[开发工具] 玄宇芯-HC32L136点屏代码分享
805|1
 楼主| rickluo 发表于 2020-10-29 12:48 | 显示全部楼层 |阅读模式
\* Copyright (C) 2018, Huada Semiconductor Co.,Ltd All rights reserved.
\* This software is owned and published by:
\* Huada Semiconductor Co.,Ltd ("HDSC").
\* BY DOWNLOADING, INSTALLING OR USING THIS SOFTWARE, YOU AGREE TO BE BOUND
\* BY ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT.
\* This software contains source code for use with HDSC
\* components. This software is licensed by HDSC to be adapted only
\* for use in systems utilizing HDSC components. HDSC shall not be
\* responsible for misuse or illegal use of this software for devices not
\* supported herein. HDSC is providing this software "AS IS" and will
\* not be responsible for issues arising from incorrect user implementation
\* of the software.
\* Disclaimer:
\* HDSC MAKES NO WARRANTY, EXPRESS OR IMPLIED, ARISING BY LAW OR OTHERWISE,
\* REGARDING THE SOFTWARE (INCLUDING ANY ACOOMPANYING WRITTEN MATERIALS),
\* ITS PERFORMANCE OR SUITABILITY FOR YOUR INTENDED USE, INCLUDING,
\* WITHOUT LIMITATION, THE IMPLIED WARRANTY OF MERCHANTABILITY, THE IMPLIED
\* WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE OR USE, AND THE IMPLIED
\* WARRANTY OF NONINFRINGEMENT.
\* HDSC SHALL HAVE NO LIABILITY (WHETHER IN CONTRACT, WARRANTY, TORT,
\* NEGLIGENCE OR OTHERWISE) FOR ANY DAMAGES WHATSOEVER (INCLUDING, WITHOUT
\* LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS, BUSINESS INTERRUPTION,
\* LOSS OF BUSINESS INFORMATION, OR OTHER PECUNIARY LOSS) ARISING FROM USE OR
\* INABILITY TO USE THE SOFTWARE, INCLUDING, WITHOUT LIMITATION, ANY DIRECT,
\* INDIRECT, INCIDENTAL, SPECIAL OR CONSEQUENTIAL DAMAGES OR LOSS OF DATA,
\* SAVINGS OR PROFITS,
\* EVEN IF Disclaimer HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
\* YOU ASSUME ALL RESPONSIBILITIES FOR SELECTION OF THE SOFTWARE TO ACHIEVE YOUR
\* INTENDED RESULTS, AND FOR THE INSTALLATION OF, USE OF, AND RESULTS OBTAINED
\* FROM, THE SOFTWARE.
\* This software may be replicated in part or whole for the licensed use,
\* with the restriction that this Disclaimer and Copyright notice must be
\* included with each copy of this software, whether used in part or whole,
\* at all times.
/** \file main.c
** A detailed description is available at
** @link Sample Group Some description @endlink
**  - 2018-05-08 1.0 Lux First version for Device Driver Library of Module.
\* Include files
\#include "gpio.h"
\#include "lcd.h"
uint32_t numCode;
\* Local pre-processor symbols/macros ('#define')
\* Global variable definitions (declared in header file with 'extern')
\* Local type definitions ('typedef')
\* Local function prototypes ('static')
\* Local variable definitions ('static')                   *
\* Function implementation - global ('extern') and local ('static')
static void App_LedInit(void);
unsigned int CalcuCode(unsigned char num);
** \brief Main function of project
** \return uint32_t return value, if needed
** This sample
int32_t main(void)
  ///< LED端口初始化
  App_LedInit();
  while(1)
​        ///< LED点亮
​    Gpio_SetIO(STK_LED_PORT, STK_LED_PIN);
​    delay1ms(500);
​        Gpio_ClrIO(STK_LED_PORT, STK_LED_PIN);
​    delay1ms(1000);
​    delay1ms(500);
​    delay1ms(1000);
​        //Lcd_FullDisp();
​    ///< LED关闭
​        numCode = (CalcuCode(0x0a) | ((CalcuCode(0x0a))<<16));
​        Lcd_WriteRam(0,numCode);
​        Lcd_WriteRam(1,numCode);
​        delay1ms(700);
​        numCode = (CalcuCode(0x0a) | ((CalcuCode(0x01))<<16));
​        delay1ms(700);
​        numCode = (CalcuCode(0x01) | ((CalcuCode(0x08))<<16));
​        delay1ms(700);
