求助stm32f4与lcd连接的配置
3474|7
xeonmm1|  楼主 | 2012-3-27 21:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
试了半天,拆了2个电阻r43,r50还是不行,代码如下
接的脚是经典组合RD PD4;WR PD5;CS PD7(ne1);RS PD11;D0-D15 ;    PD13普通背光
void FSMC_LCD_Init(void)
  FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef  p;
  /* Enable GPIOs clock */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD | RCC_AHB1Periph_GPIOE, ENABLE);
  /* Enable FSMC clock */
  RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC, ENABLE);
/*-- GPIOs Configuration -----------------------------------------------------*/
+                       SRAM pins assignment                                   +
| PD0  <-> FSMC_D2  | PE0  <-> FSMC_NBL0 | PF0  <-> FSMC_A0 | PG0 <-> FSMC_A10 |
| PD1  <-> FSMC_D3  | PE1  <-> FSMC_NBL1 | PF1  <-> FSMC_A1 | PG1 <-> FSMC_A11 |
| PD4  <-> FSMC_NOE | PE3  <-> FSMC_A19  | PF2  <-> FSMC_A2 | PG2 <-> FSMC_A12 |
| PD5  <-> FSMC_NWE | PE4  <-> FSMC_A20  | PF3  <-> FSMC_A3 | PG3 <-> FSMC_A13 |
| PD8  <-> FSMC_D13 | PE7  <-> FSMC_D4   | PF4  <-> FSMC_A4 | PG4 <-> FSMC_A14 |
| PD9  <-> FSMC_D14 | PE8  <-> FSMC_D5   | PF5  <-> FSMC_A5 | PG5 <-> FSMC_A15 |
| PD10 <-> FSMC_D15 | PE9  <-> FSMC_D6   | PF12 <-> FSMC_A6 | PG9 <-> FSMC_NE2 |
| PD11 <-> FSMC_A16 | PE10 <-> FSMC_D7   | PF13 <-> FSMC_A7 |------------------+
| PD12 <-> FSMC_A17 | PE11 <-> FSMC_D8   | PF14 <-> FSMC_A8 |
| PD13 <-> FSMC_A18 | PE12 <-> FSMC_D9   | PF15 <-> FSMC_A9 |
| PD14 <-> FSMC_D0  | PE13 <-> FSMC_D10  |------------------+
| PD15 <-> FSMC_D1  | PE14 <-> FSMC_D11  |
|                   | PE15 <-> FSMC_D12  |
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;                           //LCD背光控制
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_SetBits(GPIOD, GPIO_Pin_13);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;//RST
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* GPIOD configuration */
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource8, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource9, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource10, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource11, GPIO_AF_FSMC);
  //GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_FSMC);
  //GPIO_PinAFConfig(GPIOD, GPIO_PinSource13, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_FSMC);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_5 |
                                GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11
                                 | GPIO_Pin_14 | GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_25MHz;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
  /* GPIOE configuration */
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource0 , GPIO_AF_FSMC);
  //GPIO_PinAFConfig(GPIOE, GPIO_PinSource1 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource3 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource4 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource7 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource8 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource9 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource10 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource11 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource12 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource13 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource14 , GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource15 , GPIO_AF_FSMC);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0  | GPIO_Pin_3 | GPIO_Pin_4 |
                                GPIO_Pin_7  | GPIO_Pin_8  | GPIO_Pin_9  | GPIO_Pin_10 |
                                GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
                                GPIO_Pin_15;
/*-- FSMC Configuration ------------------------------------------------------*/
   p.FSMC_AddressSetupTime = 0x02;
  p.FSMC_AddressHoldTime = 0x00;
  p.FSMC_DataSetupTime = 0x05;
  p.FSMC_BusTurnAroundDuration = 0x00;
  p.FSMC_CLKDivision = 0x00;
  p.FSMC_DataLatency = 0x00;
  p.FSMC_AccessMode = FSMC_AccessMode_B;
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_NOR;
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
  /* Enable FSMC Bank1_SRAM Bank */
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);
void LCD_WR_REG(unsigned int index)
        *(__IO uint16_t *) (Bank1_LCD_C)= index;
#define Bank1_LCD_D    *((volatile uint16_t*)0x60020000)    //显示区数据地址
#define Bank1_LCD_C    *((volatile uint16_t*)0x60000000)         //显示区指令地址
0x60020000,0x60040000,0x60010000都试过了
液晶是4.3寸,驱动是SSD1963~~~麻烦大虾们指教~~~不胜感激
airwill| | 2012-3-28 20:46 | 只看该作者
还有 液晶的 RESET 脚也要找个 IO  口控制起来.
评分
参与人数 1威望 +1 收起 理由
xeonmm1 + 1
xeonmm1|  楼主 | 2012-3-29 07:41 | 只看该作者
2# airwill
有的,不过是通用io
airwill| | 2012-3-30 08:41 | 只看该作者
通用io 没有问题,有没有控制呢,给一个复位信号?
xeonmm1|  楼主 | 2012-3-30 14:20 | 只看该作者
4# airwill
何时再需要复位信号呢?
airwill| | 2012-3-30 15:08 | 只看该作者
上电的时候要复位咯
xeonmm1|  楼主 | 2012-3-31 00:30 | 只看该作者
6# airwill
今天终于有可以显示···不过全部雪花,io输出频率都正常~~请问是因何缘故,而且只有2/5屏有雪花,下面都是白的
xeonmm1|  楼主 | 2012-3-31 00:37 | 只看该作者
6# airwill
http://xeonmm1.blog.163.com/prevPhDownload.do?host=xeonmm1&albumId=230976943&photoId=7553925478
