startup_stm32f407xx.s分析
4235|2
 楼主| keer_zu 发表于 2021-7-27 09:03 | 显示全部楼层 |阅读模式
  1.
  2.   .syntax unified
  3.   .cpu cortex-m4
  4.   .fpu softvfp
  5.   .thumb
  6. .global  g_pfnVectors
  7. .global  Default_Handler
  8. /* start address for the initialization values of the .data section.
  9. defined in linker script */
  10. .word  _sidata
  11. /* start address for the .data section. defined in linker script */
  12. .word  _sdata
  13. /* end address for the .data section. defined in linker script */
  14. .word  _edata
  15. /* start address for the .bss section. defined in linker script */
  16. .word  _sbss
  17. /* end address for the .bss section. defined in linker script */
  18. .word  _ebss
  19. /* stack used for SystemInit_ExtMemCtl; always internal RAM used */
  20. /**
  21. * [url=home.php?mod=space&uid=247401]@brief[/url]  This is the code that gets called when the processor first
  22. *          starts execution following a reset event. Only the absolutely
  23. *          necessary set is performed, after which the application
  24. *          supplied main() routine is called.
  25. * @param  None
  26. * @retval : None
  27. */
  28.     .section  .text.Reset_Handler
  29.   .weak  Reset_Handler
  30.   .type  Reset_Handler, %function
  31. Reset_Handler:
  32.   ldr   sp, =_estack     /* set stack pointer */
  33. /* Copy the data segment initializers from flash to SRAM */
  34.   movs  r1, #0
  35.   b  LoopCopyDataInit
  36. CopyDataInit:
  37.   ldr  r3, =_sidata
  38.   ldr  r3, [r3, r1]
  39.   str  r3, [r0, r1]
  40.   adds  r1, r1, #4
  41.
  42. LoopCopyDataInit:
  43.   ldr  r0, =_sdata
  44.   ldr  r3, =_edata
  45.   adds  r2, r0, r1
  46.   cmp  r2, r3
  47.   bcc  CopyDataInit
  48.   ldr  r2, =_sbss
  49.   b  LoopFillZerobss
  50. /* Zero fill the bss segment. */
  51. FillZerobss:
  52.   movs  r3, #0
  53.   str  r3, [r2], #4
  54.
  55. LoopFillZerobss:
  56.   ldr  r3, = _ebss
  57.   cmp  r2, r3
  58.   bcc  FillZerobss
  59. /* Call the clock system intitialization function.*/
  60.   bl  SystemInit
  61. /* Call static constructors */
  62. /*     bl __libc_init_array */
  63. /* Call the application's entry point.*/
  64.   bl  entry
  65.   bx  lr
  66. .size  Reset_Handler, .-Reset_Handler
  67. /**
  68. * @brief  This is the code that gets called when the processor receives an
  69. *         unexpected interrupt.  This simply enters an infinite loop, preserving
  70. *         the system state for examination by a debugger.
  71. * @param  None
  72. * @retval None
  73. */
  74.     .section  .text.Default_Handler,"ax",%progbits
  75. Default_Handler:
  76. Infinite_Loop:
  77.   b  Infinite_Loop
  78.   .size  Default_Handler, .-Default_Handler
  79. /******************************************************************************
  80. *
  81. * The minimal vector table for a Cortex M3. Note that the proper constructs
  82. * must be placed on this to ensure that it ends up at physical address
  83. * 0x0000.0000.
  84. *
  85. *******************************************************************************/
  86.    .section  .isr_vector,"a",%progbits
  87.   .type  g_pfnVectors, %object
  88.   .size  g_pfnVectors, .-g_pfnVectors
  89.
  90.
