edgex modbus设备部署和测试
658|3
keer_zu|  楼主 | 2020-10-26 14:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
keer_zu|  楼主 | 2020-10-26 15:18 | 只看该作者
1. 首先登录控制台edgex-ui-go页面,导入device profile文件,和mqtt导入相同。文件名为modbus.device.profile.yml。内容如下:
name: "Network Power Meter"
manufacturer: "Dent Instruments"
model: "PS3037"
description: "Power Scout Meter"
labels:
  - "modbus"
  - "powerscout"
deviceResources:
    description: "Average current of all phases"
    attributes:
      { primaryTable: "HOLDING_REGISTERS", startingAddress: "9" }
    properties:
      value:
        { type: "UINT16", scale: "1"}
      units:
        { type: "String", readWrite: "R", defaultValue: "min"}
    description: "System Total True Energy"
    attributes:
      { primaryTable: "HOLDING_REGISTERS", startingAddress: "4001" }
    properties:
      value:
        { type: "FLOAT32", scale: "1"}
      units:
    description: "System Total True Power "
    attributes:
      { primaryTable: "HOLDING_REGISTERS", startingAddress: "4003" }
    properties:
      value:
      units:
    description: "Voltage Line to line (Volts) Average"
    attributes:
      { primaryTable: "HOLDING_REGISTERS", startingAddress: "4017" }
    properties:
      value:
      units:
    description: "Demand window size in minutes; default is 15 min"
    attributes:
      { primaryTable: "HOLDING_REGISTERS", startingAddress: "4603" }
    properties:
      value:
        { type: "UINT16", readWrite: "R", scale: "1"}
      units:
    description: "Line frequency setting for metering: 50=50 Hz, 60=60Hz"
    attributes:
      { primaryTable: "HOLDING_REGISTERS", startingAddress: "4609" }
    properties:
      value:
      units:
        { type: "String", readWrite: "R", defaultValue: "Hz"}
deviceCommands:
    get:
      - { index: "1", operation: "get", deviceResource: "Current" }
    get:
      - { index: "1", operation: "get", deviceResource: "Energy" }
      - { index: "2", operation: "get", deviceResource: "Power" }
      - { index: "3", operation: "get", deviceResource: "Voltage" }
    set:
      - { index: "1", operation: "set", deviceResource: "DemandWindowSize" }
      - { index: "2", operation: "set", deviceResource: "LineFrequency" }
    get:
      - { index: "1", operation: "get", deviceResource: "DemandWindowSize" }
      - { index: "2", operation: "get", deviceResource: "LineFrequency" }
coreCommands:
    get:
      path: "/api/v1/device/{deviceId}/Current"
      responses:
          code: "200"
          description: "Get the Current"
          expectedValues: ["Current"]
          code: "500"
          description: "internal server error"
          expectedValues: []
    get:
      path: "/api/v1/device/{deviceId}/Values"
      responses:
          code: "200"
          description: "Get the Values"
          expectedValues: ["Energy","Power","Voltage"]
          code: "500"
          expectedValues: []
    get:
      path: "/api/v1/device/{deviceId}/Configuration"
      responses:
          code: "200"
          description: "Get the Configuration"
          expectedValues: ["DemandWindowSize","LineFrequency"]
          code: "500"
          expectedValues: []
    put:
      parameterNames: ["DemandWindowSize","LineFrequency"]
      responses:
          code: "204"
          description: "Set the Configuration"
          expectedValues: []
          code: "500"
          expectedValues: []
对要读取的modbus地址和存储的数据类型需要在profile中进行编辑。
2 修改modbus服务端的容器编排文件docker-compose.yml,将以下代码解注释:
然后重新启动:docker-compose up -d。
#  device-modbus:
#    image: edgexfoundry/docker-device-modbus-go:1.2.1
#    ports:
#      - "127.0.0.1:49991:49991"
#    container_name: edgex-device-modbus
#    hostname: edgex-device-modbus
#    networks:
#      - edgex-network
#    environment:
#      <<: *common-variables
#      Service_Host: edgex-device-modbus
#    depends_on:
#      - data
#      - command
keer_zu|  楼主 | 2020-10-26 15:29 | 只看该作者
keer_zu|  楼主 | 2020-10-28 09:42 | 只看该作者
1447
