[华山论剑] KF8TS2508触摸按键实现(不使用官方触摸按键算法库)
3677|7
 楼主| Bengor 发表于 2022-1-24 17:58 | 显示全部楼层 |阅读模式
如果仅仅使用单路或几路触摸按键,我个人觉得官方的算法库太复杂了,所以自己写了一套单路触摸按键的代码。第一次接触芯旺的MCU,芯片规格书等技术文档相对简陋,摸索了一个多星期才写出来,测试了IO口、定时器和PWM等功能,代码有点乱,没来得及整理好。仅供大家讨论和参考,也欢迎大家指点一二。
这套代码可以检测触摸按下/松开和长按等状态,实现多种按键识别功能,可调整_Touch_Recognition的值来调节触摸灵敏度,可自适应环境变化定时调整电容触摸基准值。摘取部分代码如下,详细请看附件。
#define _TMR1_FD            5  //20us
#define _TMR0_FD            2  //10ms
#define _KeyDetectCounter   10 //count for key conform (double check)
#define _DCIntervalTime     50 //double click valid time 500ms, unit:10ms
#define _T0UserModeChange   300 //3s
#define _Time0_UpDate_CPS   30  //300ms
#define _Touch_Recognition  1000  //sensitivity of touch
//#define _Touch_Recognition  5000
typedef enum
    _Key_Press,
    _Key_Release
} __Key;
void Init()
    OSCCTL = 0b01100000;//8MHz
        P0LR = 0b00000000;
        TR0 = 0b00011000; //set P0 port to input
        PUR0 = 0b00000000; //pull up
        IOCL = 0b00000000; //IOC
        P1LR = 0b00000000;
        TR1 = 0b00000100; //set P12 port to input
        PUR1 = 0b00000000; //pull up
        P2LR = 0b00000000;
        TR2 = 0b00000100; //set P12 port to input
        PUR2 = 0b00000000; //pull up
        ANSEH = 0b00100010; //AN13 AN9
        ANSEL = 0b00000000;
        OPTR = 0b00000101; //1:64
        T0 = 100; //5ms
        PP1 = 250; //PWM 4K,TOP value 250
        PWM1L = 0;
        T1CTL = 0b00010001; //T1 enable, 1:2
        CTCTL0 = 0b10101010; //touch enable channel p1.2
        CTCTL1 = 0b01000000; //touch clk 1:8
        CTCTL2 = 0b00000000; //single trigger
        VDAC = 0b11110000; //0.8VDAC
        VRES = 0b10000000; //0.65VDAC
        VDACS = 0b01000000; //vref
        VRECTL = 0b01010010; //Vref 2V, enable
//        T3CTL = 0b11100000;//T3 enable, 1:8
        T4CTL = 0b10010000; //T4 1:2 0.25us
        T4H = 252;
        T4L = 223;
        TMR4_Start();
        PCTL = 0b00011000; //IPEN enable
        EIE2 = 0b10000000; //T3
        EIE3 = 0b10000000; //T4
        IP2 = 0b10000000; //T3 interrupt high
        IP3 = 0b10000000; //T4 interrupt high
        INTCTL = 0b00100000;
        Interrupt_Enable();
void TMR0_Reload()
        T0 = _TMR0_5MS; //5ms
void TouchReStart()
        T3CLR = 1;
        CTSTART = 1;
void TMR3_CLEAR()
        T3CLR = 0;
uint16 GetTMR3Value()
        uint16 tempValue;
        tempValue = (T3H << 8) | T3L;
        TMR3_CLEAR(); //clear the T3H and T3L for next CT detect
        return tempValue;
void TouchDetect()
        if(Get_Raw_CTData_Flag == true)
                Get_Raw_CTData_Flag = false;
                Raw_CTData = GetTMR3Value();
                Raw_CTData_Counter++;
                New_CTData = New_CTData + Raw_CTData;
                if(Raw_CTData_Counter >= 2)
                        if(Old_CTData == 0)
                                Old_CTData = New_CTData;
                        else if(New_CTData != Old_CTData)
                                if(New_CTData > Old_CTData)
                                        Diff_CTData = New_CTData - Old_CTData;
                                        if(Diff_CTData > _Touch_Recognition && GetKeyChangeFlag == true)
                                                tempKey = _Key_Release;
                                                T0_10ms_Update_CTData = 0;
                                        else
                                                if(tempKey != _Key_Press)
                                                        Old_CPS_UpDate();
                                else
                                        Diff_CTData = Old_CTData - New_CTData;
                                                tempKey = _Key_Press;
                                        else
                                                Old_CPS_UpDate();
                        New_CTData = 0;
                        Raw_CTData_Counter = 0;
void KeyDetect()
    if(Key != tempKey)
                if(T0_5ms_Key >= 1) //5ms
                        T0_5ms_Key = 0;
                        tempCounter++;
                if(tempCounter >= _KeyDetectCounter)
                        tempCounter = 0;
                        T0_10ms_Run_Delay = 0;
                        Key = tempKey;
                        if(Key == _Key_Press) //Key press
                                KeyChange = 1;
                                if(KeyClickCounter < 255)
                                        KeyClickCounter++;
                        else   //Key release
                                KeyChange = 2;
                        T0_10ms_KeyChanged = 0;
        else
                tempCounter = 0;
void KeyHandler()
        if(T0_10ms_KeyChanged >= _DCIntervalTime)
                KeyClickCounter = 0;
        //double click
        if(KeyChange == 1 && KeyClickCounter >= 2)
                FunctionEntrance = 2; //go to double click function
                KeyChange = 0;
        //single click
        if(KeyChange == 2 && T0_10ms_KeyChanged >= _DCIntervalTime)
                FunctionEntrance = 1; //go to single click function
                KeyChange = 0;
        //Key LongPress
        if(KeyChange == 1 && T0_10ms_KeyChanged >= _T0UserModeChange)
                KeyChange = 0;
                //put your long press function here
void Old_CPS_UpDate()
        if(T0_10ms_Update_CTData >= _Time0_UpDate_CPS)
                //calculate the average with the latest 20 CTData values
                Old_CTData = (Old_CTData * 19/20) + (New_CTData/20);
void main()
        Init();
        __delay_ms(200);
        while(1)
                if(T0_5ms_CTData >= 2) //start Touch module per 10ms
                        T0_5ms_CTData = 0;
                        TouchReStart(); //re-start Touch module
                TouchDetect();
                KeyDetect();
                KeyHandler();
                if(FunctionEntrance != 0)
                        if(FunctionEntrance == 1)
                                //put your single click function here
                        else
                                //put your double click function here
                        FunctionEntrance = 0;
KF8TS2508_test.zip
3.74 KB, 下载次数: 20
树上的小鸟 发表于 2022-1-27 09:00 | 显示全部楼层
赞一个
duo点 发表于 2022-2-7 16:23 来自手机 | 显示全部楼层
再赞一个
match007 发表于 2022-2-11 14:36 | 显示全部楼层
楼主棒棒~~
 楼主| Bengor 发表于 2022-2-18 16:29 | 显示全部楼层
谢谢!有空多交流~
 楼主| Bengor 发表于 2022-2-18 16:30 | 显示全部楼层
谢谢!有空多交流~
 楼主| Bengor 发表于 2022-2-18 16:31 | 显示全部楼层
谢谢!有空多交流~
小菜鸡的魅力 发表于 2022-12-7 16:36 | 显示全部楼层
帮助很大,谢谢!