  91. g_pfnVectors:
  92.   .word  _estack
  93.   .word  Reset_Handler
  94.   .word  NMI_Handler
  95.   .word  HardFault_Handler
  96.   .word  MemManage_Handler
  97.   .word  BusFault_Handler
  98.   .word  UsageFault_Handler
  99.   .word  0
  100.   .word  0
  101.   .word  0
  102.   .word  0
  103.   .word  SVC_Handler
  104.   .word  DebugMon_Handler
  105.   .word  0
  106.   .word  PendSV_Handler
  107.   .word  SysTick_Handler
  108.
  109.   /* External Interrupts */
  110.   .word     WWDG_IRQHandler                   /* Window WatchDog              */
  111.   .word     PVD_IRQHandler                    /* PVD through EXTI Line detection */
  112.   .word     TAMP_STAMP_IRQHandler             /* Tamper and TimeStamps through the EXTI line */
  113.   .word     RTC_WKUP_IRQHandler               /* RTC Wakeup through the EXTI line */
  114.   .word     FLASH_IRQHandler                  /* FLASH                        */
  115.   .word     RCC_IRQHandler                    /* RCC                          */
  116.   .word     EXTI0_IRQHandler                  /* EXTI Line0                   */
  117.   .word     EXTI1_IRQHandler                  /* EXTI Line1                   */
  118.   .word     EXTI2_IRQHandler                  /* EXTI Line2                   */
  119.   .word     EXTI3_IRQHandler                  /* EXTI Line3                   */
  120.   .word     EXTI4_IRQHandler                  /* EXTI Line4                   */
  121.   .word     DMA1_Stream0_IRQHandler           /* DMA1 Stream 0                */
  122.   .word     DMA1_Stream1_IRQHandler           /* DMA1 Stream 1                */
  123.   .word     DMA1_Stream2_IRQHandler           /* DMA1 Stream 2                */
  124.   .word     DMA1_Stream3_IRQHandler           /* DMA1 Stream 3                */
  125.   .word     DMA1_Stream4_IRQHandler           /* DMA1 Stream 4                */
  126.   .word     DMA1_Stream5_IRQHandler           /* DMA1 Stream 5                */
  127.   .word     DMA1_Stream6_IRQHandler           /* DMA1 Stream 6                */
  128.   .word     ADC_IRQHandler                    /* ADC1, ADC2 and ADC3s         */
  129.   .word     CAN1_TX_IRQHandler                /* CAN1 TX                      */
  130.   .word     CAN1_RX0_IRQHandler               /* CAN1 RX0                     */
  131.   .word     CAN1_RX1_IRQHandler               /* CAN1 RX1                     */
  132.   .word     CAN1_SCE_IRQHandler               /* CAN1 SCE                     */
  133.   .word     EXTI9_5_IRQHandler                /* External Line[9:5]s          */
  134.   .word     TIM1_BRK_TIM9_IRQHandler          /* TIM1 Break and TIM9          */
  135.   .word     TIM1_UP_TIM10_IRQHandler          /* TIM1 Update and TIM10        */
  136.   .word     TIM1_TRG_COM_TIM11_IRQHandler     /* TIM1 Trigger and Commutation and TIM11 */
  137.   .word     TIM1_CC_IRQHandler                /* TIM1 Capture Compare         */
  138.   .word     TIM2_IRQHandler                   /* TIM2                         */
  139.   .word     TIM3_IRQHandler                   /* TIM3                         */
  140.   .word     TIM4_IRQHandler                   /* TIM4                         */
  141.   .word     I2C1_EV_IRQHandler                /* I2C1 Event                   */
  142.   .word     I2C1_ER_IRQHandler                /* I2C1 Error                   */
  143.   .word     I2C2_EV_IRQHandler                /* I2C2 Event                   */
  144.   .word     I2C2_ER_IRQHandler                /* I2C2 Error                   */
  145.   .word     SPI1_IRQHandler                   /* SPI1                         */
  146.   .word     SPI2_IRQHandler                   /* SPI2                         */
  147.   .word     USART1_IRQHandler                 /* USART1                       */
