STM32F103RE的闹钟中断问题求教
1984|1
 楼主| NIKEjian 发表于 2022-1-9 18:37 | 显示全部楼层 |阅读模式
使用的是正点原子的例子,但是用的是LSI最为时钟源,但是一直复位,不懂为什么,有没有老哥解答一下的,main函数里面有一个打印,上电之后就是一直刷那个打印static void RTC_NVIC_Config(void)
  NVIC_InitTypeDef NVIC_InitStructure;
        EXTI_InitTypeDef EXTI_InitStructure;
        NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQn;                //RTCÈ«¾ÖÖжÏ
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;        //ÏÈÕ¼ÓÅÏȼ¶1λ,´ÓÓÅÏȼ¶3λ
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;        //ÏÈÕ¼ÓÅÏȼ¶0λ,´ÓÓÅÏȼ¶4λ
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                //ʹÄܸÃͨµÀÖжÏ
        NVIC_Init(&NVIC_InitStructure);                //¸ù¾ÝNVIC_InitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ÍâÉèNVIC¼Ä´æÆ÷
        NVIC_InitStructure.NVIC_IRQChannel =RTCAlarm_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelCmd =ENABLE;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =1;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority =1;
        EXTI_ClearITPendingBit(EXTI_Line17);
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Line = EXTI_Line17;
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
//ʵʱʱÖÓÅäÖÃ
//³õʼ»¯RTCʱÖÓ,ͬʱ¼ì²âʱÖÓÊÇ·ñ¹¤×÷Õý³£
//BKP->DR1ÓÃÓÚ±£´æÊÇ·ñµÚÒ»´ÎÅäÖõÄÉèÖÃ
//·µ»Ø0:Õý³£
//ÆäËû:´íÎó´úÂë
u8 RTC_Init(void)
        //¼ì²éÊDz»ÊǵÚÒ»´ÎÅäÖÃʱÖÓ
        u8 temp=0;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE);        //ʹÄÜPWRºÍBKPÍâÉèʱÖÓ
        PWR_BackupAccessCmd(ENABLE);        //ʹÄܺ󱸼ĴæÆ÷·ÃÎÊ
                BKP_DeInit();        //¸´Î»±¸·ÝÇøÓò
                RCC_LSICmd(ENABLE);        //ÉèÖÃÍⲿµÍËÙ¾§Õñ(LSE),ʹÓÃÍâÉèµÍËÙ¾§Õñ
                while (RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET)        //¼ì²éÖ¸¶¨µÄRCC±ê־λÉèÖÃÓë·ñ,µÈ´ýµÍËÙ¾§Õñ¾ÍÐ÷
                        temp++;
                        delay_ms(10);
                if(temp>=250)return 1;//³õʼ»¯Ê±ÖÓʧ°Ü,¾§ÕñÓÐÎÊÌâ
                RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);                //ÉèÖÃRTCʱÖÓ(RTCCLK),Ñ¡ÔñLSE×÷ΪRTCʱÖÓ
                RCC_RTCCLKCmd(ENABLE);        //ʹÄÜRTCʱÖÓ
                RTC_WaitForLastTask();        //µÈ´ý×î½üÒ»´Î¶ÔRTC¼Ä´æÆ÷µÄд²Ù×÷Íê³É
                RTC_WaitForSynchro();                //µÈ´ýRTC¼Ä´æÆ÷ͬ²½
                RTC_ITConfig(RTC_IT_SEC|RTC_IT_ALR, ENABLE);                //ʹÄÜRTCÃëÖжϺÍÄÖÖÓÖжÏ
                RTC_EnterConfigMode();/// ÔÊÐíÅäÖà
                RTC_SetPrescaler(39999); //ÉèÖÃRTCÔ¤·ÖƵµÄÖµ
        RTC_SetCounter(0);                            //??????0s
        /* Wait until last write operation on RTC registers has finished */
        //????WORK_TIMES
        RTC_SetAlarm(10);
                RTC_ExitConfigMode(); //Í˳öÅäÖÃģʽ
        RTC_NVIC_Config();//RCTÖжϷÖ×éÉèÖà
    printf("Time is  =%d \r\n",RTC_GetCounter()); //???????
        return 0; //ok
//RTCʱÖÓÖжÏ
//ÿÃë´¥·¢Ò»´Î
extern int count;
void RTC_IRQHandler(void)
        if(RTC_GetITStatus(RTC_IT_SEC)!=RESET)
                RTC_ClearITPendingBit(RTC_IT_OW|RTC_IT_SEC);
//ÄÖÖÓÖжÏ
void RTCAlarm_IRQHandler(void)
        if(RTC_GetITStatus(RTC_IT_ALR) != RESET)
                 printf("THE ALARM  READY =%d \r\n",RTC_GetCounter());//???????
                          RTC_ClearITPendingBit(RTC_IT_ALR);
                          RTC_SetAlarm(10+RTC_GetCounter());        //???????40s?
                          PWR_BackupAccessCmd(DISABLE);
ar3000a 发表于 2022-2-10 02:48 | 显示全部楼层
没看到main
打印内容,好几个地方都打印同样内容,咋区分?
