- int main(void)
- int no=0;
- /** Buffer Compare state */
- uint8_t state = FALSE;
- /** SPI receive Buf*/
- uint8_t rxDataBufSPI[DATA_BUF_SIZE] = {0x00};
- /** USART receive Buf*/
- uint8_t rxDataBufUSART[DATA_BUF_SIZE] = {0x00};
- // LCD液晶初始化
- lcd_25696_init();
- // 测试液晶
- lcd25696_test();
- Delay(0x3000);
- clear_screen();
- APM_MINI_LEDInit(LED2);
- APM_MINI_LEDInit(LED3);
- APM_MINI_LEDOff(LED2);
- APM_MINI_LEDOff(LED3);
- USART_FullDuplex_Init();
- SPI_FullDuplex_Init();
- display_string_16x16_textmode(0, 0, (uint8_t *)"init usart2:");
- // 初始化串口2
- //#ifdef USART2_FullDuplex
- // USART2_FullDuplex_Init();
- //#else
- usart2_init();
- //#endif
- display_string_16x16_textmode(12, 0, (uint8_t *)"end");
- Delay(0x5000);
- //clear_screen();
- display_string_16x16(0, 2, (uint8_t *)"COM发送:");
- display_string_16x16(0, 4, (uint8_t *)"SPI接收:");
- display_string_16x16(0, 6, (uint8_t *)"Spi发送:");
- display_string_16x16(0, 8, (uint8_t *)"COM接收:");
- for (int i = 0; i < DATA_BUF_SIZE; i++) {
- no=i+48;
- // 串口发送数据,因为串口1有问题,根据设置,选择串口1或者串口2
- #ifdef USART2_FullDuplex
- USART_TxData(USART2, no);
- #else
- USART_TxData(USART1, no);
- #endif
- display_alpha_char(i*16+80, 2, hexchar[no/16]);
- display_alpha_char(i*16+88, 2, hexchar[no%16]);
- // SPI发送数据
- SPI_WriteByte(no);
- display_alpha_char(i*16+80, 6, hexchar[no/16]);
- display_alpha_char(i*16+88, 6, hexchar[no%16]);
- // SPI收到数据
- while (SPI_I2S_ReadStatusFlag(SPI1, SPI_FLAG_RXBNE) == RESET);
- rxDataBufSPI[i] = SPI_I2S_RxData(SPI1);
- display_alpha_char(i*16+80, 4, hexchar[rxDataBufSPI[i]/16]);
- display_alpha_char(i*16+88, 4, hexchar[rxDataBufSPI[i]%16]);
- // 等待串口收到来自SPI发出的数据
- /* Wait data is received by UART1 */
- while (USART_ReadStatusFlag(USART2, USART_FLAG_RXBNE) == RESET);
- rxDataBufUSART[i] = USART_RxData(USART2);
- #else
- while (USART_ReadStatusFlag(USART1, USART_FLAG_RXBNE) == RESET);
- rxDataBufUSART[i] = USART_RxData(USART1);
- #endif
- display_alpha_char(i*16+80, 8, hexchar[rxDataBufUSART[i]/16]);
- display_alpha_char(i*16+88, 8, hexchar[rxDataBufUSART[i]%16]);
- /** Compare receive Buffer*/
- state = BufferCompare(rxDataBufUSART, rxDataBufSPI, DATA_BUF_SIZE);
- /* Data is ok then turn on LED2 */
- if (state == 1)
- APM_MINI_LEDOn(LED2);
- } else {
- APM_MINI_LEDOn(LED3);
- while (1)
- //APM_MINI_LEDToggle(LED3);
- Delay(0x7ffff);
下载运行,结果运行中的显示为:
COM接收到的数据的第一个字节竟然是0x00,而不是臆想中的0x30。调整部分代码的执行顺序,依旧如此。
暂时没有解决,到了做饭点,去做饭。吃完晚饭后,坐下来想了想,例程中的测试是正常的,我的代码仅仅是增加一些显示测试数据的代码。再想到SPI通讯的特点,想起来是同时双向传递数据的,使用同一个CLK完成,而在我的代码中,在收发处理之间加入了很多处理代码,是不是这部分代码导致了通讯数据有延时,导致错位?马上调整代码为如下形式:
- int main(void)
- int no=0;
- // LCD液晶初始化
- lcd_25696_init();
- // 测试液晶
- lcd25696_test();
- Delay(0x3000);
- clear_screen();
- // 初始化串口2
- usart2_init();
- Delay(0x5000);
- //clear_screen();
- no=i+48;
- // SPI发送数据
- // SPI收到数据
- if (state == 1)
- } else {
- while (1)
- Delay(0x7ffff);
编译、下载、运行。液晶显示为:
终于正常了。
这次的测试,给了自己一个教训。单片机执行速度很快,是微秒级的,在自己看来,这些都很短,在处理液晶显示的时候,花的时间可以忽略不计。然而在时序要求比较严格的地方,就可能造成无法预知的后果。这个情况,就像在有些I2C通讯的时候,如果出现了别的中断处理导致I2C通讯的延迟,等中断结束的时候,I2C通讯已经不能被正常执行了,是一样的道理。而且,自己也忽视了SPI双向通讯的特点,所出现这个结果太正常了。希望自己能牢牢记住这次的教训,避免下次再犯同样的错误。
在测试中,我还发现另外一个不解的问题,就是在下载了和串口有关的代码后(如这次的SPI测试),串口会在复位执行新下载的程序前,不断地向串口发出数据,以0x00居多,但没有规律。即使按下复位按钮不松开,发送也不会停止。在自己的印象中,执行复位,处于复位状态的微处理器是不应该工作的啊?怎么会发送串口数据呢?我的这个程序中的串口1和串口2都用了,但和串口2比,串口1使用了USART1_CK(PA8)这个信号,结果在复位状态下串口1不断发出数据,但串口2却没有。为了验证,把串口2也按照串口1方式初始化,使用USART2_CK(PA4),然后观察复位状态下串口2是否也不断发出数据。结果串口2也出现了不断发数据的情况。这个问题,我估计自己是解决不了了,只好告知极海的技术人员了。希望能解决。
