[RISC-V MCU 应用开发] 【原创】【RISC-V MCU CH32V103测评】彩色OLED屏显示驱动
2613|35
 楼主| jinglixixi 发表于 2020-11-21 10:49 | 显示全部楼层 |阅读模式
OLED屏有多种类型,其中的参数屏要比单色屏和双色屏更具色彩表现力,在设计小游戏时,彩色屏将是不错的选择,假如用单色屏来完成俄罗斯方块的话,那就只剩下方块了,相对来讲彩色屏会更具优势。
目前来看,似乎还没见到有I2C接口的彩色屏,因此就只有多牺牲几个I/O口来驱动彩色屏了!
在彩色屏与CH32V103的连接方面,其关系如下:
CLK--PA2
DIN--PA3
RST--PB3
DC --PB4
CS --PB5
BLK--PB6
定义引脚输出高低电平的语句为:
#define OLED_SCLK_Set()  GPIO_WriteBit(GPIOA, GPIO_Pin_2,Bit_SET)
#define OLED_SCLK_Clr()  GPIO_WriteBit(GPIOA, GPIO_Pin_2,Bit_RESET)
#define OLED_SDIN_Set()  GPIO_WriteBit(GPIOA, GPIO_Pin_3,Bit_SET)
#define OLED_SDIN_Clr()  GPIO_WriteBit(GPIOA, GPIO_Pin_3,Bit_RESET)
#define OLED_RST_Set()    GPIO_WriteBit(GPIOB, GPIO_Pin_3,Bit_SET)
#define OLED_RST_Clr()     GPIO_WriteBit(GPIOB, GPIO_Pin_3,Bit_RESET)
#define OLED_DC_Set()     GPIO_WriteBit(GPIOB, GPIO_Pin_4,Bit_SET)
#define OLED_DC_Clr()      GPIO_WriteBit(GPIOB, GPIO_Pin_4,Bit_RESET)
#define OLED_CS_Set()     GPIO_WriteBit(GPIOB, GPIO_Pin_5,Bit_SET)
#define OLED_CS_Clr()      GPIO_WriteBit(GPIOB, GPIO_Pin_5,Bit_RESET)
#define OLED_BLK_Set()    GPIO_WriteBit(GPIOB, GPIO_Pin_6,Bit_SET)
#define OLED_BLK_Clr()    GPIO_WriteBit(GPIOB, GPIO_Pin_6,Bit_RESET)
相关引脚输出功能的配置函数为:
  1. void App_OledInit(void)
  3. GPIO_InitTypeDef  GPIO_InitStructure;                                 //定义一个GPIO_InitTypeDef类型的结构体
  4. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能与LED相关的GPIO端口时钟
  5. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6; //配置GPIO引脚
  6. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;         //设置GPIO模式为推挽输出
  7. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;       //设置GPIO口输出速度
  8. GPIO_Init(GPIOB, &GPIO_InitStructure);                              //调用库函数,初始化GPIOA
  9. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);//使能与LED相关的GPIO端口时钟
  10. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_3;     //配置GPIO引脚
  11. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //设置GPIO模式为推挽输出
  12. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;       //设置GPIO口输出速度
  13. GPIO_Init(GPIOA, &GPIO_InitStructure);                             //调用库函数,初始化GPIOA
  14. GPIO_SetBits(GPIOA,GPIO_Pin_2|GPIO_Pin_3);                   //设置引脚输出高电平
  15. }
图片显示的函数为:
  1. void LCD_ShowPicturea(u16 x1,u16 y1,u16 x2,u16 y2)
  3. int i;
  4. LCD_Address_Set(x1,y1,x2,y2);
  5. for(i=0;i<12800;i++)
  6. {
  7. LCD_WR_DATA8(gImage_moled[i*2]);
  8. LCD_WR_DATA8(gImage_moled[i*2+1]);
  9. }