  148.   .word     USART2_IRQHandler                 /* USART2                       */
  149.   .word     USART3_IRQHandler                 /* USART3                       */
  150.   .word     EXTI15_10_IRQHandler              /* External Line[15:10]s        */
  151.   .word     RTC_Alarm_IRQHandler              /* RTC Alarm (A and B) through EXTI Line */
  152.   .word     OTG_FS_WKUP_IRQHandler            /* USB OTG FS Wakeup through EXTI line */
  153.   .word     TIM8_BRK_TIM12_IRQHandler         /* TIM8 Break and TIM12         */
  154.   .word     TIM8_UP_TIM13_IRQHandler          /* TIM8 Update and TIM13        */
  155.   .word     TIM8_TRG_COM_TIM14_IRQHandler     /* TIM8 Trigger and Commutation and TIM14 */
  156.   .word     TIM8_CC_IRQHandler                /* TIM8 Capture Compare         */
  157.   .word     DMA1_Stream7_IRQHandler           /* DMA1 Stream7                 */
  158.   .word     FSMC_IRQHandler                   /* FSMC                         */
  159.   .word     SDIO_IRQHandler                   /* SDIO                         */
  160.   .word     TIM5_IRQHandler                   /* TIM5                         */
  161.   .word     SPI3_IRQHandler                   /* SPI3                         */
  162.   .word     UART4_IRQHandler                  /* UART4                        */
  163.   .word     UART5_IRQHandler                  /* UART5                        */
  164.   .word     TIM6_DAC_IRQHandler               /* TIM6 and DAC1&2 underrun errors */
  165.   .word     TIM7_IRQHandler                   /* TIM7                         */
  166.   .word     DMA2_Stream0_IRQHandler           /* DMA2 Stream 0                */
  167.   .word     DMA2_Stream1_IRQHandler           /* DMA2 Stream 1                */
  168.   .word     DMA2_Stream2_IRQHandler           /* DMA2 Stream 2                */
  169.   .word     DMA2_Stream3_IRQHandler           /* DMA2 Stream 3                */
  170.   .word     DMA2_Stream4_IRQHandler           /* DMA2 Stream 4                */
  171.   .word     ETH_IRQHandler                    /* Ethernet                     */
  172.   .word     ETH_WKUP_IRQHandler               /* Ethernet Wakeup through EXTI line */
  173.   .word     CAN2_TX_IRQHandler                /* CAN2 TX                      */
  174.   .word     CAN2_RX0_IRQHandler               /* CAN2 RX0                     */
  175.   .word     CAN2_RX1_IRQHandler               /* CAN2 RX1                     */
  176.   .word     CAN2_SCE_IRQHandler               /* CAN2 SCE                     */
  177.   .word     OTG_FS_IRQHandler                 /* USB OTG FS                   */
  178.   .word     DMA2_Stream5_IRQHandler           /* DMA2 Stream 5                */
  179.   .word     DMA2_Stream6_IRQHandler           /* DMA2 Stream 6                */
  180.   .word     DMA2_Stream7_IRQHandler           /* DMA2 Stream 7                */
  181.   .word     USART6_IRQHandler                 /* USART6                       */
  182.   .word     I2C3_EV_IRQHandler                /* I2C3 event                   */
  183.   .word     I2C3_ER_IRQHandler                /* I2C3 error                   */
  184.   .word     OTG_HS_EP1_OUT_IRQHandler         /* USB OTG HS End Point 1 Out   */
  185.   .word     OTG_HS_EP1_IN_IRQHandler          /* USB OTG HS End Point 1 In    */
  186.   .word     OTG_HS_WKUP_IRQHandler            /* USB OTG HS Wakeup through EXTI */
  187.   .word     OTG_HS_IRQHandler                 /* USB OTG HS                   */
  188.   .word     DCMI_IRQHandler                   /* DCMI                         */
  189.   .word     0                                 /* CRYP crypto                  */
  190.   .word     HASH_RNG_IRQHandler               /* Hash and Rng                 */
  191.   .word     FPU_IRQHandler                    /* FPU                          */
  192.
