[信息] 请问使用stm32f7x的硬件jpeg解码功能,图片不能够横屏显示...
1340|1
 楼主| duo点 发表于 2021-7-6 11:31 | 显示全部楼层 |阅读模式
请教下,使用 STM32f7x的硬件 jpeg 解码功能,图片不能够横屏显示??
但是 显示字符,画图等完全可以横屏显示(四个方向可以任意显示),
还有在图片上显示字符,具体见下面程序的描述
貌似设置横竖屏显示的函数就在下面这个函数里面,但是不知道该如果修改 ????
static uint32_t JPEG_MCU_YCbCr420_ARGB_ConvertBlocks(uint8_t *pInBuffer,
                                      uint8_t *pOutBuffer,
                                      uint32_t BlockIndex,
                                      uint32_t DataCount,
                                      uint32_t *ConvertedDataCount)
  uint32_t numberMCU;
  uint32_t i,j,k, currentMCU, xRef,yRef;
  uint32_t refline;
  int32_t ycomp, crcomp, cbcomp;
  int32_t c_red, c_blue, c_green;
  uint8_t *pOutAddr, *pOutAddr2;
  uint8_t *pChrom, *pLum;
  numberMCU = DataCount / YCBCR_420_BLOCK_SIZE;
  currentMCU = BlockIndex;
  while(currentMCU < (numberMCU + BlockIndex))
    xRef = ((currentMCU *16) / JPEG_ConvertorParams.WidthExtend)*16;
    yRef = ((currentMCU *16) % JPEG_ConvertorParams.WidthExtend);
    refline = JPEG_ConvertorParams.ScaLEDWidth * xRef + (JPEG_BYTES_PER_PIXEL*yRef);
    currentMCU++;
    pChrom = pInBuffer + 256; /* pChroma = pInBuffer + 4*64 */
    pLum = pInBuffer;
    for(i= 0; i <  16; i+=2)
      if(i == 8)
        pLum = pInBuffer + 128;
      if(refline < JPEG_ConvertorParams.ImageSize_Bytes)
        pOutAddr = pOutBuffer + refline;
        pOutAddr2 = pOutAddr + JPEG_ConvertorParams.ScaledWidth;
        for(k= 0; k<2; k++)
          for(j=0; j < 8; j+=2)
            cbcomp = (int32_t)(*(pChrom));
            c_blue = (int32_t)(*(CB_BLUE_LUT + cbcomp));
            crcomp = (int32_t)(*(pChrom + 64));
            c_red = (int32_t)(*(CR_RED_LUT + crcomp));
            c_green = ((int32_t)(*(CR_GREEN_LUT + crcomp)) + (int32_t)(*(CB_GREEN_LUT + cbcomp))) >> 16;
#if (JPEG_RGB_FORMAT == JPEG_ARGB8888)
            ycomp = (int32_t)(*(pLum +j));
            *(__IO uint32_t *)pOutAddr =
              (CLAMP(ycomp + c_red) << JPEG_RED_OFFSET)     | \
              (CLAMP( ycomp + c_green) << JPEG_GREEN_OFFSET) | \
              (CLAMP(ycomp + c_blue) << JPEG_BLUE_OFFSET);
            ycomp = (int32_t)(*(pLum +j +1));
            *((__IO uint32_t *)(pOutAddr + 4)) =
            ycomp = (int32_t)(*(pLum +j +8));
            *(__IO uint32_t *)pOutAddr2 =
            ycomp = (int32_t)(*(pLum +j +8 +1));
            *((__IO uint32_t *)(pOutAddr2 +4)) =
#elif (JPEG_RGB_FORMAT == JPEG_RGB888)
            pOutAddr[JPEG_RED_OFFSET/8] = CLAMP(ycomp + c_red);
            pOutAddr[JPEG_GREEN_OFFSET/8] = CLAMP(ycomp + c_green);
            pOutAddr[JPEG_BLUE_OFFSET/8] = CLAMP(ycomp + c_blue);
            pOutAddr[3 + JPEG_RED_OFFSET/8] = CLAMP(ycomp + c_red);
            pOutAddr[3 + JPEG_GREEN_OFFSET/8] = CLAMP(ycomp + c_green);
            pOutAddr[3 + JPEG_BLUE_OFFSET/8] = CLAMP(ycomp + c_blue);
            pOutAddr2[JPEG_RED_OFFSET/8] = CLAMP(ycomp + c_red);
            pOutAddr2[JPEG_GREEN_OFFSET/8] = CLAMP(ycomp + c_green);
            pOutAddr2[JPEG_BLUE_OFFSET/8] = CLAMP(ycomp + c_blue);
            pOutAddr2[3+ JPEG_RED_OFFSET/8] = CLAMP(ycomp + c_red);
            pOutAddr2[3 + JPEG_GREEN_OFFSET/8] = CLAMP(ycomp + c_green);
            pOutAddr2[3 + JPEG_BLUE_OFFSET/8] = CLAMP(ycomp + c_blue);
#elif (JPEG_RGB_FORMAT == JPEG_RGB565)       // 使用rgb565模式,地址设置貌似就在此处,但是如果按照显示画图形的方法来设置地址的话,那这个 x, y又该如何获取啊 ???
            *(__IO uint16_t *)pOutAddr =
              ((CLAMP(ycomp + c_red) >> 3) << JPEG_RED_OFFSET)     | \
              ((CLAMP( ycomp + c_green) >> 2) << JPEG_GREEN_OFFSET) | \
              ((CLAMP(ycomp + c_blue) >> 3) << JPEG_BLUE_OFFSET);
            *((__IO uint16_t *)(pOutAddr + 2)) =
            *(__IO uint16_t *)pOutAddr2 =
            *((__IO uint16_t *)(pOutAddr2 +2)) =
#endif /* JPEG_RGB_FORMAT */
            pOutAddr += JPEG_BYTES_PER_PIXEL * 2;
            pOutAddr2 += JPEG_BYTES_PER_PIXEL * 2;
            pChrom++;
          pLum += 64;
        pLum = pLum - 128 + 16;
        refline += 2*JPEG_ConvertorParams.ScaledWidth;
    pInBuffer +=  YCBCR_420_BLOCK_SIZE;
  return numberMCU;
显示效果图片如下:
正常的竖屏显示,
竖屏 180 度 显示图片如下:
这个竖屏 180度显示,字符汉字都已经正常显示了,唯独图片没有 ??
旋转180度显示图片的地址计算我是参考我的 图形显示参数修改的,显示图形任意方向显示是没有问题的
隐去 发表于 2021-8-27 12:38 | 显示全部楼层
