[应用相关] AT32F415 运行程序跳转到bootloader
2545|2
 楼主| muyichuan2012 发表于 2021-1-4 19:52 | 显示全部楼层 |阅读模式
  AT32F415 的Demo:
  将附件解压到Project\AT_START_F415\Examples 即可使用;
  目前Demo 是通过 “USER” 按键触发跳转到Bootloader。
/* Includes ------------------------------------------------------------------*/
#include <stdio.h>
#include "at32f4xx.h"
#include "at32_board.h"
/** @addtogroup AT32F415_StdPeriph_Templates
/** @addtogroup Template
/* Private define ------------------------------------------------------------*/
#define DELAY          100
#define FAST           1
#define SLOW           4
#define BOOTLOADER_ADDRESS  0x1FFFAC00
#define BKP_JUMP_FLAG       0x5AA5
#define SET_MSP(dwValue) __ASM volatile ("msr msp, "#dwValue)
void (*pfTarget)(void);
/* Extern variables ---------------------------------------------------------*/
extern GPIO_Type *BUTTON_GPIO_PORT[BUTTON_NUM];
extern uint16_t BUTTON_GPIO_PIN[BUTTON_NUM];
extern uint32_t BUTTON_GPIO_RCC_CLK [BUTTON_NUM];
/* Private variables ---------------------------------------------------------*/
uint16_t BUTTON_EXTI_LINE[BUTTON_NUM] = {EXTI_Line0, EXTI_Line13};
uint16_t BUTTON_EXTI_IRQ[BUTTON_NUM] = {EXTI0_IRQn, EXTI15_10_IRQn};
uint8_t BUTTON_EXTI_SOURCE_PORT[BUTTON_NUM] = {GPIO_PortSourceGPIOA, GPIO_PortSourceGPIOC};
uint8_t BUTTON_EXTI_SOURCE_PIN[BUTTON_NUM] = {GPIO_PinsSource0, GPIO_PinsSource13};
uint8_t gUpdateFlag = 0;
BUTTON_Type gButtonType = BUTTON_WAKEUP;
uint8_t gSpeed = FAST;
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
  * @brief  Configure Button EXTI
  * @param  Button: Specifies the Button to be configured.
  * @retval None
void BUTTON_EXTI_Init(BUTTON_Type button)
  EXTI_InitType EXTI_InitStructure;
  NVIC_InitType NVIC_InitStructure;
  GPIO_EXTILineConfig(BUTTON_EXTI_SOURCE_PORT[button], BUTTON_EXTI_SOURCE_PIN[button]);
  EXTI_StructInit(&EXTI_InitStructure);
  EXTI_InitStructure.EXTI_Line = BUTTON_EXTI_LINE[button];
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_LineEnable = ENABLE;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_Init(&EXTI_InitStructure);
  NVIC_InitStructure.NVIC_IRQChannel = BUTTON_EXTI_IRQ[button];
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_Init(&NVIC_InitStructure);
  * @brief  Button EXTI0 Interrupt Handler
  * @param  None
  * @retval None
void EXTI0_IRQHandler(void)
  Delay_ms(5);
  EXTI_ClearIntPendingBit(BUTTON_EXTI_LINE[gButtonType]);
  if ((GPIO_ReadInputData(BUTTON_GPIO_PORT[gButtonType]) & BUTTON_GPIO_PIN[gButtonType]) == \
    gUpdateFlag = 1;
  * @brief Clear all System Status
        1. Close All Peripherals Clock
        2. Close PLL
        3. Disable All interrupt
        4. Clear All Pending Interrupt Flag
  * @param  None
  * @retval None
void APP_ClearSysStatus()
  /*Close Peripherals Clock*/
  RCC->APB2RST = 0xFFFFFFFF;
  RCC->APB2RST = 0;
  RCC->APB1RST = 0xFFFFFFFF;
  RCC->APB1RST = 0;
  RCC->APB2EN = 0;
  RCC->APB1EN = 0;
  RCC->AHBRST = 0xFFFFFFFF;
  RCC->AHBRST = 0;
  /*close USB clock*/
  RCC_AHBPeriphClockCmd(RCC_AHBPERIPH_USB, DISABLE);
  /*Close PLL*/
  /* Reset SW, AHBPSC, APB1PSC, APB2PSC, ADCPSC and CLKOUT bits */
  RCC_Reset();
  /*Colse Systick*/
  SysTick->CTRL = 0;
  /*Disable ALL interrupt && Pending Interrupt Flag*/
  /*这里需要根据用户开启的外设进行清除中断和挂起的中断标志*/
  user add code...
2. Close PLL
  * @brief  Jump to bootloader
  * @param  None
  * @retval None
void APPJumpToBootloader(void)
    uint32_t dwStkPtr, dwJumpAddr;
    dwStkPtr = *(uint32_t *)BOOTLOADER_ADDRESS;
    dwJumpAddr = *(uint32_t *)(BOOTLOADER_ADDRESS + sizeof(uint32_t));
    /*跳转之前,需要保证所有外设Clock 关闭,PLL 关闭,关闭所有中断,清除所有的中断挂起标志*/
    SET_MSP(dwStkPtr);
    pfTarget = (void (*)(void))dwJumpAddr;
    pfTarget();
  * @brief  Main Function.
  * @param  None
  * @retval None
int main(void)
  RCC_APB2PeriphClockCmd(RCC_APB2PERIPH_AFIO, ENABLE);
  AT32_Board_Init();
  BUTTON_EXTI_Init(gButtonType);
  for(;;)
    if ( gUpdateFlag == 1 )
      /*Jump to System Memory*/
      APP_ClearSysStatus();
      APPJumpToBootloader();
Jump_To_System_Memory.zip
19.83 KB, 下载次数: 76
pattywu 发表于 2021-1-4 20:43 | 显示全部楼层
是代码,就顶一下,做个记号。以便查找 。
ytmpeigd 发表于 2021-5-26 14:28 | 显示全部楼层
能下载吗?
