[STM32F4] DMA双缓冲模式
5054|26
 楼主| wyjie 发表于 2021-6-7 21:21 | 显示全部楼层
/* ÉùÃ÷TIMµÄ¼Ä´æÆ÷½á¹¹Ìå*/
    ADC_InitTypeDef       ADC_InitStruct;
    ADC_CommonInitTypeDef ADC_CommonInitStruct;
          DMA_InitTypeDef DMA_InitStruct;
          GPIO_InitTypeDef      GPIO_InitStructure;
          RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOF, ENABLE);
    /* ÉèÖÃAD²ÉÑù¶Ë¿Ú:Ä£ÄâÊäÈë*/
    /* DMA2 channel2 configuration*/
    DMA_InitStruct.DMA_Channel = DMA_Channel_2;        //»Ö¸´Ä¬ÈÏÖµ¸Ã²Ù×÷ҪעÒâ²»ÒªÖØ¸´²Ù×÷Ôì³É¼Ä´æÆ÷״̬»ìÂÒ
    DMA_InitStruct.DMA_PeripheralBaseAddr = ADC3_DR_Address;     //ÍâÉèµØÖ·        32λµØÖ·
    DMA_InitStruct.DMA_Memory0BaseAddr = (u32)&Tx_Buffer[2];      //ÄÚ´æµØÖ·£¬Êý×é½á¹¹À´´æ´¢²É¼¯µÄADÁ¿ ¼Ó(u32) ÒòΪ´æ´¢Æ÷µØÖ·¼Ä´æÆ÷ÊÇ32λµÄ
    DMA_InitStruct.DMA_DIR = DMA_DIR_PeripheralToMemory;              //dma´«Êä·½Ïòµ¥Ïò ÍâÉèΪԴ¡£
          DMA_InitStruct.DMA_BufferSize = sampling_dot*chn*25*2;        //ÉèÖÃDMAÔÚ´«Êäʱ»º³åÇøµÄ³¤¶È word 3¸öͨµÀ ÿ¸öͨµÀ32µã ¹²´æ96µãÖµ
    DMA_InitStruct.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//ÉèÖÃDMAµÄÍâÉèµÝÔöģʽ£¬Ò»¸öÍâÉè
    DMA_InitStruct.DMA_MemoryInc = DMA_MemoryInc_Enable;         //ÉèÖÃDMAµÄÄÚ´æµÝÔöģʽ£¬
    DMA_InitStruct.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//ÍâÉèÊý¾Ý×Ö³¤
    DMA_InitStruct.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;//ÄÚ´æÊý¾Ý×Ö³¤
    DMA_InitStruct.DMA_Mode = DMA_Mode_Circular;                 //ÉèÖÃDMAµÄ´«Êäģʽ£ºÁ¬Ðø²»¶ÏµÄÑ­»·Ä£Ê½
    DMA_InitStruct.DMA_Priority = DMA_Priority_High;             //ÉèÖÃDMAµÄÓÅÏȼ¶±ðΪ¸ß
    DMA_InitStruct.DMA_FIFOMode = DMA_FIFOMode_Disable;
    DMA_InitStruct.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
    DMA_InitStruct.DMA_MemoryBurst = DMA_MemoryBurst_Single;
    DMA_InitStruct.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;                    //
    DMA_Init(DMA2_Stream0, &DMA_InitStruct);
    /*Enable DMA1 channel1*/
    DMA_Cmd(DMA2_Stream0, ENABLE);
                DMA_ClearITPendingBit(DMA2_Stream0, DMA_IT_TCIF0);
                DMA_ClearITPendingBit(DMA2_Stream0, DMA_IT_HTIF0);
                DMA_ITConfig(DMA2_Stream0, DMA_IT_HT, ENABLE);
    DMA_ITConfig(DMA2_Stream0, DMA_IT_TC, ENABLE);
    /* Configure PC.03 (ADC Channel13) as analog input -------------------------*/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_0;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
    GPIO_Init(GPIOF, &GPIO_InitStructure);
                RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);