  193.
  194. /*******************************************************************************
  195. *
  196. * Provide weak aliases for each Exception handler to the Default_Handler.
  197. * As they are weak aliases, any function with the same name will override
  198. * this definition.
  199. *
  200. *******************************************************************************/
  201.    .weak      NMI_Handler
  202.    .thumb_set NMI_Handler,Default_Handler
  203.
  204.    .weak      HardFault_Handler
  205.    .thumb_set HardFault_Handler,Default_Handler
  206.
  207.    .weak      MemManage_Handler
  208.    .thumb_set MemManage_Handler,Default_Handler
  209.
  210.    .weak      BusFault_Handler
  211.    .thumb_set BusFault_Handler,Default_Handler
  212.    .weak      UsageFault_Handler
  213.    .thumb_set UsageFault_Handler,Default_Handler
  214.    .weak      SVC_Handler
  215.    .thumb_set SVC_Handler,Default_Handler
  216.    .weak      DebugMon_Handler
  217.    .thumb_set DebugMon_Handler,Default_Handler
  218.    .weak      PendSV_Handler
  219.    .thumb_set PendSV_Handler,Default_Handler
  220.    .weak      SysTick_Handler
  221.    .thumb_set SysTick_Handler,Default_Handler
  222.
  223.    .weak      WWDG_IRQHandler
  224.    .thumb_set WWDG_IRQHandler,Default_Handler
  225.
  226.    .weak      PVD_IRQHandler
  227.    .thumb_set PVD_IRQHandler,Default_Handler
  228.
  229.    .weak      TAMP_STAMP_IRQHandler
  230.    .thumb_set TAMP_STAMP_IRQHandler,Default_Handler
  231.
  232.    .weak      RTC_WKUP_IRQHandler
  233.    .thumb_set RTC_WKUP_IRQHandler,Default_Handler
  234.
  235.    .weak      FLASH_IRQHandler
  236.    .thumb_set FLASH_IRQHandler,Default_Handler
  237.
  238.    .weak      RCC_IRQHandler
  239.    .thumb_set RCC_IRQHandler,Default_Handler
  240.
  241.    .weak      EXTI0_IRQHandler
  242.    .thumb_set EXTI0_IRQHandler,Default_Handler
  243.
  244.    .weak      EXTI1_IRQHandler
  245.    .thumb_set EXTI1_IRQHandler,Default_Handler
  246.
  247.    .weak      EXTI2_IRQHandler
  248.    .thumb_set EXTI2_IRQHandler,Default_Handler
  249.
  250.    .weak      EXTI3_IRQHandler
  251.    .thumb_set EXTI3_IRQHandler,Default_Handler
  252.
  253.    .weak      EXTI4_IRQHandler
  254.    .thumb_set EXTI4_IRQHandler,Default_Handler
  255.
  256.    .weak      DMA1_Stream0_IRQHandler
  257.    .thumb_set DMA1_Stream0_IRQHandler,Default_Handler
  258.
  259.    .weak      DMA1_Stream1_IRQHandler
  260.    .thumb_set DMA1_Stream1_IRQHandler,Default_Handler
  261.
  262.    .weak      DMA1_Stream2_IRQHandler
  263.    .thumb_set DMA1_Stream2_IRQHandler,Default_Handler
  264.
  265.    .weak      DMA1_Stream3_IRQHandler
  266.    .thumb_set DMA1_Stream3_IRQHandler,Default_Handler
  267.
  268.    .weak      DMA1_Stream4_IRQHandler
  269.    .thumb_set DMA1_Stream4_IRQHandler,Default_Handler
  270.
  271.    .weak      DMA1_Stream5_IRQHandler
  272.    .thumb_set DMA1_Stream5_IRQHandler,Default_Handler
  273.
