请问我用状态机编程密码锁的程序还有什么问题吗?
3464|0
 楼主| cr315 发表于 2021-8-23 11:51 | 显示全部楼层 |阅读模式
[C] 纯文本查看 复制代码
#include <reg52.h>#include <intrins.h>#include <stdio.h>#include <stdlib.h>#include <string.h> typedef enum{        STATE0 = 0,        STATE1,        STATE2,        STATE3,STATE4,        }STATE;STATE current_state = STATE0;#define uint unsigned int#define uchar unsigned char#define DataPort P0 #define RS_CLR RS=0 #define RS_SET RS=1#define RW_CLR RW=0 #define RW_SET RW=1 #define EN_CLR EN=0#define EN_SET EN=1sbit RS = P2^4;   //?¨??????,?è?? sbit RW = P2^5;sbit EN = P2^6;uchar key=20,ch;uchar table[]={'1','2','3','4','5','6','7','8','9','0'};void delayms(uint);void LCD_show();void test();void delayms(uint xms){     uint i,j; for(i=xms;i>0;i--)     for(j=110;j>0;j--);}//           1602????/*------------------------------------------------              ?????ü??????M------------------------------------------------*/ void LCD_Write_Com(unsigned char com)  {   delayms(5); RS_CLR;  RW_CLR;  EN_SET;  DataPort= com;  _nop_();  EN_CLR; }  /*------------------------------------------------              ????????????------------------------------------------------*/void LCD_Write_Data(unsigned char Data)  {  //while(LCD_Check_Busy()); //???ò???? delayms(5); RS_SET;  RW_CLR;  EN_SET;  DataPort= Data;  _nop_(); EN_CLR; } /*------------------------------------------------                ????????------------------------------------------------*/  void LCD_Clear(void)  {  LCD_Write_Com(0x01);  delayms(5); } /*------------------------------------------------              ????×?·??®????------------------------------------------------*/  void LCD_Write_String(uchar x,uchar y,uchar *s)  {      IF (y == 0)  {      LCD_Write_Com(0x80 + x);      } else  {      LCD_Write_Com(0xC0 + x);      }         while (*s)  {      LCD_Write_Data( *s);      s ++;      } }/*------------------------------------------------              ????×?·?????------------------------------------------------*/ void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)  {      if (y == 0)  {      LCD_Write_Com(0x80 + x);      }     else  {      LCD_Write_Com(0xC0 + x);      }         LCD_Write_Data( Data);   } /*------------------------------------------------              ??????????------------------------------------------------*/ void LCD_Init(void)  {   LCD_Write_Com(0x38);    /*?????????è??*/    delayms(5);    LCD_Write_Com(0x38);    delayms(5);    LCD_Write_Com(0x38);    delayms(5);    LCD_Write_Com(0x38);     LCD_Write_Com(0x08);    /*??????±?*/    LCD_Write_Com(0x01);    /*????????*/    LCD_Write_Com(0x06);    /*??????±ê?????è??*/    delayms(5);    LCD_Write_Com(0x0C);    /*???????°??±ê?è??*/}//???ó?ü?? void matrixkeyscan(){uchar temp;P3=0xfe;temp=P3;temp=temp&0xf0;if(temp!=0xf0){   delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xee: key=11; break; case 0xde: key=3; break; case 0xbe: key=2; break; case 0x7e: key=1; break;}while(temp!=0xf0){   temp=P3; temp=temp&0xf0;}}}P3=0xfd;temp=P3;temp=temp&0xf0;if(temp!=0xf0){   delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xed: key=12; break; case 0xdd: key=6; break; case 0xbd: key=5;  break; case 0x7d: key=4;  break;}while(temp!=0xf0){   temp=P3; temp=temp&0xf0;}}}P3=0xfb;temp=P3;temp=temp&0xf0;if(temp!=0xf0){   delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xeb: key=13; break; case 0xdb: key=9;  break; case 0xbb: key=8;  break; case 0x7b: key=7; break;}while(temp!=0xf0){   temp=P3; temp=temp&0xf0;}}}P3=0xf7;temp=P3;temp=temp&0xf0;if(temp!=0xf0){   delayms(10); temp=P3; temp=temp&0xf0; if(temp!=0xf0) { temp=P3; switch(temp) { case 0xe7: key=16; break; case 0xd7: key=12; break; case 0xb7: key=11; break; case 0x77: key=10; break;}while(temp!=0xf0){   temp=P3; temp=temp&0xf0;}}}}uchar datadeal(){ if(key<=10) return table[key-1]; else return 0xff;}void main(){uchar k,i;LCD_Init();LCD_Write_Com(0x0F);LCD_Write_String(1,0,\"Input the code\");delayms(2000);while(1){  for(i=0;i<4;) { matrixkeyscan();while((ch!=datadeal())&&(datadeal()!=0xff))  {ch=datadeal();LCD_Write_Char(0+k,1,ch);//????????????×?·?k++;  switch(current_state){  case STATE0:        if(ch == '2')   current_state = STATE1;        break;case STATE1:        if(ch == '4')   current_state = STATE2;        break;        case STATE2:      if(ch == '7')   current_state = STATE3;        break;        case STATE3:        if(ch == '9')   current_state = STATE4;  break;        default:        current_state = STATE0;        break;        }i++;}}k=0;        if(current_state == STATE4){  LCD_Clear();  delayms(10);LCD_Write_Com(0x0c);    LCD_Write_String(4,0,\"Correct\");  LCD_Write_String(2,1,\"Lock is open\");        current_state =   STATE0;while(1);        }else       {        LCD_Clear();  LCD_Write_String(4,0,\"Wrong\");  LCD_Write_String(1,1,\"Lock is closed\");        current_state =  STATE0;       }        break;  }delayms(2000);}这是我第一次用状态机的概念来编程,程序比较小,功能也比较简单,就是用矩阵键盘输入数字,1602液晶显示,不过与一般密码锁有所不同,我用状态机来比较输入的数字与正确数字,感觉比较简单,但是,还有很多不足:输入的数字无法显示最后一位,但是状态机可以判断(这个暂时未解决,希望大家给些建议);本来想把是1602显示的部分和状态机部分分别做成函数,但是那样运行不成功,就这样写了,程序看起来不太清晰,望提宝贵意见