  10. }
实现显示效果的主程序为:
  1. int main(void)
  3. u8 i=0;
  4. u8 j=0;
  5. Delay_Init();   //延时函数初始化
  6. LED_Init();     //LED初始化
  7. App_OledInit();
  8. OLED_Init();
  9. Delay_Ms(200);
  10. LCD_Clear(BLACK);
  11. BACK_COLOR=BLACK;
  12. LCD_ShowString(10,0,"CH32V103 TEST",RED);
  13. LCD_ShowString(10,20,"OLED Display",RED);
  14. LCD_ShowString(10,40,"jinglixixi",RED);
  15. LCD_ShowString(10,60,"2020.10.28",RED);
  16. Delay_Ms(2000);
  17. LCD_Clear(BLACK);
  18. LCD_ShowChinese(28,0,0,32,YELLOW);
  19. LCD_ShowChinese(60,0,1,32,YELLOW);
  20. LCD_ShowChinese(92,0,2,32,YELLOW);
  21. LCD_ShowChinese(20,40,0,16,YELLOW);
  22. LCD_ShowChinese(36,40,1,16,YELLOW);
  23. LCD_ShowChinese(52,40,2,16,YELLOW);
  24. LCD_ShowChinese(68,40,3,16,YELLOW);
  25. LCD_ShowChinese(84,40,4,16,YELLOW);
  26. LCD_ShowChinese(100,40,5,16,YELLOW);
  27. LCD_ShowChinese(116,40,6,16,YELLOW);
  28. LCD_ShowString(20,60,"0.96 TFT SPI",YELLOW);
  29. Delay_Ms(2000);
  30. LCD_Clear(BLACK);
  31. LCD_ShowString(10,0,"LCD_W:",RED);
  32. LCD_ShowNum(70,0,LCD_W,3,RED);
  33. LCD_ShowString(10,20,"LCD_H:",RED);
  34. LCD_ShowNum(70,20,LCD_H,2,RED);
  35. for(i=0;i<4;i++)
  36. {
  37. LCD_ShowPicture(i*40,40,39+i*40,79);
  38. }
  39. Delay_Ms(2000);
  40. LCD_ShowPicturea(0,0,159,79);
  41. }
经编译,程序对系统资源的占用情况如图1所示。
图1
程序下载后的运行效果见图2~图4所示。
图2
图3
图4
若单显示图片,则系统资源资源情况为:
图5
程序下载后面,其运行效果如图6所示。
图6
NEWB  发表于 2020-11-21 18:49
 楼主| jinglixixi 发表于 2020-11-21 18:54 | 显示全部楼层
感谢支持!
yujielun 发表于 2021-2-21 20:29 | 显示全部楼层
这个不带TFT的驱动吗?
xinpian101 发表于 2021-2-22 10:15 | 显示全部楼层
给力啊,都是硬货,下载。
 楼主| jinglixixi 发表于 2021-2-22 11:17 | 显示全部楼层
给力啊,都是硬货,下载。
真爱吴迪迪 发表于 2021-2-23 15:49 | 显示全部楼层
这个是OLED还是LCD?
有没有OLED的驱动?
 楼主| jinglixixi 发表于 2021-2-23 16:40 | 显示全部楼层
这个是OLED还是LCD?
有没有OLED的驱动?
是OLED,但在商家提供的驱动中要选LCD的。
usysm 发表于 2021-3-6 21:37 | 显示全部楼层
oled显示屏对驱动电流有要求吗?
jkl21 发表于 2021-3-6 21:38 | 显示全部楼层
驱动SSD1322
wwppd 发表于 2021-3-6 21:38 | 显示全部楼层
学习一下驱动OLED显示屏的相关程序
maqianqu 发表于 2021-3-6 21:38 | 显示全部楼层
OLED有源驱动和TFT-LCD的驱动一样吗
dspmana 发表于 2021-3-6 21:39 | 显示全部楼层
用 单片机控制OLED 显示屏
eefas 发表于 2021-3-6 21:39 | 显示全部楼层
OLED屏幕的IIC驱动程序
pl202 发表于 2021-3-6 21:39 | 显示全部楼层
谢谢楼主的资料。
typeof 发表于 2021-3-6 21:40 | 显示全部楼层
是SSD1306吗
yujielun 发表于 2021-3-6 21:40 | 显示全部楼层
没有初始化的代码吗
htmlme 发表于 2021-3-6 21:41 | 显示全部楼层
这个7口的oled吧
dspmana 发表于 2021-3-6 21:41 | 显示全部楼层
可以走gui吗
maqianqu 发表于 2021-3-6 21:41 | 显示全部楼层
OLED屏SSD1306驱动
wwppd 发表于 2021-3-6 21:41 | 显示全部楼层
怎样才能同时驱动OLED和LCD两个屏
