[应用相关] BUG: stm32g474 cubemx生成ADC2初始化代码有问题
902|2
 楼主| laocuo1142 发表于 2021-2-1 15:50 | 显示全部楼层 |阅读模式
在cubeide中,用cubemx产生stm32g474re LL库的初始代码中,ADC1和ADC2配成独立工作,但是在MX_ADC2_Init(void)中,这两句是错的  LL_ADC_DisableDeepPowerDown(ADC1);
  LL_ADC_EnableInternalRegulator(ADC1);
将导致ADC2不供电,无法工作,每次都要手工改过来才能正常工作。
  * @brief ADC2 Initialization Function
  * @param None
  * @retval None
static void MX_ADC2_Init(void)
  /* USER CODE BEGIN ADC2_Init 0 */
  /* USER CODE END ADC2_Init 0 */
  LL_ADC_InitTypeDef ADC_InitStruct = {0};
  LL_ADC_REG_InitTypeDef ADC_REG_InitStruct = {0};
  /* Peripheral clock enable */
  LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_ADC12);
  /* ADC2 DMA Init */
  /* ADC2 Init */
  LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_1, LL_DMAMUX_REQ_ADC2);
  LL_DMA_SetDataTransferDirection(DMA1, LL_DMA_CHANNEL_1, LL_DMA_DIRECTION_PERIPH_TO_MEMORY);
  LL_DMA_SetChannelPriorityLevel(DMA1, LL_DMA_CHANNEL_1, LL_DMA_PRIORITY_MEDIUM);
  LL_DMA_SetMode(DMA1, LL_DMA_CHANNEL_1, LL_DMA_MODE_NORMAL);
  LL_DMA_SetPeriphIncMode(DMA1, LL_DMA_CHANNEL_1, LL_DMA_PERIPH_NOINCREMENT);
  LL_DMA_SetMemoryIncMode(DMA1, LL_DMA_CHANNEL_1, LL_DMA_MEMORY_INCREMENT);
  LL_DMA_SetPeriphSize(DMA1, LL_DMA_CHANNEL_1, LL_DMA_PDATAALIGN_WORD);
  LL_DMA_SetMemorySize(DMA1, LL_DMA_CHANNEL_1, LL_DMA_MDATAALIGN_HALFWORD);
  /* USER CODE BEGIN ADC2_Init 1 */
  /* USER CODE END ADC2_Init 1 */
  /** Common config
  ADC_InitStruct.Resolution = LL_ADC_RESOLUTION_12B;
  ADC_InitStruct.DataAlignment = LL_ADC_DATA_ALIGN_LEFT;
  ADC_InitStruct.LowPowerMode = LL_ADC_LP_MODE_NONE;
  LL_ADC_Init(ADC2, &ADC_InitStruct);
  ADC_REG_InitStruct.TriggerSource = LL_ADC_REG_TRIG_EXT_TIM8_TRGO;
  ADC_REG_InitStruct.SequencerLength = LL_ADC_REG_SEQ_SCAN_DISABLE;
  ADC_REG_InitStruct.SequencerDiscont = LL_ADC_REG_SEQ_DISCONT_DISABLE;
  ADC_REG_InitStruct.ContinuousMode = LL_ADC_REG_CONV_SINGLE;
  ADC_REG_InitStruct.DMATransfer = LL_ADC_REG_DMA_TRANSFER_UNLIMITED;
  ADC_REG_InitStruct.Overrun = LL_ADC_REG_OVR_DATA_OVERWRITTEN;
  LL_ADC_REG_Init(ADC2, &ADC_REG_InitStruct);
  LL_ADC_SetGainCompensation(ADC2, 0);
  LL_ADC_SetOverSamplingScope(ADC2, LL_ADC_OVS_DISABLE);
  /* Disable ADC deep power down (enabled by default after reset state) */
  /* Enable ADC internal voltage regulator */
  /* Delay for ADC internal voltage regulator stabilization. */
  /* Compute number of CPU cycles to wait for, from delay in us. */
  /* Note: Variable divided by 2 to compensate partially */
  /* CPU processing cycles (depends on compilation optimization). */
  /* Note: If system core clock frequency is below 200kHz, wait time */
  /* is only a few CPU processing cycles. */
  uint32_t wait_loop_index;
  wait_loop_index = ((LL_ADC_DELAY_INTERNAL_REGUL_STAB_US * (SystemCoreClock / (100000 * 2))) / 10);
  while(wait_loop_index != 0)
    wait_loop_index--;
  LL_ADC_REG_SetTriggerEdge(ADC2, LL_ADC_REG_TRIG_EXT_RISING);
  /** Configure Regular Channel
  LL_ADC_REG_SetSequencerRanks(ADC2, LL_ADC_REG_RANK_1, LL_ADC_CHANNEL_VOPAMP3_ADC2);
  LL_ADC_SetChannelSamplingTime(ADC2, LL_ADC_CHANNEL_VOPAMP3_ADC2, LL_ADC_SAMPLINGTIME_6CYCLES_5);
  LL_ADC_SetChannelSingleDiff(ADC2, LL_ADC_CHANNEL_VOPAMP3_ADC2, LL_ADC_SINGLE_ENDED);
  LL_ADC_SetOffset(ADC2, LL_ADC_OFFSET_1, LL_ADC_CHANNEL_VOPAMP3_ADC2, 0);
  LL_ADC_SetOffsetSign(ADC2, LL_ADC_OFFSET_1, LL_ADC_OFFSET_SIGN_NEGATIVE);
  LL_ADC_SetOffsetSaturation(ADC2, LL_ADC_OFFSET_1, LL_ADC_OFFSET_SATURATION_DISABLE);
  /* USER CODE BEGIN ADC2_Init 2 */
  LL_ADC_StartCalibration(ADC2, LL_ADC_SINGLE_ENDED);
  while (LL_ADC_IsCalibrationOnGoing(ADC2) != 0)  { };
  wait_loop_index = (ADC_DELAY_CALIB_ENABLE_CPU_CYCLES >> 1);
    wait_loop_index--;
  /* Enable ADC */
  LL_ADC_Enable(ADC2);
  /* Poll for ADC ready to convert */
  while (LL_ADC_IsActiveFlag_ADRDY(ADC2) == 0)         { };
  /* USER CODE END ADC2_Init 2 */
磨砂 发表于 2021-3-1 12:55 | 显示全部楼层
如何发现的这个错误呢
晓伍 发表于 2021-3-1 12:58 | 显示全部楼层
非常感谢楼主的提醒哈