    /* Common configuration (applicable for the three ADCs) ******/
    /* Single ADC mode */
    ADC_CommonInitStruct.ADC_Mode = ADC_Mode_Independent;
    /* ADCCLK = PCLK2/2 */
                ADC_CommonInitStruct.ADC_Prescaler = ADC_Prescaler_Div6;
                ADC_CommonInitStruct.ADC_Prescaler = ADC_Prescaler_Div8;
    /* Available only for multi ADC mode */
//     ADC_CommonInitStruct.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
    /* Delay between 2 sampling phases */
                ADC_CommonInitStruct.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles;
    ADC_CommonInit(&ADC_CommonInitStruct);
    /* Configure ADC1 to convert continously channel/2/3 ***********/
    ADC_InitStruct.ADC_Resolution = ADC_Resolution_12b;
    ADC_InitStruct.ADC_ScanConvMode = ENABLE ;
                ADC_InitStruct.ADC_ContinuousConvMode = DISABLE;
//    ADC_InitStruct.ADC_ContinuousConvMode = ENABLE;
    ADC_InitStruct.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
    ADC_InitStruct.ADC_DataAlign = ADC_DataAlign_Right;
    ADC_InitStruct.ADC_NbrOfConversion = chn;
    ADC_Init(ADC3, &ADC_InitStruct);
    /* ADC1 regular channels configuration [¹æÔòģʽͨµÀÅäÖÃ]*/
    ADC_RegularChannelConfig(ADC3, ADC_Channel_5 , 6, ADC_SampleTime_480Cycles);//ͨµÀ1£¬UA
    ADC_RegularChannelConfig(ADC3, ADC_Channel_10, 5, ADC_SampleTime_480Cycles);//ͨµÀ2£¬IA
    ADC_RegularChannelConfig(ADC3, ADC_Channel_6 , 4, ADC_SampleTime_480Cycles);//ͨµÀ3£¬UB
                ADC_RegularChannelConfig(ADC3, ADC_Channel_4 , 3, ADC_SampleTime_480Cycles);//ͨµÀ4£¬IB
                ADC_RegularChannelConfig(ADC3, ADC_Channel_7 , 2, ADC_SampleTime_480Cycles);//ͨµÀ5£¬UC
                ADC_RegularChannelConfig(ADC3, ADC_Channel_13 ,1, ADC_SampleTime_480Cycles);//ͨµÀ6£¬IC
                ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE);
    /*  Ê¹ÄÜADC1 DMA*/
    ADC_DMACmd(ADC3, ENABLE);
    /* Enable ADC1 ʹÄÜADC1*/
//    ADC_ITConfig(ADC3, ADC_IT_EOC, ENABLE);
    ADC_Cmd(ADC3, ENABLE);
    ADC_SoftwareStartConv(ADC3);
zwll 发表于 2021-6-7 21:26 | 显示全部楼层
你不用dma,把3200点缓存里初始化成正确的数据
renyaq 发表于 2021-6-7 21:28 | 显示全部楼层
然后用你的函数去处理。看看有没有问题。
 楼主| wyjie 发表于 2021-6-7 21:32 | 显示全部楼层
在定时中断里只做启动AD转换的操作,就可以了,以前的程序里对采样次数做了累加,应该是条件限制造成了采样的延后。
dingy 发表于 2021-6-7 22:02 | 显示全部楼层
那应该没什么问题了吧。呵呵。st不用背黑锅了
renyaq 发表于 2021-6-7 22:04 | 显示全部楼层
请问楼主用以太网传数据的话不会应为速度的问题而舍弃掉某些数据吗
 楼主| wyjie 发表于 2021-6-7 22:07 | 显示全部楼层
其实还是不大明白,我再琢磨琢磨吧,多谢了哈先
