[技术讨论] 刚开始用gd32f450-EVAL开发板,求一个ADC2的实例
5297|2
 楼主| lxy962301 发表于 2021-8-26 16:19 | 显示全部楼层 |阅读模式
ADC2获取电压值读不出来,demo例程也没有,请问哪位有没有实例?
tyw 发表于 2021-8-26 17:19 | 显示全部楼层
 楼主| lxy962301 发表于 2021-8-27 14:40 | 显示全部楼层
int main(void)
    /* system clocks configuration */
    rcu_config();
    /* systick configuration */
    systick_config();
    /* GPIO configuration */
    gpio_config();
    /* DMA configuration */
    dma_config();
    /* ADC configuration */
    adc_config();
    /* configure COM port */
    gd_eval_com_init(EVAL_COM0);
    while(1){
        delay_1ms(1000);
        printf("\r\n *******************************");
        printf("\r\n ADC2 regular channel data = %5.4fV\r\n", adc_value[0]*3.3/4096);
    \brief      configure the different system clocks
    \param[in]  none
    \param[out] none
    \retval     none
void rcu_config(void)
    /* enable GPIOC clock */
    rcu_periph_clock_enable(RCU_GPIOF);
    /* enable ADC clock */
    rcu_periph_clock_enable(RCU_ADC2);
    /* enable timer1 clock */
    rcu_periph_clock_enable(RCU_TIMER1);
    rcu_timer_clock_prescaler_config(RCU_TIMER_PSC_MUL4);
    /* enable DMA clock */
    rcu_periph_clock_enable(RCU_DMA1);
    /* config ADC clock */
    adc_clock_config(ADC_ADCCK_PCLK2_DIV6);
    \brief      configure the GPIO peripheral
    \param[in]  none
    \param[out] none
    \retval     none
void gpio_config(void)
    /* config the GPIO as analog mode */
    //gpio_mode_set(GPIOF, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10);
    gpio_mode_set(GPIOF, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_6);
    \brief      configure the DMA peripheral
    \param[in]  none
    \param[out] none
    \retval     none
void dma_config(void)
    /* ADC_DMA_channel configuration */
    dma_single_data_parameter_struct dma_single_data_parameter;
    /* ADC DMA_channel configuration */
    dma_deinit(DMA1, DMA_CH0);
    /* initialize DMA single data mode */
    dma_single_data_parameter.periph_addr = (uint32_t)(&ADC_RDATA(ADC2));
    dma_single_data_parameter.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
    dma_single_data_parameter.memory0_addr = (uint32_t)(adc_value);
    dma_single_data_parameter.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
    dma_single_data_parameter.periph_memory_width = DMA_PERIPH_WIDTH_16BIT;
    dma_single_data_parameter.direction = DMA_PERIPH_TO_MEMORY;
    dma_single_data_parameter.number = 1;
    dma_single_data_parameter.priority = DMA_PRIORITY_HIGH;
    dma_single_data_mode_init(DMA1, DMA_CH0, &dma_single_data_parameter);
    dma_channel_subperipheral_select(DMA1, DMA_CH0, DMA_SUBPERI0);
    /* enable DMA circulation mode */
    dma_circulation_enable(DMA1, DMA_CH0);
    /* enable DMA channel */
    dma_channel_enable(DMA1, DMA_CH0);
    \brief      configure the ADC peripheral
    \param[in]  none
    \param[out] none
    \retval     none
void adc_config(void)
    /* ADC mode config */
    adc_sync_mode_config(ADC_SYNC_MODE_INDEPENDENT);
    /* ADC contineous function disable */
    adc_special_function_config(ADC2, ADC_CONTINUOUS_MODE, ENABLE);
    /* ADC scan mode disable */
    adc_special_function_config(ADC2, ADC_SCAN_MODE, ENABLE);
    /* ADC data alignment config */
    adc_data_alignment_config(ADC2, ADC_DATAALIGN_RIGHT);
    /* ADC channel length config */
    adc_channel_length_config(ADC2, ADC_REGULAR_CHANNEL, 1);
    /* ADC regular channel config */
    adc_regular_channel_config(ADC2, 0, ADC_CHANNEL_4, ADC_SAMPLETIME_15);
    //adc_regular_channel_config(ADC0, 1, ADC_CHANNEL_2, ADC_SAMPLETIME_15);
    //adc_regular_channel_config(ADC0, 2, ADC_CHANNEL_3, ADC_SAMPLETIME_15);
    //adc_regular_channel_config(ADC0, 3, BOARD_ADC_CHANNEL, ADC_SAMPLETIME_15);
    /* ADC trigger config */
    adc_external_trigger_source_config(ADC2, ADC_REGULAR_CHANNEL, ADC_EXTTRIG_REGULAR_T0_CH0);
    adc_external_trigger_config(ADC2, ADC_REGULAR_CHANNEL, EXTERNAL_TRIGGER_DISABLE);
    /* ADC DMA function enable */
    adc_dma_request_after_last_enable(ADC2);
    adc_dma_mode_enable(ADC2);
    /* enable ADC interface */
    adc_enable(ADC2);
    /* wait for ADC stability */
    delay_1ms(1);
    /* ADC calibration and reset calibration */
    adc_calibration_enable(ADC2);
    /* enable ADC software trigger */
    adc_software_trigger_enable(ADC2, ADC_REGULAR_CHANNEL);
这个程序是官方demo改的,AD0可以正常获取数据,但是AD2不行,为什么??