  274.    .weak      DMA1_Stream6_IRQHandler
  275.    .thumb_set DMA1_Stream6_IRQHandler,Default_Handler
  276.
  277.    .weak      ADC_IRQHandler
  278.    .thumb_set ADC_IRQHandler,Default_Handler
  279.
  280.    .weak      CAN1_TX_IRQHandler
  281.    .thumb_set CAN1_TX_IRQHandler,Default_Handler
  282.
  283.    .weak      CAN1_RX0_IRQHandler
  284.    .thumb_set CAN1_RX0_IRQHandler,Default_Handler
  285.
  286.    .weak      CAN1_RX1_IRQHandler
  287.    .thumb_set CAN1_RX1_IRQHandler,Default_Handler
  288.
  289.    .weak      CAN1_SCE_IRQHandler
  290.    .thumb_set CAN1_SCE_IRQHandler,Default_Handler
  291.
  292.    .weak      EXTI9_5_IRQHandler
  293.    .thumb_set EXTI9_5_IRQHandler,Default_Handler
  294.
  295.    .weak      TIM1_BRK_TIM9_IRQHandler
  296.    .thumb_set TIM1_BRK_TIM9_IRQHandler,Default_Handler
  297.
  298.    .weak      TIM1_UP_TIM10_IRQHandler
  299.    .thumb_set TIM1_UP_TIM10_IRQHandler,Default_Handler
  300.
  301.    .weak      TIM1_TRG_COM_TIM11_IRQHandler
  302.    .thumb_set TIM1_TRG_COM_TIM11_IRQHandler,Default_Handler
  303.
  304.    .weak      TIM1_CC_IRQHandler
  305.    .thumb_set TIM1_CC_IRQHandler,Default_Handler
  306.
  307.    .weak      TIM2_IRQHandler
  308.    .thumb_set TIM2_IRQHandler,Default_Handler
  309.
  310.    .weak      TIM3_IRQHandler
  311.    .thumb_set TIM3_IRQHandler,Default_Handler
  312.
  313.    .weak      TIM4_IRQHandler
  314.    .thumb_set TIM4_IRQHandler,Default_Handler
  315.
  316.    .weak      I2C1_EV_IRQHandler
  317.    .thumb_set I2C1_EV_IRQHandler,Default_Handler
  318.
  319.    .weak      I2C1_ER_IRQHandler
  320.    .thumb_set I2C1_ER_IRQHandler,Default_Handler
  321.
  322.    .weak      I2C2_EV_IRQHandler
  323.    .thumb_set I2C2_EV_IRQHandler,Default_Handler
  324.
  325.    .weak      I2C2_ER_IRQHandler
  326.    .thumb_set I2C2_ER_IRQHandler,Default_Handler
  327.
  328.    .weak      SPI1_IRQHandler
  329.    .thumb_set SPI1_IRQHandler,Default_Handler
  330.
  331.    .weak      SPI2_IRQHandler
  332.    .thumb_set SPI2_IRQHandler,Default_Handler
  333.
  334.    .weak      USART1_IRQHandler
  335.    .thumb_set USART1_IRQHandler,Default_Handler
  336.
  337.    .weak      USART2_IRQHandler
  338.    .thumb_set USART2_IRQHandler,Default_Handler
  339.
  340.    .weak      USART3_IRQHandler
  341.    .thumb_set USART3_IRQHandler,Default_Handler
  342.
  343.    .weak      EXTI15_10_IRQHandler
  344.    .thumb_set EXTI15_10_IRQHandler,Default_Handler
  345.
  346.    .weak      RTC_Alarm_IRQHandler
  347.    .thumb_set RTC_Alarm_IRQHandler,Default_Handler
  348.
  349.    .weak      OTG_FS_WKUP_IRQHandler
  350.    .thumb_set OTG_FS_WKUP_IRQHandler,Default_Handler
  351.
