[verilog] 一种浅显的脉宽控制的方案
6451|0
 楼主| 邹逸谦 发表于 2021-9-30 10:52 | 显示全部楼层 |阅读模式
module bx (
    input        clk,
    input        rst_n,
    input        laser_tx_en,
    input [24:0] pwm_width,
    input [24:0] pwm_cycle,
    input [5:0]  laser_tx_num,
    output     laser_on,
    output     frame_sync,
    output     laser_tx_done
    reg  [24 : 0]   pwm_cnt;
    reg             laser_on_i;
    reg  [5:0]  num_cnt;
    always @(posedge clk or negedge rst_n) begin
        if (~rst_n) begin
            pwm_cnt    <= 25'd0;
        end
        else if (laser_tx_en)  begin
            if (pwm_cnt == pwm_cycle)  begin
                pwm_cnt    <= 25'd0;
            end
            else
                pwm_cnt    <= pwm_cnt + 25'd1;
        end
        else
            pwm_cnt   <=  25'd0;
    end
        if (~rst_n) begin
            laser_on_i   <=  1'd0;
        end
            case (num_cnt > laser_tx_num)
                1'b1: laser_on_i   <=  1'd0;
                1'b0:if (pwm_cnt <= pwm_width) begin
                        laser_on_i   <=  1'd1;
                    end
                    else if (pwm_cnt >= pwm_width) begin
                        laser_on_i   <=  1'd0;
                    end
                    else
                        laser_on_i   <=  laser_on_i;
                default: laser_on_i  <=  1'd0;
            endcase
        end
    end
        if (~rst_n) begin
            num_cnt    <=  6'd0;
        end
        else if (pwm_cnt == pwm_cycle)begin
            num_cnt    <=  num_cnt + 6'd1;
        end
        else if (num_cnt > laser_tx_num) begin
            num_cnt    <=  6'd0;
        end
    end
    assign   laser_on        =  laser_on_i;
    assign   frame_sync      =  ((pwm_cnt == 1) & laser_on_i) ? 1'd1 : 1'd0;
    assign   laser_tx_done   =  (num_cnt > laser_tx_num) ? 1'd1 : 1'd0;
endmodule
控制脉冲与发射次数,达到一般的通用水准。
