[应用相关] STM32移植FAFTS文件系统遍历设备中的所有文件和文件夹
8813|0
 楼主| 晓伍 发表于 2021-7-2 12:57 | 显示全部楼层 |阅读模式
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "sdram.h"
#include "mpu.h"
#include "malloc.h"
#include "nand.h"
#include "ftl.h"
#include "ff.h"
#include "exfuns.h"
#include "string.h"
FRESULT scan_files (char* path)
    FRESULT res;
    DIR dir;
    UINT i;
    static FILINFO fno;
        static u8 layerDeeph=0;
        u8 j;
    res = f_opendir(&dir, path);
    if (res == FR_OK)
                layerDeeph+=4;
        for (;;)
            res = f_readdir(&dir, &fno);
            if (res != FR_OK || fno.fname[0] == 0)
                                break;
            if (fno.fattrib & AM_DIR)
                i = strlen(path);
                sprintf(&path[i], "/%s", fno.fname);
                                for(j=0;j<layerDeeph;j++)
                                        printf(" ");
                                printf("%s%s%s%s%s%s\r\n", "\033[","33;","22m",fno.fname,"  <DIR>","\033[0m");
                res = scan_files(path);
                if (res != FR_OK) break;
                path[i] = 0;
                        else
                                        printf(" ");
                printf("%s%s%s%s%s\r\n","\033[","32;","22m",fno.fname,"\033[0m");
        f_closedir(&dir);
                layerDeeph-=4;
    return res;
int main(void)
        char buff[256];
        u8 t=0;
        u8 res=0;
        FIL file;
        Cache_Enable();                                        //打开L1-Cache
        HAL_Init();                                                        //初始化HAL库
        Stm32_Clock_Init(160,5,2,4);                      //设置时钟,400Mhz
        delay_init(400);                                                //延时初始化
        uart_init(115200);                                                //串口初始化
        LED_Init();        //初始化LED
        SDRAM_Init();                                   //初始化SDRAM
        my_mem_init(SRAMIN);                        //初始化内部内存池(AXI)
        my_mem_init(SRAMEX);                        //初始化外部内存池(SDRAM)
        my_mem_init(SRAM12);                        //初始化SRAM12内存池(SRAM1+SRAM2)
        my_mem_init(SRAM4);                                //初始化SRAM4内存池(SRAM4)
        my_mem_init(SRAMDTCM);                        //初始化DTCM内存池(DTCM)
        my_mem_init(SRAMITCM);                        //初始化ITCM内存池(ITCM)
        FTL_Init();
        exfuns_init();                                //为fatfs相关变量申请内存
        res=f_mount(fs[0],"0:",1);        //挂载NAND FLASH.
        if(res==0X0D)                                //NAND FLASH磁盘,FAT文件系统错误,重新格式化NAND FLASH
                printf("NAND Disk Formatting...\r\n");//格式化NAND
                res=f_mkfs("0:",FM_ANY,0,fatbuf,FF_MAX_SS);        //格式化NAND FLASH,1:,盘符;FM_ANY,自动选择文件系统类型,0,自动选择簇大小
                if(res==0)
                        f_setlabel((const TCHAR *)"0:NANDDISK");//设置Flash磁盘的名字为:NANDDISK
                        printf("NAND Disk Format Finish\r\n");                //格式化完成
                else
                        printf("NAND Disk Format Error\r\n");        //格式化失败
                delay_ms(1000);
        printf("*********************************\r\n");
        f_mkdir("/HDC");
                f_open(&file,"/HDC/1.txt",FA_OPEN_ALWAYS|FA_WRITE);
                f_close(&file);
                f_open(&file,"/HDC/2.txt",FA_OPEN_ALWAYS|FA_WRITE);
                f_close(&file);
                f_mkdir("/HDC/A");
                        f_open(&file,"/HDC/A/A1.txt",FA_OPEN_ALWAYS|FA_WRITE);
                        f_close(&file);
                        f_open(&file,"/HDC/A/A2.txt",FA_OPEN_ALWAYS|FA_WRITE);
                        f_close(&file);
                        f_open(&file,"/HDC/A/A3.txt",FA_OPEN_ALWAYS|FA_WRITE);
                        f_close(&file);
                f_mkdir("/HDC/B");
                        f_open(&file,"/HDC/B/B1.txt",FA_OPEN_ALWAYS|FA_WRITE);
                        f_close(&file);
                        f_open(&file,"/HDC/B/B2.txt",FA_OPEN_ALWAYS|FA_WRITE);
                        f_close(&file);
                        f_open(&file,"/HDC/B/B3.txt",FA_OPEN_ALWAYS|FA_WRITE);
                        f_close(&file);
                f_mkdir("/HDC/C");
                        f_open(&file,"/HDC/C/C1.txt",FA_OPEN_ALWAYS|FA_WRITE);
                        f_close(&file);
                        f_open(&file,"/HDC/C/C2.txt",FA_OPEN_ALWAYS|FA_WRITE);
                        f_close(&file);
                        f_open(&file,"/HDC/C/C3.txt",FA_OPEN_ALWAYS|FA_WRITE);
                        f_close(&file);
        strcpy(buff, "/");
        res = scan_files(buff);
        while(1)
                t++;
                delay_ms(200);
                LED0_Toggle;//DS0闪烁
