[STM32F1] IO模拟SPI _读写 SPI FLASH-25Q32
674|12
 楼主| huangchui 发表于 2021-5-9 19:08 | 显示全部楼层 |阅读模式
/******************** (C) COPYRIGHT ********************
* 文件名  :spi_flash.c
* 描述    :spi 底层应用函数库
* 硬件连接 ----------------------------
*         | PC8-SPI2-NSS  : W25X40-CS  |
*         | PD14-SPI2-SCK  : W25X40-CLK |
*         | PC7-SPI2-MISO : W25X40-DO  |
*         | PD13-SPI2-MOSI : W25X40-DIO |
*         | PC6-WRITE    : W25X40-DIO |
*         | PD15-HOLD    : W25X40-DIO |
* 库版本  :ST3.0.0
* 作者    :
* 博客    :
#include "spi_flash.h"
#include "gpio.h"
/* Private typedef -----------------------------------------------------------*/
//#define SPI_FLASH_PageSize      4096
#define SPI_FLASH_PageSize      256
#define SPI_FLASH_PerWritePageSize      256
/* Private define ------------------------------------------------------------*/
#define W25X_WriteEnable                      0x06
#define W25X_WriteDisable                      0x04
#define W25X_ReadStatusReg                    0x05
#define W25X_WriteStatusReg                    0x01
#define W25X_ReadData                                0x03
#define W25X_FastReadData                      0x0B
#define W25X_FastReadDual                      0x3B
#define W25X_PageProgram                      0x02
#define W25X_BlockErase                              0xD8
#define W25X_SectorErase                      0x20
#define W25X_ChipErase                              0xC7
#define W25X_PowerDown                              0xB9
#define W25X_ReleasePowerDown            0xAB
#define W25X_DeviceID                                0xAB
#define W25X_ManufactDeviceID           0x90
#define W25X_JedecDeviceID                    0x9F
#define WIP_Flag                  0x01  /* Write In Progress (WIP) flag */
#define Dummy_Byte                0xFF
 楼主| huangchui 发表于 2021-5-9 19:10 | 显示全部楼层
void SPI_FLASH_Write_Protect_ENABLE(void)//flash 打开写保护
  SPI_FLASH_Write_Protect_Assert();
 楼主| huangchui 发表于 2021-5-9 19:12 | 显示全部楼层
void SPI_FLASH_Write_Protect_DISABLE(void)//flash 关闭写保护
  SPI_FLASH_Write_Protect_Deassert();
 楼主| huangchui 发表于 2021-5-9 19:14 | 显示全部楼层
void SPI_FLASH_Hold_ENABLE(void)//flash HOLD ENABLE
  SPI_FLASH_Hold_Assert();
 楼主| huangchui 发表于 2021-5-9 19:16 | 显示全部楼层
void SPI_FLASH_Hold_DISABLE(void)//flash HOLD DISABLE
  SPI_FLASH_Hold_Deassert();
 楼主| huangchui 发表于 2021-5-9 19:17 | 显示全部楼层
* Function Name  : SPI_FLASH_Init
* Description    : Initializes the peripherals used by the SPI FLASH driver.
* Input          : None
* Output         : None
* Return         : None
void SPI_FLASH_Init(void)
#ifdef _BOARD  //DEMO Board
GpioInitTypeDef gpioInitStr;
    // 初始化模拟SPI的IO口
    // SPI_FLASH_SCK_S  PA5
        gpioInitStr.GpioPin = SPI_FLASH_SCK_PIN_S;
        gpioInitStr.GpioSpeed = GpioSpeed2MHz;
        gpioInitStr.GpioMode = Gpio_Mode_Out_PP;
        GpioInit(SPI_FLASH_SCK_PORT_S, &gpioInitStr);
    // SPI_FLASH_MOSI_S PA7
           gpioInitStr.GpioPin = SPI_FLASH_MOSI_PIN_S;
        GpioInit(SPI_FLASH_MOSI_PORY_S, &gpioInitStr);
    // SPI_FLASH_NSS_S  PA4
    gpioInitStr.GpioPin = SPI_FLASH_NSS_PIN_S;
        GpioInit(SPI_FLASH_NSS_PORT_S, &gpioInitStr);
    // SPI_FLASH_MISO_S PA6
           gpioInitStr.GpioPin = SPI_FLASH_MISO_PIN_S;
        gpioInitStr.GpioMode = Gpio_Mode_IN_FLOATING;
      //gpioInitStr.GpioMode = Gpio_Mode_IPU;
        GpioInit(SPI_FLASH_MISO_PORY_S, &gpioInitStr);
#else
#ifdef SPI_FLASH_HAL
  SPI_InitTypeDef  SPI_InitStructure;
  /* Enable SPI1 and GPIO clocks */
  /*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO,
       SPI_FLASH_SPI_MISO_GPIO, SPI_FLASH_SPI_DETECT_GPIO
       and SPI_FLASH_SPI_SCK_GPIO Periph clock enable */
  // spi2管脚重映射
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD, ENABLE);
  /*!< SPI_FLASH_SPI Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  /*!< AFIO Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  /*!< Configure SPI_FLASH_SPI pins: SCK */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  /*!< Configure SPI_FLASH_SPI pins: MISO */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /*!< Configure SPI_FLASH_SPI pins: MOSI */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  /*!< Configure SPI_FLASH_SPI_CS_PIN pin: SPI_FLASH Card CS pin */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  /* Deselect the FLASH: Chip Select high */
  SPI_FLASH_CS_HIGH();
  /* SPI1 configuration */
  // W25X40: data input on the DIO pin is sampled on the rising edge of the CLK.
  // Data on the DO and DIO pins are clocked out on the falling edge of CLK.
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;  //高位先发
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI2, &SPI_InitStructure);
  /* Enable SPI1  */
  SPI_Cmd(SPI2, ENABLE);
#else
    // 初始化模拟SPI的IO口
    // SPI_FLASH_SCK_S  PD14
    // SPI_FLASH_MOSI_S PD13
    // SPI_FLASH_NSS_S  PC8
    // SPI_FLASH_MISO_S PC7
#endif
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD, ENABLE);
      //Write_Protect PC6
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
      //Hold  PD15
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
        SPI_FLASH_Write_Protect_DISABLE();//flash 关闭写保护
        SPI_FLASH_Hold_DISABLE();//flash HOLD DISABLE
#endif
xiaoqizi 发表于 2021-6-2 15:02 | 显示全部楼层
spi本来就挺好用的 为什么要模拟呢
木木guainv 发表于 2021-6-2 15:05 | 显示全部楼层
实测运行稳定吗
磨砂 发表于 2021-6-2 15:35 | 显示全部楼层
代码配置需求比较多
晓伍 发表于 2021-6-2 15:39 | 显示全部楼层
模拟spi调试的时候顺手吗
八层楼 发表于 2021-6-2 15:43 | 显示全部楼层
请问如何调整时序呢
東南博士 发表于 2021-6-2 15:43 | 显示全部楼层
学习学习!
感觉还是硬件比较好!
观海 发表于 2021-6-2 15:46 | 显示全部楼层
定义那么多id是用来干嘛的呢
