[其他模拟产品-信号链]
CC2541 2.4GHz蓝牙低功耗连接解决方案
8492|21
lirfv|  楼主 | 2012-3-20 22:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TI公司的CC2541是2.4GHz蓝牙低功耗系统级芯片(SoC),支持250kbps, 500kbps, 1Mbps和2Mbps数据速率,具有极好的连接预算,应用时不外接前端,输出功率可编程到0dBm, 1Mbps时的接收灵敏度为-94dBm,主要用在2.4GHz蓝牙低功耗系统,个人2.4GHz系统,人机接口如键盘,鼠标和遥控等,体育和休闲设备,手机附件和消费类电子.本文介绍了CC2541主要特性,方框图, 应用电路图和CC2541评估模块主要特性,电路图和材料清单以及采用TPS62370的CC2541EM电源电路图和材料清单.
The CC2541 is a power-optimized true system-on-chip (SoC) solution for both low energy and proprietary 2.4-GHz applications. It enables robust network nodes to be built with low total bill-of-material costs. The CC2541 combines the excellent performance of a leading RF transceiver with an industry-standard enhanced 8051 MCU, in-system programmable flash memory, 8-KB RAM, and many other powerful supporting features and peripherals. The CC2541 is highly suited for systems where ultralow power consumption is required. This is specified by various operating modes. Short transition times between operating modes further enable low power consumption.
The CC2541 is pin-compatible with the CC2540 in the 6-mm × 6-mm QFN40 package, if the USB is not used on the CC2540 and the I2C/extra I/O is not used on the CC2541.
CC2541主要特性:
CC2541 WITH TPS62730
• TPS62730 is a 2-MHz Step-Down Converter With Bypass Mode
• Extends Battery Lifetime by up to 20%
• Reduced Current in All Active Modes
• 30-nA Bypass Mode Current to Support
• RF Performance Unchanged
• Small Package Allows for Small Solution Size
• CC2541 Controllable
CC2541应用:
• 2.4-GHz Bluetooth low energy Systems
• Proprietary 2.4-GHz Systems
• Human-Interface Devices (Keyboard, Mouse, Remote Control)
• Sports and Leisure Equipment
• Mobile Phone Accessories
• Consumer Electronics
图1.CC2541方框图
图2.CC2541应用电路图
CC2541评估模块
The CC2541 Evaluation Module Kit contains two CC2541 Bluetooth low energy Evaluation Modules, which can be used either as standalone modules (requires a power source and a simple carrier board like the SoC Battery Board or connected to e.g. the SmartRF05EB Evaluation Boards (included in the CC2540DK) for full control from the PC.
The evaluation modules can be used as a reference board for prototyping and for verifying the performance of the CC2541 RF IC.
CC2541评估模块主要特性:
The CC2541EMK includes:
 2 x CC2541EM Evaluation Modules
 2 x 2.4 GHz Antennas
 Documentation
图3.CC2541评估模块外形图
注:CC2541评估模块要和CC2540DK开发套件的SmartRF05EB一起使用.
图4.CC2541评估模块电路图
CC2541评估模块材料清单见:
图5.CC2541评估模块采用TPS62370的电源电路图
woody_yao| | 2012-3-31 08:52 | 只看该作者
这个IC的价格怎样?
wewo| | 2012-4-2 10:52 | 只看该作者
哇 不错 很有参考价值呢 不知楼主哪找的呢
我估计价格不便宜呢
jimmy.wu| | 2012-8-7 10:35 | 只看该作者
手上有套件,谁搞过一起交流交流啊
shenmu2012| | 2012-8-7 14:15 | 只看该作者
这个跟单片机是怎样通讯的呢?我看了下,还没看出来的啊
czdo| | 2012-8-7 21:51 | 只看该作者
蓝牙ble的方案?
wuyingte| | 2012-10-22 09:48 | 只看该作者
提示: 该帖被管理员或版主屏蔽
comeon201208| | 2012-10-22 12:40 | 只看该作者
看着还不错的,先收下啦
ztfmtk| | 2013-1-22 19:28 | 只看该作者
不错, 不知价位如何
hawksabre| | 2013-1-22 20:19 | 只看该作者
感觉这套方案价格应该不便宜   呵呵   顶一个  图片看不见啊  呵呵
vivilzb1985| | 2013-1-23 13:31 | 只看该作者
是啊,大家说的是,看下价位的啊
Dengyu| | 2013-7-1 10:45 | 只看该作者
价格也不贵,欢迎来电咨询:13751097661 邓生
trumpxp| | 2013-7-2 19:23 | 只看该作者
看看先    有时间   想搞搞
hawksabre| | 2013-7-3 19:02 | 只看该作者
学习学习    资料很不错    有时间   需要好好看看    很不错   楼主
hudi008| | 2013-7-4 00:08 | 只看该作者
谢谢分享的。
数码小叶| | 2014-8-23 09:54 | 只看该作者
想学,不知到从哪入门啊
电子小侠客| | 2014-8-25 17:08 | 只看该作者
这个资料很有用,学习了
lzmm| | 2014-8-26 21:19 | 只看该作者
lzmm| | 2014-8-26 21:20 | 只看该作者
给力呢
