[其他产品] Microchip C语言编译器论坛
1412|7
 楼主| 斧王FUWANG 发表于 2022-5-31 17:17 | 显示全部楼层 |阅读模式
xc16问题
dspic器件,在xc16编译器下的.S源文件里怎么定义一个结构体变量??谁试过这是官网上扣的一个例程,感觉和普通的汇编编程风格很不同额,比方说一些伪指令前面都加个“.”还有就是程序中的ExampleHPFFilter是个结构体变量么,如何定义的?
 楼主| 斧王FUWANG 发表于 2022-5-31 17:18 | 显示全部楼层
  1. /*******************************************************************************
  2. High Pass Filter coefficients file
  3. //高通滤波系数文件
  4. Company:
  5. Microchip Technology Inc.
  6. File Name:
  7. examplehpf.s
  8. Summary:
  9. Consists of coefficients used by the filter function
  10. //包含了滤波函数的系数
  11. Description:
  12. This file composes of the high pass filter coefficients that are used
  13. by the IIRTransposed filter function to filter the incoming analog
  14. signal. These coefficients reside in the x-memory area.
  15. //这些系数存在于X-memory存储区域
  16. *******************************************************************************/
  17. /*******************************************************************************
  18. Copyright (c) 2012 released Microchip Technology Inc.  All rights reserved.
  19. Microchip licenses to you the right to use, modify, copy and distribute
  20. Software only when embedded on a Microchip microcontroller or digital signal
  21. controller that is integrated into your product or third party product
  22. (pursuant to the sublicense terms in the accompanying license agreement).
  23. You should refer to the license agreement accompanying this Software for
  24. additional information regarding your rights and obligations.
  25. SOFTWARE AND DOCUMENTATION ARE PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND,
  26. EITHER EXPRESS OR IMPLIED, INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF
  27. MERCHANTABILITY, TITLE, NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE.
  28. IN NO EVENT SHALL MICROCHIP OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER
  29. CONTRACT, NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR
  30. OTHER LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
  31. INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE OR
  32. CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT OF
  33. SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
  34. (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
  35. *******************************************************************************/
  36. ; *****************************************************************************
  37. ; *****************************************************************************
  38. ; Section: Constants
  39. ; *****************************************************************************
  40. ; *****************************************************************************
  41. .equ ExampleHPFNumSections, 5
  42. ; ..............................................................................
  43. ;
  44. ; Allocate and initialize filter coefficients
  45. ;
  46. ; These coefficients have been designed for use in the Transpose filter only
  47. .section .xdata, xmemory, data  ;THIS line was modified
  48. ;to be compatible with C30 v1.3x
  49. ExampleHPFCoefs:
  50. .hword  0x2392  ; b( 1,0)/2
  51. .hword  0xB8FF  ; b( 1,1)/2
  52. .hword  0x3D5F  ; a( 1,1)/2
  53. .hword  0x2392  ; b( 1,2)/2
  54. .hword  0xEF39  ; a( 1,2)/2
  55. .hword  0x2FBB  ; b( 2,0)/2
  56. .hword  0xA1F2  ; b( 2,1)/2
  57. .hword  0x579D  ; a( 2,1)/2
  58. .hword  0x2FBB  ; b( 2,2)/2
  59. .hword  0xDA17  ; a( 2,2)/2
  60. .hword  0x3818  ; b( 3,0)/2
  61. .hword  0x9344  ; b( 3,1)/2
  62. .hword  0x68F9  ; a( 3,1)/2
  63. .hword  0x3818  ; b( 3,2)/2
  64. .hword  0xCC0D  ; a( 3,2)/2
  65. .hword  0x3C51  ; b( 4,0)/2
  66. .hword  0x8C80  ; b( 4,1)/2
  67. .hword  0x7150  ; a( 4,1)/2
  68. .hword  0x3C51  ; b( 4,2)/2
  69. .hword  0xC52E  ; a( 4,2)/2
  70. .hword  0x3E73  ; b( 5,0)/2
  71. .hword  0x8920  ; b( 5,1)/2
  72. .hword  0x7583  ; a( 5,1)/2
  73. .hword  0x3E73  ; b( 5,2)/2
  74. .hword  0xC175  ; a( 5,2)/2
  75. ; ..............................................................................
  76. ; Allocate states buffers in (uninitialized) Y data space
  77. .section .yconst
  78. ExampleHPFStates1:
  79. .space ExampleHPFNumSections*2
  80. ExampleHPFStates2:
  81. .space ExampleHPFNumSections*2
  82. ; ..............................................................................
  83. ; Allocate and intialize filter structure
  84. ;配置和初始化,滤波器结构体
  85. .section .data
  86. .global _ExampleHPFFilter
  87. ;这个是对ExampleHPFFilter定义么????否则该变量是在哪里定义的??
  88. _ExampleHPFFilter:
  89. .hword ExampleHPFNumSections-1
  90. .hword ExampleHPFCoefs
  91. .hword 0xFF00
  92. .hword ExampleHPFStates1
  93. .hword ExampleHPFStates2
  94. .hword 0x0000
  95. ; ..............................................................................
  96. ; Sample assembly language calling program
  97. ;  The following declarations can be cut and pasted as needed into a program
  98. ;               .extern _IIRTransposeFilterInit
  99. ;               .extern _BlockIIRTransposeFilter
  100. ;               .extern _ExampleHPFFilter
  101. ;
  102. ;               .section        .bss
  103. ;
  104. ;        The input and output buffers can be made any desired size
  105. ;          the value 40 is just an example - however, one must ensure
  106. ;          that the output buffer is at least as long as the number of samples
  107. ;          to be filtered (parameter 4)
  108. ;input:         .space  40
  109. ;output:        .space  40
  110. ;               .text
  111. ;
  112. ;
  113. ;  This code can be copied and pasted as needed into a program
  114. ;
  115. ;
  116. ; Set up pointers to access input samples, filter taps, delay line and
  117. ; output samples.
  118. ;               mov     #_ExampleHPFFilter, W0  ; Initalize W0 to filter structure
  119. ;               call    _IIRTransposeFilterInit ; call this function once
  120. ;
  121. ; The next 4 instructions are required prior to each subroutine call
  122. ; to _BlockIIRTransposeFilter
  123. ;               mov     #_ExampleHPFFilter, W0  ; Initalize W0 to filter structure
  124. ;               mov     #input, W1      ; Initalize W1 to input buffer
  125. ;               mov     #output, W2     ; Initalize W2 to output buffer
  126. ;               mov     #20, W3 ; Initialize W3 with number of required output samples
  127. ;               call    _BlockIIRTransposeFilter        ; call as many times as needed
sadicy 发表于 2022-6-3 09:08 | 显示全部楼层
很少看s文件
橘子阿小 发表于 2022-6-7 08:04 | 显示全部楼层
它是一个子函数
chenqianqian 发表于 2022-6-7 08:09 来自手机 | 显示全部楼层
楼主还用汇编写代码?
豌豆爹 发表于 2022-6-7 10:13 | 显示全部楼层
为什么你贴的代码底纹是黑色的,
lcczg 发表于 2022-6-8 17:01 | 显示全部楼层
具体格式解释,汇编器的用户手册应该会讲。
活跃的老崔 发表于 2022-6-27 08:58 | 显示全部楼层