  352.    .weak      TIM8_BRK_TIM12_IRQHandler
  353.    .thumb_set TIM8_BRK_TIM12_IRQHandler,Default_Handler
  354.
  355.    .weak      TIM8_UP_TIM13_IRQHandler
  356.    .thumb_set TIM8_UP_TIM13_IRQHandler,Default_Handler
  357.
  358.    .weak      TIM8_TRG_COM_TIM14_IRQHandler
  359.    .thumb_set TIM8_TRG_COM_TIM14_IRQHandler,Default_Handler
  360.
  361.    .weak      TIM8_CC_IRQHandler
  362.    .thumb_set TIM8_CC_IRQHandler,Default_Handler
  363.
  364.    .weak      DMA1_Stream7_IRQHandler
  365.    .thumb_set DMA1_Stream7_IRQHandler,Default_Handler
  366.
  367.    .weak      FSMC_IRQHandler
  368.    .thumb_set FSMC_IRQHandler,Default_Handler
  369.
  370.    .weak      SDIO_IRQHandler
  371.    .thumb_set SDIO_IRQHandler,Default_Handler
  372.
  373.    .weak      TIM5_IRQHandler
  374.    .thumb_set TIM5_IRQHandler,Default_Handler
  375.
  376.    .weak      SPI3_IRQHandler
  377.    .thumb_set SPI3_IRQHandler,Default_Handler
  378.
  379.    .weak      UART4_IRQHandler
  380.    .thumb_set UART4_IRQHandler,Default_Handler
  381.
  382.    .weak      UART5_IRQHandler
  383.    .thumb_set UART5_IRQHandler,Default_Handler
  384.
  385.    .weak      TIM6_DAC_IRQHandler
  386.    .thumb_set TIM6_DAC_IRQHandler,Default_Handler
  387.
  388.    .weak      TIM7_IRQHandler
  389.    .thumb_set TIM7_IRQHandler,Default_Handler
  390.
  391.    .weak      DMA2_Stream0_IRQHandler
  392.    .thumb_set DMA2_Stream0_IRQHandler,Default_Handler
  393.
  394.    .weak      DMA2_Stream1_IRQHandler
  395.    .thumb_set DMA2_Stream1_IRQHandler,Default_Handler
  396.
  397.    .weak      DMA2_Stream2_IRQHandler
  398.    .thumb_set DMA2_Stream2_IRQHandler,Default_Handler
  399.
  400.    .weak      DMA2_Stream3_IRQHandler
  401.    .thumb_set DMA2_Stream3_IRQHandler,Default_Handler
  402.
  403.    .weak      DMA2_Stream4_IRQHandler
  404.    .thumb_set DMA2_Stream4_IRQHandler,Default_Handler
  405.
  406.    .weak      ETH_IRQHandler
  407.    .thumb_set ETH_IRQHandler,Default_Handler
  408.
  409.    .weak      ETH_WKUP_IRQHandler
  410.    .thumb_set ETH_WKUP_IRQHandler,Default_Handler
  411.
  412.    .weak      CAN2_TX_IRQHandler
  413.    .thumb_set CAN2_TX_IRQHandler,Default_Handler
  414.
  415.    .weak      CAN2_RX0_IRQHandler
  416.    .thumb_set CAN2_RX0_IRQHandler,Default_Handler
  417.
  418.    .weak      CAN2_RX1_IRQHandler
  419.    .thumb_set CAN2_RX1_IRQHandler,Default_Handler
  420.
  421.    .weak      CAN2_SCE_IRQHandler
  422.    .thumb_set CAN2_SCE_IRQHandler,Default_Handler
  423.
  424.    .weak      OTG_FS_IRQHandler
  425.    .thumb_set OTG_FS_IRQHandler,Default_Handler
  426.
