[技术讨论]
AT32F421硬件I2C官方库驱动异常
946|1
因为ST身价太贵,最近尝试国产替代,使用AT32F421测试发现硬件I2C在从机有响应的情况下,并没有置位ADDRF标志(见代码31行),造成I2C一直超时停止,请问哪 位大神能指导一下。
I2C_StatusType I2C_Mem_Read(I2C_Type* I2Cx, uint8_t SlaAddr, uint32_t ReadAddr, uint8_t ReadAddrSize, uint8_t *pBuffer, uint16_t NumByteToRead, uint32_t Timeout)
  /* Wait until BUSY flag is reset */
  if(I2C_WaitOnFlagUntilTimeout(I2Cx, I2C_FLAG_BUSYF, SET, I2C_EVT_CHECK_NONE, I2C_TIMEOUT_BUSY_FLAG) != I2C_OK)
    return I2C_ERROR_STEP_1;
  /* Disable Pos */
  I2C_NACKPositionConfig(I2Cx, I2C_NACKPosition_Current);
  /* Enable Acknowledge */
  I2C_AcknowledgeConfig(I2Cx, ENABLE);
  /* Send START condition */
  I2C_GenerateSTART(I2Cx, ENABLE);
  /* Wait until SB flag is set */
  if(I2C_WaitOnFlagUntilTimeout(I2Cx, I2C_FLAG_STARTF, RESET, I2C_EVT_CHECK_NONE, Timeout) != I2C_OK)
    /* Send STOP Condition */
    I2C_GenerateSTOP(I2Cx, ENABLE);
    return I2C_ERROR_STEP_2;
  /* Send slave address for write */
  I2C_Send7bitAddress(I2Cx, SlaAddr, I2C_Direction_Transmit);
/* Wait until ADDR flag is set */
  if(I2C_WaitOnFlagUntilTimeout(I2Cx, I2C_FLAG_ADDRF, RESET, I2C_EVT_CHECK_NONE, Timeout) != I2C_OK)
    return I2C_ERROR_STEP_3;
  /* Clear ADDR flag */
  I2C_ClearADDRFlag(I2Cx);
  /* Wait until TDE flag is set */
  if(I2C_WaitOnFlagUntilTimeout(I2Cx, I2C_FLAG_TDE, RESET, I2C_EVT_CHECK_NONE, Timeout) != I2C_OK)
    return I2C_ERROR_STEP_4;
  if(ReadAddrSize == I2C_MEMADD_SIZE_32BIT)
          I2C_SendData(I2Cx, (uint8_t)(ReadAddr >> 24));
          if(I2C_WaitOnFlagUntilTimeout(I2Cx, I2C_FLAG_TDE, RESET, I2C_EVT_CHECK_ACKFAIL, Timeout) != I2C_OK)
            return I2C_ERROR_STEP_5;
          ReadAddrSize -= 1;
  if(ReadAddrSize == I2C_MEMADD_SIZE_24BIT)
          I2C_SendData(I2Cx, (uint8_t)(ReadAddr >> 16));
          ReadAddrSize -= 1;
  if(ReadAddrSize == I2C_MEMADD_SIZE_16BIT)
          I2C_SendData(I2Cx, (uint8_t)(ReadAddr >> 8));
  /* Send Memory Address */
  I2C_SendData(I2Cx, ReadAddr);
    return I2C_ERROR_STEP_6;
  /* Send slave address for read */
  I2C_Send7bitAddress(I2Cx, SlaAddr, I2C_Direction_Receive);
  if(I2C_WaitOnFlagUntilTimeout(I2Cx, I2C_FLAG_ADDRF, RESET, I2C_EVT_CHECK_ACKFAIL, Timeout) != I2C_OK)
    return I2C_ERROR_STEP_7;
  if(NumByteToRead == 1)
    /* Disable Acknowledge */
    I2C_AcknowledgeConfig(I2Cx, DISABLE);
  else if(NumByteToRead == 2)
    /* Enable Pos */
    I2C_NACKPositionConfig(I2Cx, I2C_NACKPosition_Next);
  else
  while(NumByteToRead > 0)
    if(NumByteToRead <= 3)
      /* One byte */
        /* Wait until RXNE flag is set */
        if(I2C_WaitOnFlagUntilTimeout(I2Cx, I2C_FLAG_RDNE, RESET, I2C_EVT_CHECK_NONE, Timeout) != I2C_OK)
          return I2C_ERROR_STEP_8;
        /* Read data from DR */
        (*pBuffer++) = I2C_ReceiveData(I2Cx);
        NumByteToRead--;
      /* Two bytes */
        /* Wait until BTF flag is set */
        if(I2C_WaitOnFlagUntilTimeout(I2Cx, I2C_FLAG_BTFF, RESET, I2C_EVT_CHECK_NONE, Timeout) != I2C_OK)
          return I2C_ERROR_STEP_9;
        NumByteToRead--;
        NumByteToRead--;
      /* 3 Last bytes */
      else
          return I2C_ERROR_STEP_10;
        NumByteToRead--;
          return I2C_ERROR_STEP_11;
        NumByteToRead--;
        NumByteToRead--;
    else
        return I2C_ERROR_STEP_12;
      NumByteToRead--;
  return I2C_OK;
tanganrong|  楼主 | 2021-3-21 18:53 | 只看该作者
帖子放错版块了
