu_a2        =40;return;}
if(wendu_a1        >1412        ){wendu_a2        =39;return;}
if(wendu_a1        >1360        ){wendu_a2        =38;return;}
if(wendu_a1        >1320        ){wendu_a2        =37;return;}
if(wendu_a1        >1281        ){wendu_a2        =36;return;}
if(wendu_a1        >1244        ){wendu_a2        =35;return;}
if(wendu_a1        >1211        ){wendu_a2        =34;return;}
if(wendu_a1        >1171        ){wendu_a2        =33;return;}
if(wendu_a1        >1131        ){wendu_a2        =32;return;}
if(wendu_a1        >1090        ){wendu_a2        =31;return;}
if(wendu_a1        >1051        ){wendu_a2        =30;return;}
if(wendu_a1        >1016        ){wendu_a2        =29;return;}
if(wendu_a1        >988        ){wendu_a2        =28;return;}
if(wendu_a1        >947        ){wendu_a2        =27;return;}
if(wendu_a1        >902        ){wendu_a2        =26;return;}
if(wendu_a1        >864        ){wendu_a2        =25;return;}
if(wendu_a1        >830        ){wendu_a2        =24;return;}
if(wendu_a1        >786        ){wendu_a2        =23;return;}
if(wendu_a1        >756        ){wendu_a2        =22;return;}
319