  427.    .weak      DMA2_Stream5_IRQHandler
  428.    .thumb_set DMA2_Stream5_IRQHandler,Default_Handler
  429.
  430.    .weak      DMA2_Stream6_IRQHandler
  431.    .thumb_set DMA2_Stream6_IRQHandler,Default_Handler
  432.
  433.    .weak      DMA2_Stream7_IRQHandler
  434.    .thumb_set DMA2_Stream7_IRQHandler,Default_Handler
  435.
  436.    .weak      USART6_IRQHandler
  437.    .thumb_set USART6_IRQHandler,Default_Handler
  438.
  439.    .weak      I2C3_EV_IRQHandler
  440.    .thumb_set I2C3_EV_IRQHandler,Default_Handler
  441.
  442.    .weak      I2C3_ER_IRQHandler
  443.    .thumb_set I2C3_ER_IRQHandler,Default_Handler
  444.
  445.    .weak      OTG_HS_EP1_OUT_IRQHandler
  446.    .thumb_set OTG_HS_EP1_OUT_IRQHandler,Default_Handler
  447.
  448.    .weak      OTG_HS_EP1_IN_IRQHandler
  449.    .thumb_set OTG_HS_EP1_IN_IRQHandler,Default_Handler
  450.
  451.    .weak      OTG_HS_WKUP_IRQHandler
  452.    .thumb_set OTG_HS_WKUP_IRQHandler,Default_Handler
  453.
  454.    .weak      OTG_HS_IRQHandler
  455.    .thumb_set OTG_HS_IRQHandler,Default_Handler
  456.
  457.    .weak      DCMI_IRQHandler
  458.    .thumb_set DCMI_IRQHandler,Default_Handler
  459.
  460.    .weak      HASH_RNG_IRQHandler
  461.    .thumb_set HASH_RNG_IRQHandler,Default_Handler
  462.    .weak      FPU_IRQHandler
  463.    .thumb_set FPU_IRQHandler,Default_Handler
 楼主| keer_zu 发表于 2021-7-27 09:15 | 显示全部楼层
  1.     .section  .text.Reset_Handler
  2.   .weak  Reset_Handler
  3.   .type  Reset_Handler, %function
  4. Reset_Handler:
  5.   ldr   sp, =_estack     /* set stack pointer */
  6. /* Copy the data segment initializers from flash to SRAM */
  7.   movs  r1, #0
  8.   b  LoopCopyDataInit
  9. CopyDataInit:
  10.   ldr  r3, =_sidata
  11.   ldr  r3, [r3, r1]
  12.   str  r3, [r0, r1]
  13.   adds  r1, r1, #4
  14.
  15. LoopCopyDataInit:
  16.   ldr  r0, =_sdata
  17.   ldr  r3, =_edata
  18.   adds  r2, r0, r1
  19.   cmp  r2, r3
  20.   bcc  CopyDataInit
  21.   ldr  r2, =_sbss
  22.   b  LoopFillZerobss
  23. /* Zero fill the bss segment. */
  24. FillZerobss:
  25.   movs  r3, #0
  26.   str  r3, [r2], #4
  27.
  28. LoopFillZerobss:
  29.   ldr  r3, = _ebss
  30.   cmp  r2, r3
  31.   bcc  FillZerobss
系统复位后,从Rest_Handler:处执行。
首先设置栈指针
将数据段从flash拷贝到SRAM/* Copy the data segment initializers from flash to SRAM */
用0填充bss段/* Zero fill the bss segment. */
 楼主| keer_zu 发表于 2021-7-27 09:18 | 显示全部楼层
  1. /* Call the clock system intitialization function.*/
  2.   bl  SystemInit
  3. /* Call static constructors */
  4. /*     bl __libc_init_array */
  5. /* Call the application's entry point.*/
  6.   bl  entry
  7.   bx  lr
  8. .size  Reset_Handler, .-Reset_Handler
初始化时钟系统,然后跳转到application
1497
