[应用相关] STM32F407VET6两个CAN同时工作
786|1
 楼主| 磨砂 发表于 2021-9-7 08:12 | 显示全部楼层 |阅读模式
一、注意点
两个CAN接口同时工作主要是初始化的时候必须一起使能时钟
二、代码分享
u8 can_init(u8 tsjw,u8 tbs2,u8 tbs1,u16 brp,u8 mode)
        u16 std_id_1 =0x123;
        u16 std_id_2 =0x123;
        CAN_InitTypeDef        CAN_InitStructure;
        CAN_FilterInitTypeDef  CAN_FilterInitStructure;
        #if CAN1_RX0_INT_ENABLE
        NVIC_InitTypeDef  NVIC_InitStructure;
        #endif
        //使能相关时钟
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);//使能PORTA时钟
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//使能PORTA时钟
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);//使能CAN1时钟
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN2, ENABLE);//使能CAN1时钟
        //初始化GPIO
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11| GPIO_Pin_12;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
        GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化PA11,PA12
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5| GPIO_Pin_6;
        GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化PA12,PA13
        //引脚复用映射配置
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource11,GPIO_AF_CAN1); //GPIOA11复用为CAN1
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource12,GPIO_AF_CAN1); //GPIOA12复用为CAN1
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource5,GPIO_AF_CAN2); //GPIOA11复用为CAN2
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource6,GPIO_AF_CAN2); //GPIOA12复用为CAN2
        //CAN单元设置
        CAN_InitStructure.CAN_TTCM=DISABLE;        //非时间触发通信模式
        CAN_InitStructure.CAN_ABOM=DISABLE;        //软件自动离线管理
        CAN_InitStructure.CAN_AWUM=DISABLE;//睡眠模式通过软件唤醒(清除CAN->MCR的SLEEP位)
        CAN_InitStructure.CAN_NART=ENABLE;        //禁止报文自动传送
        CAN_InitStructure.CAN_RFLM=DISABLE;        //报文不锁定,新的覆盖旧的
        CAN_InitStructure.CAN_TXFP=DISABLE;        //优先级由报文标识符决定
        CAN_InitStructure.CAN_Mode= mode;         //模式设置
        CAN_InitStructure.CAN_SJW=tsjw;        //重新同步跳跃宽度(Tsjw)为tsjw+1个时间单位 CAN_SJW_1tq~CAN_SJW_4tq
        CAN_InitStructure.CAN_BS1=tbs1; //Tbs1范围CAN_BS1_1tq ~CAN_BS1_16tq
        CAN_InitStructure.CAN_BS2=tbs2;//Tbs2范围CAN_BS2_1tq ~        CAN_BS2_8tq
        CAN_InitStructure.CAN_Prescaler=brp;  //分频系数(Fdiv)为brp+1
        CAN_Init(CAN1, &CAN_InitStructure);   // 初始化CAN1
        CAN_Init(CAN2, &CAN_InitStructure);   // 初始化CAN2
        //配置过滤器
        CAN_FilterInitStructure.CAN_FilterNumber=0;          //过滤器0
        CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask; //屏蔽模式
        CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit; //32位
        CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;32位ID
        CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
        CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;//32位MASK
        CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
        CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_Filter_FIFO0;//过滤器0关联到FIFO0
        CAN_FilterInitStructure.CAN_FilterActivation=ENABLE; //激活过滤器0
        CAN_FilterInit(&CAN_FilterInitStructure);//滤波器初始化
        CAN_FilterInitStructure.CAN_FilterNumber=14; //过滤器14
        CAN_FilterInit(&CAN_FilterInitStructure);  //CAN2
        CAN_ITConfig(CAN1,CAN_IT_FMP0,ENABLE);//FIFO0消息挂号中断允许.
        NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX0_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;     // 主优先级为1
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;            // 次优先级为0
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        #endif
        #if CAN2_RX0_INT_ENABLE
        CAN_ITConfig(CAN2,CAN_IT_FMP0,ENABLE);//FIFO0消息挂号中断允许.
        NVIC_InitStructure.NVIC_IRQChannel = CAN2_RX0_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;            // 次优先级为0
        #endif
        return 0;
caigang13 发表于 2021-9-7 08:36 来自手机 | 显示全部楼层
谢谢分享经验
