- int main(void)
- /* Define and initialize all Variables */
- uint8_t memory_s[16]={1,2,4,6,8,10,12,14,16,18,20,22,24,26,28,30};
- uint8_t memory_r[16]={0};
- /* Reset of all peripherals, Initializes the Systick. */
- SystemTick_Init();
- /* Initializes all peripherals clock you need */
- SystemClock_Reconfig();
- /* Initialize all configured peripherals */
- GPIO_Init();
- DMA_Init();
- Timer1_Init();
- OLED_Init();
- ADCx_Init();
- #if USED_IIC_SOFT
- // I2C_WritePage(SLAVE_ADDRESS0,5,0,memory_s);
- // delay_ms(100);
- I2C_ReadPageBytes(SLAVE_ADDRESS0,5,0,memory_r);
- #else
- I2C1_Init();
- delay_ms(10);
- I2C_WriteOneByte(SLAVE_ADDRESS0,5,5,138);
- #endif
- /* trigger start ADCx_channels conversion */
- adc_software_trigger_enable(ADC0, ADC_REGULAR_CHANNEL);
- adc_software_trigger_enable(ADC2, ADC_REGULAR_CHANNEL);
- while(1)
- if(Module.LED_REFRESH)
- gpio_bit_set(GPIOB,GPIO_PIN_4);
- else
- gpio_bit_reset(GPIOB,GPIO_PIN_4);
- if(Module.OLED_REFRESH)
- Module.OLED_REFRESH = 0;
- // memory_r[3] = I2C_ReadOneByte(SLAVE_ADDRESS0,5,5);
- OLED_ShowNum(24,0,ADC0_Buffer[0][0],5,16);
- OLED_ShowNum(24,2,ADC0_Buffer[2][0],5,16);
- OLED_ShowNum(24,4,ADC2_Buffer[1][0],5,16);
- OLED_ShowNum(24,6,memory_r[3],5,16);
- OLED_ShowNum(96,0,ADC0_Buffer[1][0],4,16);
- OLED_ShowNum(96,2,ADC2_Buffer[0][0],4,16);
- OLED_ShowNum(96,4,memory_r[2],4,16);
- OLED_ShowNum(96,6,memory_r[4],4,16);
- return 0;