​        numCode = (CalcuCode(0x08) | ((CalcuCode(0x05))<<16));
​        delay1ms(700);
​        numCode = (CalcuCode(0x05) | ((CalcuCode(0x06))<<16));
​        delay1ms(700);
​        numCode = (CalcuCode(0x06) | ((CalcuCode(0x06))<<16));
​        delay1ms(700);
​        numCode = (CalcuCode(0x06) | ((CalcuCode(0x02))<<16));
​        delay1ms(700);
​        numCode = (CalcuCode(0x02) | ((CalcuCode(0x03))<<16));
​        delay1ms(700);
​        numCode = (CalcuCode(0x03) | ((CalcuCode(0x09))<<16));
​        delay1ms(700);
​        numCode = (CalcuCode(0x09) | ((CalcuCode(0x00))<<16));
​        delay1ms(700);
​        numCode = (CalcuCode(0x00) | ((CalcuCode(0x00))<<16));
​        delay1ms(700);
​        delay1ms(700);
​        numCode = (CalcuCode(0x00) | ((CalcuCode(0x0a))<<16));
​        delay1ms(700);
​        delay1ms(700);
​        delay1ms(700);
​        delay1ms(700);
  unsigned int pcode;
  switch(num & 0x0f)
​    case 0 :  pcode = 0x0f05;break;
​    case 1 :  pcode  =  0x0600;break;
​    case 2 :  pcode  =  0x0b06;break;
​    case 3 :  pcode  =  0x0f02;break;
​    case 4 :  pcode  = 0x0603;break;
​    case 5 :  pcode  =  0x0d03;break;
​    case 6 :  pcode = 0x0d07;break;
​    case 7 :  pcode  =  0x0700;break;
​    case 8 :  pcode  = 0x0f07;break;
​    case 9 :  pcode  =  0x0f03;break;
​    default :  pcode  =  0x0000;break;
  return pcode;
  stc_gpio_cfg_t stcGpioCfg;
​    stc_lcd_cfg_t  stcLcdCfg;                 //LCD
​    stc_lcd_segcompara_t stcLcdsegcompara;   //LCD
​    stc_lcd_segcom_t  stcLcdsegcom;            //LCD
​    DDL_ZERO_STRUCT(stcLcdCfg);
  Sysctrl_ClkSourceEnable(SysctrlClkRCL,TRUE);      //系统时钟源使能,内部低速时钟
  Sysctrl_SetRCLTrim(SysctrlRclFreq32768);     //内部低速时钟频率TRIM值加载
​    //< 打开GPIO外设时钟门控
  Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
  Sysctrl_SetPeripheralGate(SysctrlPeripheralLcd,TRUE);
  ///< 端口方向配置->输出(其它参数与以上(输入)配置参数一致)
  stcGpioCfg.enDir = GpioDirOut;
  ///< 端口上下拉配置->下拉
  stcGpioCfg.enPu = GpioPuDisable;
  stcGpioCfg.enPd = GpioPdDisable;
  ///< LED关闭
  ///< GPIO IO LED端口初始化
  Gpio_Init(STK_LED_PORT, STK_LED_PIN, &stcGpioCfg);
​    //lcd io
​    Gpio_SetAnalogMode(STK_LCD_COM0_PORT,STK_LCD_COM0_PIN);
​    Gpio_SetAnalogMode(STK_LCD_COM1_PORT,STK_LCD_COM1_PIN);
​    Gpio_SetAnalogMode(STK_LCD_COM2_PORT,STK_LCD_COM2_PIN);
​    Gpio_SetAnalogMode(STK_LCD_COM3_PORT,STK_LCD_COM3_PIN);
​    Gpio_SetAnalogMode(STK_LCD_SEG0_PORT,STK_LCD_SEG0_PIN);
​    Gpio_SetAnalogMode(STK_LCD_SEG1_PORT,STK_LCD_SEG1_PIN);
​    Gpio_SetAnalogMode(STK_LCD_SEG2_PORT,STK_LCD_SEG2_PIN);
​    Gpio_SetAnalogMode(STK_LCD_SEG3_PORT,STK_LCD_SEG3_PIN);
​    Gpio_SetAnalogMode(STK_LCD_SEG4_PORT,STK_LCD_SEG4_PIN);
​    Gpio_SetAnalogMode(STK_LCD_SEG5_PORT,STK_LCD_SEG5_PIN);
​    Gpio_SetAnalogMode(STK_LCD_SEG6_PORT,STK_LCD_SEG6_PIN);
​    Gpio_SetAnalogMode(STK_LCD_SEG7_PORT,STK_LCD_SEG7_PIN);
​    //lcd
​    stcLcdsegcom.u32Seg0_31 = 0xffffff00;    //SEG0-SEG7
​    stcLcdsegcom.stc_seg32_51_com0_8_t.seg32_51_com0_8 = 0x000010ff;    //COM0-COM3
​    stcLcdCfg.LcdBias = LcdBias3;        //偏置电压1/3
​    stcLcdCfg.LcdBiasSrc = LcdInResMidPower;    //偏压来源 外部电容
​    stcLcdCfg.LcdClkSrc = LcdRCL;        //LCD内部
​    stcLcdCfg.LcdScanClk = LcdClk128hz; //扫描频率
​    stcLcdCfg.LcdCpClk =  LcdClk4k;      //LCD
​    stcLcdCfg.LcdDuty  =  LcdDuty4;      //1/4
​    stcLcdCfg.LcdEn = LcdEnable;        //LCD使能
​    stcLcdCfg.LcdMode = LcdMode0;        //模式0
​    Lcd_SetSegCom(&stcLcdsegcom);
​    Lcd_Init(&stcLcdCfg);
​    Lcd_ClearDisp();
\* EOF (not truncated)
isageko 发表于 2020-11-1 22:53 | 显示全部楼层
挺不错的帖子怎么没人的 不过没有大概讲讲干啥的真的很懒的看
